UPS Project
  • dan86
    • Nov 2009
    • 35
    UPS Project
    Hi Guys,
    Please tell me if this is in the wrong place. I currently run about 10 machines including servers etc at home on my ring main 240vac supply and each machine has its own psu. However when I plug in any more machines or forget and plug in a laptop the rcd breaker trips. I have a apc ups which i could connect my machines to however i believe the 240vac pwr runs straight through that to the outlets and so doesn't solve the trip problem.
    I am considering the following:
    A number of 12v leisure batteries or better, a 1000watt inverter or better and a 12v car battery charger to charge the battery bank normally. Esentially I am creating a basic ups system where if the mains pwr trips or has an outage the machines connected to the inverter would remain on for however long the batteries lasted.
    I just need to confirm something before this is planned or non-planned depending on what you guys advise me as I know you know your stuff. If I have the following setup:
    12v mains charger > battery bank 12v batteries > 12v > 1000water inverter 240vac > socket strip and a couple of machines connected will my main rcd know about the machines psu capicaters? Say if my ring mains rcd limit was 10 machines and a 11th machine would trip the breaker ( I have been told it causes an inbalance because of the caps in the psu) would adding the machine that normally tripped my ring main still trip the breaker if it was on my home made ups system? I am sure my main rcd would't trip however many machines I had running on the battery bank within reason as the 12v car charger > batteries are feeding the machines.
    Any advice would be greatful. Apologies for the long post. Please tell me if this is a bad idea. If this is a good idea then it solves 3-4 problems.
    Daniel
  • Pyr0Beast
    • Feb 2009
    • 406
    Re: UPS Project
    It is not imbalance of capacitors it is the noise filtering of PSU which causes that some current always flows thru the grounding wire, this tripping the breaker which detects any imbalance.
      • 31277
      Re: UPS Project
      maybe, but the ring is 32a and the breakers are very fast at stopping surges.
      i'v had one trip because a lightbulb failed!
      maybe wire a second ring into the cab and put another breaker on the bussbar.
      • dan86
        • Nov 2009
        • 35
        Re: UPS Project
        Thanks guys. I believe the the rcd is 30mA and because its for domestic use it senstive.
        • dan86
          • Nov 2009
          • 35
          Re: UPS Project
          Would that mean if the machines were connected like the following below the rcd would still trip?
          12v car charger > inverter > 240vac > machines
          • dan86
            • Nov 2009
            • 35
            Re: UPS Project
            Any updates or advice on this? Please.
            • willawake
              Super Modulator
              • Nov 2003
              • 8457
              • Greece
              Re: UPS Project
              why dont you just get an electrician in?
              • Eagle2a
                • Aug 2009
                • 35
                Re: UPS Project
                I finally figured out an RCD breaker is what we call a GFCI breaker here in the USA. Are you sure you aren't exceeding the max current capacity of the breaker rather than tripping its leaky current detection circuit? And can you move the computers to a non-RCD breaker protected circuit? That would be the preferred solution.
                • Pyr0Beast
                  • Feb 2009
                  • 406
                  Re: UPS Project
                  With galvanic insulation no.
                  Current can flow thru grounds, like monitor cable, keyboard cable, KVM switch etc.
                  • MixMasta
                    • Feb 2006
                    • 142
                    Re: UPS Project
                    Get a different circuit breaker.
                    • japlytic
                      • Oct 2005
                      • 2086
                      Re: UPS Project
                      I have handled two models of UPS (not live chassis - the battery negative is connected directly to the USB communication port) which are an APC Back-UPS CS Series and a Belkin F6C800auUNV.
                      In these two models, the mains input and output are monitored directly (no isolation transformers) via high value resistors (2M0 per side in Belkin, with 800K per side in APC) while the output current is monitored by a current transformer.
                      • Pyr0Beast
                        • Feb 2009
                        • 406
                        Re: UPS Project
                        Mustek Powermust 600VA monitors input voltage the same way. The whole PCB except the COM port is under voltage.
                        • dan86
                          • Nov 2009
                          • 35
                          Re: UPS Project
                          Thanks for the replies, i've not checked the forums in a few days. The breaker is working correctly and has been tested. However because its a domestic premise we canno't have it changed. I've been told in large computer rooms such has a college campus it room they aren;'t on these breakers but its allowed because theres someone there keeping an eye on things.
                          I'm not exceeding the breakers spec ie 32amps. The solution to my problem is make it so no matter how many machines were running on the inverter the electric won't trip due to the rcd being so sensitive. 99.99% of the time the power is fine and doesn't trip but does sometimes causing downtime etc.
                          I mean would running the machines earth elsewhere from the rest of the mains circuit make a difference?
                          • kc8adu
                            • Nov 2003
                            • 8832
                            • U.S.A!
                            Re: UPS Project
                            big isolation transformer?
                            • dan86
                              • Nov 2009
                              • 35
                              Re: UPS Project
                              Infact I was just reading up about that and then saw your reply.
                              • CapLeaker
                                VOIP, ATA REN and old analog phones ring voltage booster
                                by CapLeaker
                                I am working on a backup phone to VHF paging solution. Basically I am dealing with the old Zetron pagers. Here is how it works: One calls a number, the Zetron picks up, operator punches in the DTMF access code, the Zetron keys the transmitter and you can talk. press # the Zetron unkeys the transmitter and hangs up / times out.
                                Now this setup works good on the old land lines, but not at all using a VOIP ATA. You can call all you want and swear like a bastard at the Zetron, but it will not (even if I threaten it's life) pick up.
                                Yep, I know about the high ring voltage...
                                12-10-2022, 09:27 PM
                              • sew333
                                Can halogen bulb damaged trip breaker?
                                by sew333
                                Hello. Today first time something tripped breaker in my house. I mean i was sitting on Windows 10 desktop ,like always and i hear BUM from fuse box. And power go down. Pc turned off.
                                I have that pc almost 1 year and something like that never happened. I think there was not circuit overload,because all devices was off,like tv,washer etc. Only pc was on. And nothing get damaged. Anybody have clue why it happened?
                                To turn back power again i change breaker to up of course. And its fine again.
                                PC:
                                Aorus AD27QD
                                AORUS PRO Z390-PRO GAMING
                                Aorus...
                                08-29-2020, 03:09 PM
                              • BOSCHNJAK
                                by BOSCHNJAK
                                ABOUT ME INTRODUCTION FILE
                                2
                                024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                                2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                                2022 BEV, PROJECT ?
                                2021 BEV, PROJECT ?
                                2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                                2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                                12-28-2023, 02:09 PM
                              • Smartec82
                                The Project ID of the Thomson 55UC6406
                                by Smartec82
                                Does anyone know the Project ID of the Thomson 55UC6406 , panel: LSC550FN11-906? The picture appears duplicated and I can't change it in the service menu. I can only change the Project ID by pressing 062598, pressing 3 dashes, ID.
                                10-03-2025, 11:30 AM
                              • tony359
                                Ring tester
                                by tony359
                                I'd like to add a ring tester to my toolbox to test flybacks but also low frequency transformers if possible.
                                I found a few products online, some based on the "diodegonewild" design, others are different designs. Some are available to build DIY, others are not.
                                Any suggestions on a DIY one I could put together? Ideally something which would also be able to test low frequency transformers, that might be handy.
                                So far I found these two:
                                http://bobparker.net.au/Basic%20Digital%20Ringer/ (the posher version...
                                09-13-2023, 07:34 AM
