Using a Variac to simulate UPS battery
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Good day folks. I noticed we have a beefy UPS just sitting there in the corner of the shop, but no batteries. It takes a lot of them judging by its size, but I don't know if it still works. Would it a dumb idea to stick the battery terminals on a variac to simulate a charged battery to see if it fires up ? Of course, I'd use a rectifier and a capacitor (or several) to smooth out the voltage as much as possible and also wouldn't plug the UPS itself into the mains - I'm not that dumb A lightbulb in series with the DC might also be a good idea.
    Has anyone done this before or would something pop immediately ? A variac doesn't isolate from the mains, so it would be a shock hazard, but it's just for testing purposes. I imagine if I plug the UPS into the wall, I'd create a short, but assuming I don't and just try to power it off battery to see if the inverter is functional...Any other UPS troubleshooting tips would be greatly appreciated.
    Wattevah...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Using a Variac to simulate UPS battery
    Would it a dumb idea to stick the battery terminals on a variac to simulate a charged battery to see if it fires up ? Yes
    Isolation is still the issue... there had been another thread with related issues, in fact you may have started it... At least it seems a lot of UPS designs don't completely isolate the battery from the line and hence they give warnings not to work on batteries when plugged in.
    Ultimately I think UPSes, if they don't come with working batteries are generally lost causes - you have to guess whether they work or not. Take your chance and get batteries or not. I think a vast majority of them still work if they're not of the high frequency type, and usually they get disposed of for the sole reason of... yep you guessed it, bad batteries.
    If you have an isolated bench psu, you can use that, though I'm not sure my PSU could power my UPS for testing, it only goes to 18V and 15A. My UPS that no longer has any good batteries requires three 6V batteries, so my PSU won't cut it.
    • Sametbey
      • Jan 2021
      • 229
      • Turkey
      You can estimate how many 12V 9A UPS batteries can be inside the UPS. When you plug the UPS into a 220V AC electrical outlet, you can measure how many volts it produces for charging. about how many volts is required (6 * 12V for 72V) You should make the variac output DC with diode and capacitor.
      I'm not happy to be so strong. because it's not humanly
        • Jul 2011
        • 6057
        To me this might not be a good idea to do this because of what has been talked about earlier about isolation of Variac I would not mind coming up with something that could be used to check a UPS backup without using batteries to test one but I want to do this safely and blow up something or catch something on fire
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          As I said in my original post: as long as you don't connect the UPS to mains at the same time, I don't see why isolation should be of concern when using a variac.
          Wattevah...
          • Sametbey
            • Jan 2021
            • 229
            • Turkey
            As long as you don't connect the UPS to the mains at the same time, there is no problem. however be aware of the danger of electric shock. How many volts will you give from the variac? Are you going to use a rectifier (diode)?
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              I said I'd use a FULL BRIDGE RECTIFIER in my original post (and probably a cap+coil to smooth it out as much as possible, though the UPS itself is likely to have some beefy caps on its battery input anyway). I'm not crazy enough to feed it AC
              As for the voltage, I'd adjust it to match the amount of batteries it's meant to work with.
              Wattevah...
              • Sametbey
                • Jan 2021
                • 229
                • Turkey
                There are 3 12V 9A batteries in the 1000VA ups, I use. Input rectifier circuit failed due to high voltage. i fixed it
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  You mean the UPS's internal rectifier for mains, or have you already tried the Variac idea and killed a rectifier trying it ?
                  Wattevah...
                  • Sametbey
                    • Jan 2021
                    • 229
                    • Turkey
                    İnternal rectifier for mains
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8701
                      testing UPS implies also testing switchover time..
                      You'll need massive supplemental filtering, filtering batteries is virtually unnecessary when using low or low enough esr batteries.
                      • Dannyx
                        CertifiedAxhole
                        • Aug 2016
                        • 3912
                        That's what worries me: it may not like the dirty DC coming out a simple bridge rectifier...no idea how I should filter it though. I think I should build some sort of test jig which is always assembled and ready to connect to any UPS for this purpose. Trouble is I think the values for the components (which I'm not entirely sure what they should be to begin with) would also have to change based on the voltage I set on the Variac...
                        Wattevah...
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          Due to the low frequency of line voltage you'll probably need quite a bit of capacitance to "match" the voltage stability of a battery, probably 10millifarads would be a start?
                          My variac can only handle like 10 amps so technically my bench PSU surpasses the current capacity of my variac...
                          • shovenose
                            Send Doge Memes
                            • Aug 2010
                            • 6575
                            Use a bunch of car batteries
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              yeah that's what he should do... Or just one car battery...
                              I wish I could do the same with my 18V UPS.
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                If I had a bunch of car batts just laying around, I could probably afford proper SLAs
                                This is intended solely for troubleshooting purposes when I get a big ol' hunk of an UPS with no or dead batteries and I need to test how much of it still works, namely the inverter.
                                I know this trick works with smaller units and I even tested myself up to 24v using regular power bricks, but when you start going above 36v you have a bit of a challenge to replicate the volts AND amps a ton of SLAs can deliver...
                                Wattevah...
                                  This was what I did in t he lab to test the UPS without having the batteries around, it is just enough to make the UPS run at low AC load.
                                  I use old UPS transformer 120VAC side fed by the VARIAC, the low Voltage side (low Voltage high current winding which was used to be driven by the MOSFET's and get the DC from the batteries) is connected to high current bridge rectifier and lot of high capacitor bank.
                                  for example if the 12V output is drawing 10A, the AC side fed by VARIAC will only draw a little over 1ACA. With is setup you have isolation provided by the old UPS transformer.
                                  I save a lot of old transformer from old UPS to build high power DC power supplies. I am sure you have lots of broken UPS to play with.
                                  • Dannyx
                                    CertifiedAxhole
                                    • Aug 2016
                                    • 3912
                                    Small units are not the issue. Like I said, I was able to test up to 24v battery voltage by using a simple wall-wart, though, granted, with no load, as that would've probably overloaded it. The problem is testing larger units which can easily take 6 batteries in series or perhaps even more, resulting in a voltage which can't be easily replicated, hence where the variac idea came from.
                                    The transformer idea is actually not bad, especially if it's a 230v-110v transformer of a decent size.
                                    Wattevah...
                                    • redwire
                                      • Dec 2010
                                      • 3912
                                      The problem with your approach is the poor regulation of the variac and rectifier.
                                      There's only a few volts difference between a "dead" SLA battery cutoff maybe 10.5VDC and good 12V and charging 14V.
                                      You can variac dial in 13VDC, with the UPS plugged in it jumps to 14V to charge the imaginary battery, and when there is no mains the UPS starts running off the variac and the voltage sags too much.
                                      What happened to your DPS5020 power supply build? I would use that, with an extra output diode in series so the UPS charging does not backfeed and blow up the DPS.
                                      Even 1,000VA UPS needs at least 50A at 24V! When the variac power supply sags to 10V, it will just shut off.
                                      I would test the UPS using a bench power supply, and then do the load test using batteries. It's just caps, mosfets, and relays that fail usually.
                                      • shovenose
                                        Send Doge Memes
                                        • Aug 2010
                                        • 6575
                                        I don't know, I'm broke as heck and have at least four working car batteries floating around
                                          12-31-2023, 06:04 AM
                                        • flat-earther
                                          Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
                                          by flat-earther
                                          I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
                                          To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
                                          I have opened the camera and I think there is enough room to add something inside to accomplish this:
                                          The camera is powered by a 3.7V nominal single cell lithium ion battery.
                                          So I need to connect another battery in...
                                          06-08-2025, 02:00 AM
                                        • mkdj
                                          by mkdj
                                          Mark and model: ASUS X571
                                          Tests already made:
                                          - I have removed...
                                          07-14-2025, 09:16 AM
                                        • huzo
                                          HP ELITE X2 1013 G3 weird battery issue
                                          by huzo
                                          Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
                                          01-31-2025, 12:09 AM
                                        • trepachka
                                          iPad Air A1475 Boot loops after replacing battery
                                          by trepachka
                                          This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
                                          The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
                                          I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
                                          11-08-2024, 03:17 PM
