LED Resistor Calculations ...
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    Re: LED Resistor Calculations ...
    Originally posted by eccerr0r
    The footprint model should have marked that node to be a DNC node so it would show up as a DRC or LVS error.
    If you're talking about the footprint that is used for the PCB design layout, I completely agree... that center pad should be electrically equivalent to the anode so that someone (like me) doesn't think it's available for a separate network in the schematic.
    sigpic
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      Originally posted by diif
      Your panel should really be Aluminium not FR4.
      OK, what I wanna know is ... if one uses an Aluminum backed PCB, aluminum can still conduct electricity ... unless they dope it with something that prevents that? I'm a little confused on how that works if you were to connect those center pins to an aluminum backing...
      sigpic
      • diif
        • Feb 2014
        • 6978
        • England
        #43
        Of course it conducts, it;s bare aluminium. You don't connect anything to it. The centre contact is the anode.
        https://www.pcbway.com/pcb_prototype...minum_PCB.html
        • EasyGoing1
          Shock Therapist
          • Sep 2016
          • 977
          So then how would you connect the LED to the aluminum backing for heat dissipation? Or is it just having the aluminum close to the LEDs that it will pick up the heat they are kicking out and transfer it away?
          sigpic
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8691
            Aluminum PCB just means the backing is aluminum, of course this will not function as a regular PCB, so there's a layer of dielectric on the aluminum. Then there's another layer of copper over the dielectric which gets etched. Heat transfer still needs to go through the thin dielectric layer, so it's not as good as being soldered straight to the aluminum but it's better than FR-4.
            • diif
              • Feb 2014
              • 6978
              • England
              #46
              Yes, with large copper planes on the front and the back solid aluminium the whole PCB becomes a heatsink.
              • redwire
                • 3902
                Most high power LED dies have two bonding wires, with the die (substrate) glued or soldered to the cathode leg.
                OP's having a third pad seems like it's just cheap or something.
                • EasyGoing1
                  Shock Therapist
                  • Sep 2016
                  • 977
                  Aluminum PCB just means the backing is aluminum, of course, this will not function as a regular PCB, so there's a layer of dielectric on the aluminum. Then there's another layer of copper over the dielectric which gets etched. Heat transfer still needs to go through the thin dielectric layer, so it's not as good as being soldered straight to the aluminum but it's better than FR-4.
                  So I did some re-design on the panel, and I also made a 12-volt version ... everything on one layer without any center pins on the LED at all on the board, and I had originally had some through-hole components but when I had PCBWay quote them, they wanted over $300 ... so I made everything surface without any through-hole components and am waiting for that quote... apparently, when you spec aluminum for the board, it takes longer to get it quoted, but if the quote remains at the price it was when I put it in the cart, then ill order them up and should end up with a better panel that I have now.
                  sigpic
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8691
                    I have a dead GE A19 bulb I need to take apart and do failure analysis...
                    • EasyGoing1
                      Shock Therapist
                      • Sep 2016
                      • 977
                      You're talking about a replacement light bulb? What's the point? Those things are cheap now a days.
                      sigpic
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        #51
                        I think you should look at your design to better take advantage of the copper front.
                          i think you should look at your design to better take advantage of the copper front.
                          +1
                          • EasyGoing1
                            Shock Therapist
                            • Sep 2016
                            • 977
                            Could you be more specific?
                            sigpic
                            • diif
                              • Feb 2014
                              • 6978
                              • England
                              #54
                              You want the whole of the front to heat up evenly, remove those traces and have the + and - pads the full width of the board.
                              • EasyGoing1
                                Shock Therapist
                                • Sep 2016
                                • 977
                                You mean like this?
                                The copper layer which is all on the GND net, is underneath each LEDs heat dissipation node without any exposed copper so it will heat the entire copper plane that is GND electrically then presumably that will pass to the aluminum for dissipation...
                                sigpic
                                • diif
                                  • Feb 2014
                                  • 6978
                                  • England
                                  #56
                                  No not like that, I still see traces, the heat is trapped under the LEDs and can't go sideways.
                                  Draw thick lines from almost the top to the bottom that is your + pad the a tiny gap then another for the - and so on. The only thin trace will be the - round the edge going pack to the - input.
                                  With LEDs you're routing heat as well as electricity, heat is your primary concern.
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8691
                                    And still the NC pad are all connected together? Or are you using a different chip now?
                                    note: depending on soldermask insulation is not a good idea...
                                    • EasyGoing1
                                      Shock Therapist
                                      • Sep 2016
                                      • 977
                                      OK, I colored the copper layer which is all electrically GROUND in yellow. Everywhere you see an X. the center pin of the LED is pressed against the SOLDERMASK on the board... the center pins are NOT soldered to the board. THEN, the back of the board is aluminum...
                                      Tell me how to dissipate heat better than this?
                                      sigpic
                                      • diif
                                        • Feb 2014
                                        • 6978
                                        • England
                                        #59
                                        I'm not sure why you're capitalising certain words but this photo should help explain.
                                        The thin bit you see is the only part of the board apart from near the edge there is no used copper, when i say used, I mean used for dissipating heat, power is coming top to bottom. The anodes and cathodes are all joined in big wide copper strips.
                                        The centre pad on your LED should be soldered it's connected to the anode.
                                        • EasyGoing1
                                          Shock Therapist
                                          • Sep 2016
                                          • 977
                                          "The anodes and cathodes are all joined in big wide copper strips" - so in my design, this is a problem ...
                                          Here is the schematic for my LED panel... as you can see, if I just connected all of the anodes and cathodes ... it would not work at all.
                                          Also, the center pin does NOT need to be soldered for the LED to work. The two ends of the LED are all that are necessary for the things to light up.
                                          sigpic
