Can halogen bulb damaged trip breaker?
  • sew333
    • Apr 2017
    • 81
    • Poland
    Hello. Today first time something tripped breaker in my house. I mean i was sitting on Windows 10 desktop ,like always and i hear BUM from fuse box. And power go down. Pc turned off.
    I have that pc almost 1 year and something like that never happened. I think there was not circuit overload,because all devices was off,like tv,washer etc. Only pc was on. And nothing get damaged. Anybody have clue why it happened?
    To turn back power again i change breaker to up of course. And its fine again.
    PC:
    Aorus AD27QD
    AORUS PRO Z390-PRO GAMING
    Aorus 2080 Ti waterforce stock
    2x16GB DDR4 GSKILL XMP
    9700K STOCK
    Seasonic TX-750W TITANIUM PLUS PRIME
    Never happened with that pc in whole year. Also pc is stable during full load etc.
    Today i just browsing internet and power goes down with tripped breaker.
    Pc working like before again. Weird any clues?
    Then.......i go to bathroom and saw that one of 3 led bulbs no lightning. So it get burned. So that was propably that halogen bulb?
  • petehall347
    • Jan 2015
    • 4426
    Re: Can halogen bulb damaged trip breaker?
    post a pic of the halogen bulb .
      • 31015
      led? halogen? which is it?
      • sew333
        • Apr 2017
        • 81
        • Poland
        fluorescent
        • petehall347
          • Jan 2015
          • 4426
          turn it off and see if all others work
          • sew333
            • Apr 2017
            • 81
            • Poland
            One not working ,but 2 working. Its halogen bulb. Sorry ,not fluorescent.
            • petehall347
              • Jan 2015
              • 4426
              change broke one for new one and see what happens
                • Jul 2011
                • 6039
                12 volts or higher voltage than this
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8146
                  I've had something similar happening. The end of the story was a heat damaged AC wire that went to an old florescent light fixture with a transformer style ballast. The insulation had broken down, and rendered the copper also in a green color.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Power surge maybe?
                    • sew333
                      • Apr 2017
                      • 81
                      • Poland
                      I have question.Maybe my psu of pc caused breaker to trip or it was that bulb? Also pc is running still.
                      • TechGeek
                        Computer Geek
                        • Jan 2015
                        • 2254
                        Likely that bulb. Replace it and see if it trips again.
                        Permanently Retired Systems:
                        Kooky and Kool Systems
                        sigpic
                        • sew333
                          • Apr 2017
                          • 81
                          • Poland
                          Somebody said this to me:"I am a registered electrician in the state of Wi and I'm going to tell you to call a local electrician because something isn't right with your household's wiring. You need somebody there in person to find the fault meaning this is outside the scope of what we can help with on a forum. "
                          So he is right?
                          • sew333
                            • Apr 2017
                            • 81
                            • Poland
                            Hey somebody said this to me:"Yes, something isn't right. Something is triggering the breakers. Bulbs and other electronics are dying. Explain this to the electrician. An electrician posted in this thread... follow their advice."
                            What triggering,is he right?
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              I think it's a surge, and to fix this, likely you're dealing with something that's dangerous to work on. A certified electrician who knows your locale's wiring code is needed to work on it safely.
                              • sew333
                                • Apr 2017
                                • 81
                                • Poland
                                Or maybe bad luck ? Monitor and bulb get damaged past 6 months.
                                • RJARRRPCGP
                                  • Jul 2004
                                  • 6304
                                  I know that in the Americas, with "split-phase", probably a bad neutral connection. Not so sure for Europe.
                                  ASRock B550 PG Velocita
                                  Ryzen 9 "Vermeer" 5900X
                                  Arc A770 16 GB
                                  eVGA Supernova G3 750W
                                  Alienware AW3423DWF OLED
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8701
                                    you could try to monitor your line voltage and see if it's out of range. It could go a long way to figure out what's wrong.
                                    • sew333
                                      • Apr 2017
                                      • 81
                                      • Poland
                                      I have a question. About that propably halogen bulb. Is this possible that psu in pc tripped breakers,and not halogen bulb?
                                      BUT PSU OF MONITOR IS NOT THE SAME OF PC?
                                      So thats why i am asking about pc psu now.
                                      If 3 months ago monitor psu blowed , then maybe 2 weeks ago it was not bulb but psu of pc? But like i said pc working. Also psu in monitor have not the same safery features like psu in pc?
                                      Please answer. I am not cooled down <Lol>
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8701
                                        depends on the design. Likely the widerange PSUs are a bit more tolerant of varying voltages though it's impossible to tell what you have.
                                        It's not likely that a PC PSU will trip breakers without itself being damaged. So if it's still working, likely was not the trip cause, unless the breaker was not capable withstanding the initial plug in inrush or you were already drawing current near its limit.
                                        • repair-it
                                          TOSHIBA DLP 52HM95 How to reset timer module on bulb
                                          by repair-it
                                          I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                                          Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                                          10-11-2023, 07:18 PM
                                        • ezenia
                                          LUMIMAN Smart Bulb IC ID?
                                          by ezenia
                                          I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                                          In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                                          04-28-2025, 05:56 PM
                                        • sew333
                                          Can halogen bulb flicker?
                                          by sew333
                                          Hi. Yesterday i was in bathroom. And halogen bulb flicker for 1 second. Is this possible and why it flicker? Thx
                                          Bulb looking something like that:
                                          06-09-2022, 09:25 AM
                                        • XxMicroSoldering
                                          ASUS Rog Strix G17-712LV Laptop Liquid damaged
                                          by XxMicroSoldering
                                          Hello Guys
                                          I have a ASUS Rog strix laptop that I bought recently to fix and the previous owner spilled water on it . He brought it into a repair shop for them to check it out and instead of fixing it they damaged the battery connector of the laptop ! Other than that they damaged damaged nothing . But since the liquid damage the laptop only turns on and the keyboard lights up and then immediately turns off. I really want to repair this laptop and I also have experience in repairing phones etc and laptops and a bit of soldering but the diagnosing part is where I need help with and...
                                          10-17-2024, 10:45 AM
                                        • sew333
                                          Coincidence or something fishy with Seasonic psu's?
                                          by sew333
                                          Hello.
                                          My previous pc ,i bought in 1 january 2019,here are parts.
                                          9900K
                                          Asus Prime Z390-A
                                          2x16 GSKILL
                                          Corsair 750RmX
                                          2080 Ti Waterforce
                                          monitor Acer Predator
                                          There was not issues in house with tripping breaker/s.
                                          In november 2019 i bought only new monitor Aorus AD27QD and new psu Seasonic 850W Ultra Platinum.
                                          So in november 2019 i bought new monitor Aorus AD27QD and new psu Seasonic 850W Ultra Platinum. After 3,5 months , in february 2020 ,something tripped breaker in night and that...
                                          09-21-2020, 03:52 PM
