Too much current from a Buck Converter
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Dear members,
    Let us consider the buck-converter circuit of +1.05VS_VCCPP in the PDF. +1.05VS_VCCPP is a 1.05v voltage rail. The schematic says the circuit can provide up to 20A of current. It belongs to a laptop: Lenovo G470. B+ is 19v.
    Now assume we connect +1.05VS_VCCPP to many ICs to provide power for them. The laptop works in a way that mostly less than 20A are drawn from +1.05VS_VCCPP but sometimes the required current exceeds 20A. For example, 25A or 30A.
    PU702 is the controller IC in the buck-converter circuit. It controls the output voltage according to the feedback in Pin 5.
    Please explain what will happen when the connected ICs try to draw more than 20A from this buck-converter circuit?
    Does the buck-converter circuit provide the extra current or it just provides 20A?
    Does the voltage drops at those times?
    Do the Mosfets get hot?
    Does any IC get damaged at those times?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: Too much current from a Buck Converter
    inductor gets hot
    mosfet gets hot
    regulation/ripple/voltage no longer in spec, ICs no longer work properly.
    Ideally it was designed with some buffer space past 20A but no guarantees.
    I'm surprised that it's bucking 19V to 1.05V, that's a fairly large jump though not out of the world of impossible. 19V seems kind of a waste, lithium ion battery packs usually not 19V, so a boost converter would be necessary...
    • caspian
      • Oct 2015
      • 1591
      • Laptop
      The 19v DC voltage is provided by the AC adapter of the laptop.
      Here is the datasheet of the controller in the buck-converter circuit. In Page 12, it says RT8209 has cycle-by-cycle current limiting control. then, it explains more.
      It is really important to me to know whether the extra required current leads to some damage/degradation to the buck-converter circuit and the connected ICs, or it leads to just a shutdown of the laptop?
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        In addition, I have got the following question:
        The AC adapter provides 19v 4.5A as the DC power source (B+) for this buck-converter circuit. How come this buck-converter circuit is able to generate 20A? how can the buck-converter circuit generate 15.5A more current compared to its power source?
        • Chaminda4191
          Chaminda4191
          • Apr 2023
          • 28
          • Sri Lanka
          RT8209 L/M (A8) is equivalent to APW8815. I tried it on an Optiplex 7020 motherboard, and it worked like a charm without any errors​
            Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
            The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
            The bq24745 features dynamic power management...
            10-23-2024, 02:50 AM
          • vrasp
            Issues in PWM circuit with LC filter to drive Peltier
            by vrasp
            I've been trying to build a Peltier circuit that I can control with arduino and create cooling ramps. I've never built a circuit before and only have a basic knowledge of electronics.
            I've been researching how to do this and attempted to build it. My circuit is basically a PWM signal sent to a motor driver with an LC filter to smoothen the signal. Since very low temperatures are required, I added another Peltier on top of the first one. The top Peltier needs to be driven at a lower voltage to limit the amount of heat produced and effectively lower the temperature....
            10-27-2022, 08:11 PM
          • gizmo1990
            What is this PSW1 part on a circuit board? Trying to fix a Canopus ADVC-300 DV/VHS Converter
            by gizmo1990
            I'm trying to fix this Canopus converter so that I can convert lots of old VHS cassettes. The problem is that it turns on for a split (and I mean split!) second, the fan jerks and then.. nothing. I've checked the power brick works. I've opened up the converter itself and been testing for shorts.
            The image attached shows the on/off switch (which I've checked works) to the left of the yellow socket. Below the yellow socket is a green block marked 26 with a strange symbol at the front. Putting my probes either end of this block, on the silver parts, gives an open short...
            10-21-2024, 08:02 AM
          • piernov
            Laptop battery charging circuit
            by piernov
            1. Some theory
            1.1. Introduction
            Almost every laptop has a charging circuit of some sort, that does a few things:
            • Manages switching between AC adapter and battery power
            • Manages battery charging and generates power rail to charge battery
            There are 2 different designs to handle switching between AC adapter and battery power and feeding the system:
            • Hybrid power boost (HPB) and traditional circuits without power boost (see Warning in HPB section)
            • Narrow VDC (NVDC)
            Texas instrument has a nice overview of these technologies with some more details at https:...
            11-15-2020, 01:31 PM
            ISL6556ACB ISL6556ACBZ ISL6556ACR ISL6556ACRZ PWM Controller Datasheet
            Optimized Multi-Phase PWM Controller
            with 6-Bit DAC for VR10.X Application
            The ISL6556A controls microprocessor core voltage
            regulation by driving up to 4 synchronous-rectified buck
            channels in parallel. Multi-phase buck converter architecture
            uses interleaved timing to multiply channel ripple frequency
            and reduce input and output ripple currents. Lower ripple
            results in fewer components, lower component cost, reduced
            power dissipation, and smaller implementation...
            11-05-2024, 03:10 PM
