Honeywell quartz clock component
+ More Options
Posts
    • 31170
    Re: Honeywell quartz clock component
    the battery *can* be short circuit because it must be connected to the clock via a resistor and maybe a bypass-diode to limit the charge current.
    • sofTest
      • Aug 2008
      • 361
      #42
      The battery is not shorted, nor leaking. I've read that shorting only happened in battery packs, due to reversal, not in single cells? My battery is probably bad due to cadmium crystal build up. (Yes, I've been reading up on batteries and charging, also.)
      Yes, I found that the clock can run without the battery. But since the the clock normally is only monitored once a week, I find it best to have a backup battery in, in case of power outages.
      Info 1 -> Google translation
      Info 2 -> Google translation
      Anyway, due to the unknown handling of charging (overcharging) in the clock, I find it most safe to replace with a NiCd. I found a source for a 110 mAh NiCD, but it's not stocked, so there is some delivery time.
      I'm enclosing a new picture of the board, with annotations.
      Thanks for now. I'll report back when I know more.
      Be a mensch
        • 31170
        nicad's can short, i had a slotmachine that wouldnt start because the nicad was dragging the power down.
        • Pyr0Beast
          • Feb 2009
          • 406
          #44
          Yup. They can short. Zap it and it should work.
          • Radio Fox
            • Jan 2010
            • 281
            The circuit is a very basic design. The zener diode, electrolytic smoothing capacitor, and battery are all connected in parallel across the supply pins of the IC. If the battery was a dead short, the clock would stop.
            It seems to me that the battery is acting like a resistor, drawing current & pulling down the supply volts. This could be causing the IC to operate erratically, perhaps causing it to "miss a beat" every now & again, slowing the clock down.
            Originally posted by sofTest
            ...Anyway, due to the unknown handling of charging (overcharging) in the clock, I find it most safe to replace with a NiCd. I found a source for a 110 mAh NiCD, but it's not stocked, so there is some delivery time...
            I'm surprised you found one. I thought they were extinct.
            ________________________________________________
            Invisible airwaves crackle with life
            Bright antennae bristle with the energy
            • Pyr0Beast
              • Feb 2009
              • 406
              #46
              I would agree with that.
              • 999999999
                • Sep 2006
                • 774
                IMO, there is one most likely fault, the trimmer capacitor. It is unlikely the crystal itself would drift this much, at so high a rate.
                You might try turning that capacitor through it's full range several times, but first marking what position it had and counting turns so you can return it to the original position, and do some comparitive testing for how much changing it's position one direction or the other changes the time rate of change.
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  #48
                  i mentioned the glue being the problem earlier.
                  i would have replaced the trimmer earlier in the game.set it by using a counter and adjusting to 32.768 khz.
                  • Radio Fox
                    • Jan 2010
                    • 281
                    I suggested turning the trimmer in post #8, but that was before sofTest said how slow the clock was running. It is running at 1/3 of normal. There is no way a trimmer will pull a Xtal to a third of it's frequency. I think a very rough rule of thumb is 1KHz per MHz of Xtal frequency.
                    btw...why do you need to count the turns on the trimmer?
                    • Radio Fox
                      • Jan 2010
                      • 281
                      You've even less chance of pulling a 4194.304kHz Xtal down to 32.768kHz.
                      • 999999999
                        • Sep 2006
                        • 774
                        ^ but, if the battery is acting as a resistor and it's now out of circuit, we need to know what that result is.
                        I don't fault sofTest for it, because we all have only a finite amount of time to spend, but ultimately proposed tests, data gathering, parts swaps if all else fails, might help.
                        Then again, what is the point when you can buy a new clock mechanism for dirt cheap that is more accurate than something decades old? If it were a valuable vintage antique that the owner sought to sell as-was, then I see the advantage of keeping it all original.
                          • 31170
                          isnt this fixed yet?
                          if i had it i would draw a schematic.
                          • Radio Fox
                            • Jan 2010
                            • 281
                            I get the impression that it's a bit of a long job putting it all back together. Perhaps that's why sofTest wants to wait until it's all back to how he wants it, before refitting the clock.
                            I assume it's some kind of central heating timer (although he hasn't actually said what it's used in). In an earlier post sofTest said a replacement timer would cost over 200 US dollars!!!
                            • Radio Fox
                              • Jan 2010
                              • 281
                              He must still be waiting for the replacement NiCd.
                              I drew a schematic from the photos sofTest posted.
                              • kc8adu
                                • Nov 2003
                                • 8832
                                • U.S.A!
                                #55
                                guess i didnt see that.
                                so used to seeing 32.768.
                                btw the trimmer is a single turn.the rock COULD be bad and be that far off....
                                had a 20m rock in a yaesu 101 that was off by a mile.surprised it even ran.
                                • sofTest
                                  • Aug 2008
                                  • 361
                                  #56
                                  Hi.
                                  I'm still waiting for the battery. The shop in Norway I first ordered it from, changed delivery time from 2-14 days to 2-30 days two days after I ordered. So I cancelled, and re-ordered from Tower Hobbies in the US. It was confirmed shipped last Friday, so it shouldn't be long before I receive it.
                                  As for the repair, according to the Germans who has experience with this clock, the usual fault is the battery, and sometimes the electrolytes. As the electrolytes are out already, I will replace them also. I would have liked to replace the trimmer also, but as I don't have any equipment to calibrate a new one (beside a time consuming observe and adjust), I will leave the old one in, unless the battery and electrolytes replacements fail. I have tried turning the trimmer, and the action is smooth, and no sticking, if that is any indication.
                                  Yes, the clock is part of a old building heating system, regulating daytime/night time/weekend temperature. The clock is sold used for €60-80 on eBay, and I've found new ones from around USD 200 and up. There are of course more modern and accurate systems, but that would involve replacing more than the clock. For its time, the Honeywell Aquatrol W964F system was quite advanced, and still does the job, when it keep the time. A small drift in time isn't a problem either.
                                  Thanks for still looking in.
                                  Be a mensch
                                  • Pyr0Beast
                                    • Feb 2009
                                    • 406
                                    #57
                                    Trimming resistors do fail. But I'm not sure if trimming capacitors do the same as well since there isn't any direct electrical contact.
                                      • 31170
                                      variable capacitors get contaminated or tarnished and it creates a resistive path and effects overall capacitance.
                                      • Radio Fox
                                        • Jan 2010
                                        • 281
                                        ...the rock COULD be bad and be that far off....
                                        Out of interest, did that Xtal run high or low? Just wondering whether the Xtal may have cracked causing it to run high.
                                        • kc8adu
                                          • Nov 2003
                                          • 8832
                                          • U.S.A!
                                          #60
                                          way high.
                                          • shelby5041
                                            clock radio / radio lifespan?
                                            by shelby5041
                                            hi
                                            ive got a modern digital clock radio approx 15yrs old
                                            my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                                            since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                                            the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                                            it uses very little power just a few watts i would imagine that may have something...
                                            09-14-2024, 03:30 AM
                                          • pc_okay
                                            Crystal compatibility 32khz ASUS UX325 NB255_PCB_MB_V4
                                            by pc_okay
                                            Hello friends,
                                            Its been a while, i wish you an happy new year 2025 !
                                            I have this laptop doesn't start, power light up a second when pluging USB-C charger.
                                            Laptop take 0.11A.
                                            All signals and voltages before SLP_S4# are OK but no SLP_S4# , S3...
                                            I get no oscilation on XTAL 32.768 KHZ
                                            Battery is not charging but charging led is here.
                                            PCH heat at 30° approximatively. (with no heatsink)
                                            I think this crystal might be dead, i have only boardview giving me this: XTAL 32.768KHZ 12.5PF/20PPM.
                                            It's a 2 pins Crystal.
                                            01-13-2025, 09:26 AM
                                          • UserXP
                                            Vintage SONY Digital Clock Radio ICF-C12W no audio
                                            by UserXP
                                            Dear all,
                                            I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                                            i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                                            My question is, do you know of this brand of capacitors and how bad are...
                                            07-21-2025, 08:35 AM
                                          • TinkerTron
                                            Schematic vs. Reality: Where Are the Resistors on My Sharp Clock Radio? Model FY-70CH
                                            by TinkerTron
                                            Hey everyone,
                                            I'm currently working on a mid-70s Sharp Electronic Digital Clock Radio, Model FY-70CH. I found the service manual online, printed it out, and have been studying it for a while. My main reasons for tackling this are: (1) I want to learn electronics and figured I'd start with something I had on hand, and (2) I want to fix its issues. Right now, the radio sounds awful, has about 5V DC at the speaker terminals, and the alarm time setting doesn't work. But I'm not asking how to fix these problems.
                                            Instead, here's what's been bugging me so far:
                                            The schematic...
                                            03-06-2025, 02:03 PM
                                          • Fontana
                                            71R-H14BW6-T830, clock stops when shutdown
                                            by Fontana
                                            Hi!
                                            Funny problem. I have a board, model 71r-h14bw6-t830, it's a shuttle board used commonly on a lot of cheap laptops/AIOs.
                                            The clock (RTC) is not working when the machine is turned off. Doesn't matter if it is connected to dc power or not. When the PC is powered on, the clock works fine.
                                            I tried replacing Y6 and Y7 (picture below), but it doesn't seem to be an oscillator problem.
                                            I don't have the exact schematic for this board, but I'll provide one that is similar (a variation of the same board).
                                            Any suggestions?
                                            OBS: when the pc is off,...
                                            09-28-2022, 09:57 AM
