Need help to identify a component (diode?)
  • Askic
    • Sep 2018
    • 187
    • BIH
    Hello guys,
    can you please help my identify components with numbers 53 and 59? They could be a diodes?
    This component 53 is connected in parallel between source and drain of a P Channel A2179 Mosfet.
    I wonder what is their purpose here.
    Thank you!
    • Jul 2011
    • 6070
    Re: Need help to identify a component (diode?)
    This might help you
    http://www.s-manuals.com/smd/53
    Zener Diodes
    https://cdn.badcaps-static.com/pdfs/...57602c93cc.pdf
    Google search—> SMD diode “53”
    Someone else would have to answer this question for you
    “ I wonder what is their purpose here. ”
    I hope this helps you
    • R_J
      • Jun 2012
      • 9623
      The thumb nail picture is too small, there seems to be other markings (above the 59) on the devices? Since there are 3 in parallel I would almost suspect they are capacitors?
      What is the board from? any numbers on the board? Can you tell how the circuit is used? is the mosfet just used as a switch?
      • Askic
        • Sep 2018
        • 187
        • BIH
        Thank you sam sam sam.
        R_J this is from Fujitsu H700 laptop board. I have no schematics, but I can guess that Mosfets are used for protection since thea are in close proximity of the batery. There is a current sensing resistor there.
        • dicky96
          Sun Seeker
          • Mar 2017
          • 1825
          • Spain
          It looks like a Tantalum capacitor to me too.
          Follow me on YouTube
          Learn Electronics Repair
          • hobostove
            Corsair RM1000e - Help identify 5VSB Zener diode
            by hobostove
            Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
            Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
            There's a 22ohm resistor that's melted and open, but it still has the bands.
            The other part is a zener diode and it's top went to jesus, so I can't read the marking.
            It looks like the diode connects the source and drain of a TNY284...
            03-27-2025, 02:25 PM
          • eccerr0r
            Electric lawnmower...purpose of diode...
            by eccerr0r
            I was looking at an old battery powered electric lawnmower I picked up as the previous owner didn't want to buy a new board to replace a ruined old board. Tried to study how it was designed - it appears it has a huge 80A contactor...or rather, a 80A relay. It appears to be SPDT to control the motor. A 30A relay protects the circuitry.
            The weird thing I don't quite get is how this thing is connected. The common contact is connected to the motor. The NO contact is connected to the battery, which is expected, so when the relay is activated, the common is connected to the NO contact and...
            08-27-2022, 12:54 PM
          • jjne
            AUO M270QAN01 - identify diode?
            by jjne
            I have a small number of monitors based on the above panel and am working through them. I have at least two with a single, burned-out diode. From what I can see it's something like DI428 or DII428 or DH428. Here's a picture of a working one.
            Can anyone identify this please? Based on the number 428 it may be a shottky or a Zener according to Google. The device in question is D105.
            ETA I can confirm that the number is definitely 428 (I took a video which revealed a better image), the DII appears to be a maker's mark. There's also a code 1G. Looking around...
            01-24-2024, 08:39 PM
          • gurj1979
            Ubiquitiu 24 port POE. Help Identify Diode 3pin)
            by gurj1979
            Hi again guys.
            Ive got a Ubiquiti 24 port POE Switch which has failed to work. Fans turn on, but no lights.
            I've ripped the board out, flipped it upside down and noticed a blown 3pin SMD Diode (at location D53). Marking is ESSP (as with all the other Diodes in the same row).
            Anyone help me identify the model of this Diode ?...
            08-23-2023, 08:39 AM
          • rddube
            Asus C423N motherboard - trying to identify diode
            by rddube
            Can anyone point me in the right direction as I am trying to identify which diode this is as in the red square.
            Many thanks!
            Ray...
            06-24-2023, 08:08 PM
