Using a Variac to simulate UPS battery
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Re: Using a Variac to simulate UPS battery
    Originally posted by redwire
    What happened to your DPS5020 power supply build? I would use that, with an extra output diode in series so the UPS charging does not backfeed and blow up the DPS.
    Surprised someone still remembers that It's pretty much just sat there this whole time, close to how the original discussions left it, still waiting for me to wire it all up So much to do, so little time.....
    Wattevah...
    • redwire
      • Dec 2010
      • 3906
      I had a big UPS come into the shop, it was dead. I think 3,000VA. Connected 4 car batteries for 48V and I started probing around following power, when all of a sudden a connection arced loud when I poked it. The entire shop heard it, freaked out techs ran out, they were scared it was going to blow up or something. It was kind of funny. All it was is a factory cold solder joint on a wire terminal block.
      Go and use what you got, try the variac, I think the voltage will be too mushy to work.
      So I would instead get the DPS5020 running...
        12-31-2023, 06:04 AM
      • flat-earther
        Adding a clock battery to action camera to retain date&time when changing batteries Campark X25
        by flat-earther
        I have a cheap action camera with an annoying trait, every time I change batteries the date & time gets reset and I have to set it again.
        To solve this problem I want to add a small internal battery inside it which will keep supplying power to the camera for a while while I change batteries so the date & time is retained.
        I have opened the camera and I think there is enough room to add something inside to accomplish this:
        The camera is powered by a 3.7V nominal single cell lithium ion battery.
        So I need to connect another battery in...
        06-08-2025, 02:00 AM
      • mkdj
        by mkdj
        Mark and model: ASUS X571
        Tests already made:
        - I have removed...
        07-14-2025, 09:16 AM
      • huzo
        HP ELITE X2 1013 G3 weird battery issue
        by huzo
        Hi, so the old battery was getting error stated it's capacity is starting too get low and should be replaced, so the customer bought a new one and replaced it, but the new battery was also getting this notice that it's capacity is getting low and should be replaced, so i took the laptop for testing and the battery is charging at the terminal at 8.03V , the voltage of the battery is 7.7V, and drawing around 600mA when charger is put and the laptop is off...so that should be ok... but the bios system test doesn't recognize the battery and can't do the battery test and so is the hp battery manager,...
        01-31-2025, 12:09 AM
      • trepachka
        iPad Air A1475 Boot loops after replacing battery
        by trepachka
        This iPad was working fine except the battery was not holding charge for more than 40 minutes. I replaced it with a new battery. I haven't glued the battery yet, just inserted it into the slot and held it with battery screw.
        The iPad was powered on with the new battery and I am getting white screen with Apple logo for about 10 seconds, then the screen turns dark. It then cycles like this forever.
        I know the battery is working because the iPad continues to boot loop without the charger until it depletes to 0% and the message displays I need to plug in the charger.
        11-08-2024, 03:17 PM
