I am in need of a 80 buck converter that is adjustable rated 4 amps or better
    • Jul 2011
    • 6070
    Can anyone recommend a switching regulator or a buck converter that has these specifications
    Input voltage 80 adjustable at least 4 amps or better
    Any information would greatly appreciated
    Re: I am in need of a 80 buck converter that is adjustable rated 4 amps or better
    What is the highest input Voltage do you need?
    Is the 80VDC the minimum input Voltage?
      • Jul 2011
      • 6070
      From what I have seen when turning the power supply on that this voltage stabilizes at 70 to 75 volts and stay at this level until it is loaded and at 3.5 amps it is about 50 volts or so this is also stable
      I would like to have some head room above the maximum voltage that I have seen so far
        • Jul 2011
        • 6070
        Test
        • redwire
          • Dec 2010
          • 3912
          What are the specs you are looking for? >80VDC 4A in, 50VDC 4A out?
            • Jul 2011
            • 6070
            I could work with these specifications that you have in your reply
            But what I am really interested in is an adjustable output voltage at minimum of 4 amps
              • Jul 2011
              • 6070
              Would this work
              DC-DC Buck Converter Step-Down Power Supply Module in 20-70V Out 2.5-58V 30A
              https://www.ebay.com/itm/DC-DC-Buck-...sAAOSwCi9gBloK
              • redwire
                • Dec 2010
                • 3912
                Is this for powering that big solenoid? Does it have a reverse-diode across it?
                The raw DC is from a control transformer feeding a bridge-rectifier with no filter capacitor?
                Just trying to get clear on what the load and input power is.
                Because any buck-converter will not like input ripple.
                  • Jul 2011
                  • 6070
                  I basically want to use this to test LED strips and modules and any device that has a voltage above 40 volts
                  How much filtering capacitors would I need and what type an UF value
                  I am going to power this device from the ATX switching power supply —> auxiliary power supply board
                    • 31281
                    one of the psu makers, i think kunkin makes one that is 5a 120v
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      https://www.ebay.com/itm/900W-15A-DC.../133612454146?
                        • Jul 2011
                        • 6070
                        Do you have a website link to where you can buy one
                        I found this and this would work also
                        https://www.ebay.com/itm/FNIRSI-DC60...kAAOSwF5dfhtrW
                        The only thing I have to figure out is how to make sure that the incoming voltage does not exceed 70 volts because I was looking earlier for a Zener diode to limit the voltage to 60 to 80 volts and could not find anything I could use
                          • Jul 2011
                          • 6070
                          Thank you for your website link I am sure that this will work for boost the voltage up but I am looking for buck converter to go from 80 volt to 12 for something lower if possible but I wanting it to be adjustable
                          I just have to wait until I have some more money to buy one
                          Hopefully soon
                            Not adjustable but you may be able to modify the feedback circuit.
                            What is the adjustable range?
                            https://www.amazon.com/Pro-Chaser-re.../ref=pd_sbs_4?
                            https://www.amazon.com/High-Voltage-.../ref=pd_sbs_1?
                            • bohaboha
                              Adjustable Buck Converter V/A potentiometer traces destroyed
                              by bohaboha
                              Hi I have destroyed the tracks to both the volt and amp connector is it possible to solve this problem and maybe find another way to connect them. see the pictures and the disaster that I did...
                              08-18-2022, 06:11 PM
                            • Manuel S.
                              Lenovo Yoga 720-15ikb (LA-E552P): DEAD - strange voltage on 5V buck converter
                              by Manuel S.
                              my Lenovo 720 is dead. :-(
                              I guess i have found an issue on the 5V buck converter (**BAC7NH** from Silergy (also called SY8288C 5V)) but i am not completely sure so i want to ask here for some hints.
                              Here is a Schematic of the IC: https://prom.ua/p1498216381-sy8288c-...ac-bacxxx.html
                              When i attach the supply 19V, i only have 1.8V on the OUT (it should be 5V). The IC is getting hot.
                              The EN1 is completely off 0V, EN2 show 1.5V.
                              If i inject 5V on the EN1 the OUT goes up to 2.6V (but never reach 5V).
                              BS seams SHORT to the OUT....
                              03-14-2024, 05:17 PM
                            • caspian
                              Too much current from a Buck Converter
                              by caspian
                              Dear members,
                              Let us consider the buck-converter circuit of +1.05VS_VCCPP in the PDF. +1.05VS_VCCPP is a 1.05v voltage rail. The schematic says the circuit can provide up to 20A of current. It belongs to a laptop: Lenovo G470. B+ is 19v.
                              Now assume we connect +1.05VS_VCCPP to many ICs to provide power for them. The laptop works in a way that mostly less than 20A are drawn from +1.05VS_VCCPP but sometimes the required current exceeds 20A. For example, 25A or 30A.
                              PU702 is the controller IC in the buck-converter circuit. It controls the output voltage according to the feedback...
                              05-29-2020, 06:41 AM
                            • adamski1952
                              ps5 shorted after buck converter
                              by adamski1952
                              Hi.all.
                              Working on a PS5 EDM-010 motherboard and i've located a short after the TLV62090RGTR 5v to 3.3v chip directly behind F7002.same chip i think. I've removed the chip thinking that was the problem but the short is still there.I injected 1v at 1 amp on output coil (arrowed in picture) but nothing shows up on my thermal camera. No boardview so I because I dont know which rail it feeds i'm reluctant to up the power injection.I could use some help with this if anone has any ideas. ...
                              12-18-2024, 08:25 PM
                            • Thetechdude
                              Repair help. Zotac trinity 4070ti 12G 3x
                              by Thetechdude
                              Hi Guys.
                              Here I have a 4070ti with some issues.
                              When powered on the led lights which power on (where the zotac logo is) flash green 3 times. Once it has flashed green 3 times it does not post.
                              Just to mention I have not worked on many 40x cards before therefore some of my assumptions could be wrong. If you do happen to find that my analysis is wrong or I have missed something feel free to comment.
                              Additionally, I do not have a schematic for this exact card model so if anyone is willing to post the schematic it would be much appreciated.
                              Resistances:...
                              09-07-2025, 07:49 AM
