I am in need of a 80 buck converter that is adjustable rated 4 amps or better
    • Jul 2011
    • 6039
    Can anyone recommend a switching regulator or a buck converter that has these specifications
    Input voltage 80 adjustable at least 4 amps or better
    Any information would greatly appreciated
    Re: I am in need of a 80 buck converter that is adjustable rated 4 amps or better
    What is the highest input Voltage do you need?
    Is the 80VDC the minimum input Voltage?
      • Jul 2011
      • 6039
      From what I have seen when turning the power supply on that this voltage stabilizes at 70 to 75 volts and stay at this level until it is loaded and at 3.5 amps it is about 50 volts or so this is also stable
      I would like to have some head room above the maximum voltage that I have seen so far
        • Jul 2011
        • 6039
        Test
        • redwire
          • 3907
          What are the specs you are looking for? >80VDC 4A in, 50VDC 4A out?
            • Jul 2011
            • 6039
            I could work with these specifications that you have in your reply
            But what I am really interested in is an adjustable output voltage at minimum of 4 amps
              • Jul 2011
              • 6039
              Would this work
              DC-DC Buck Converter Step-Down Power Supply Module in 20-70V Out 2.5-58V 30A
              https://www.ebay.com/itm/DC-DC-Buck-...sAAOSwCi9gBloK
              • redwire
                • 3907
                Is this for powering that big solenoid? Does it have a reverse-diode across it?
                The raw DC is from a control transformer feeding a bridge-rectifier with no filter capacitor?
                Just trying to get clear on what the load and input power is.
                Because any buck-converter will not like input ripple.
                  • Jul 2011
                  • 6039
                  I basically want to use this to test LED strips and modules and any device that has a voltage above 40 volts
                  How much filtering capacitors would I need and what type an UF value
                  I am going to power this device from the ATX switching power supply —> auxiliary power supply board
                    • 31015
                    one of the psu makers, i think kunkin makes one that is 5a 120v
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      https://www.ebay.com/itm/900W-15A-DC.../133612454146?
                        • Jul 2011
                        • 6039
                        Do you have a website link to where you can buy one
                        I found this and this would work also
                        https://www.ebay.com/itm/FNIRSI-DC60...kAAOSwF5dfhtrW
                        The only thing I have to figure out is how to make sure that the incoming voltage does not exceed 70 volts because I was looking earlier for a Zener diode to limit the voltage to 60 to 80 volts and could not find anything I could use
                          • Jul 2011
                          • 6039
                          Thank you for your website link I am sure that this will work for boost the voltage up but I am looking for buck converter to go from 80 volt to 12 for something lower if possible but I wanting it to be adjustable
                          I just have to wait until I have some more money to buy one
                          Hopefully soon
                            Not adjustable but you may be able to modify the feedback circuit.
                            What is the adjustable range?
                            https://www.amazon.com/Pro-Chaser-re.../ref=pd_sbs_4?
                            https://www.amazon.com/High-Voltage-.../ref=pd_sbs_1?
