Is all solder wick created equal?
+ More Options
Posts
  • aliasdck
    • Sep 2009
    • 100
    I have a project on hand that requires the use of solder wick. I don't find myself using solder wick much... usually use solder sucker when it is safe to do so.
    I have some solder wick I purchased from radioshack years ago and I was trying to use it today. Noticed this solder wick isn't really doing the trick... the solder doesn't seem attracted to it much.
    I always assumed all solder wick was created equal but I'm beginning to wonder now. I can remember years ago using some solder wick and I recall it working much better. I'm figuring the stuff I bought at radioshack is probably crap.
    • 30978
    Re: Is all solder wick created equal?
    no, each brand uses different flux.
    some work a lot better than others.
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      You get what you pay for
      I made the mistake of buying Dick Smith branded solder wick - Dick Smith being a large Australian electronics retail chain
      Dick Smith solder wick is absolute garbage - just doesn't do the job, and also leaves residue which has to be cleaned off
      Then I bit the bullet and paid around 50% more to get Goot branded Japanese solder wick
      What a difference - the solder just flows into the Goot wick, and leaves almost no residue
      better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
      • Krankshaft
        • Jan 2007
        • 2328
        Go for Techspray wick their flux is great.
        Radioshack wick is complete crap I remember that the wick was debraiding when I used it. Not to mention the copper strands seemed very coarse. I have no idea what type of flux was in it either. They recently switched OEMs for the wick the old stuff was better.
        Not as good as Techspray but hills over their current OEMs crap.
        Check my post here:
        https://www.badcaps.net/forum/showthread.php?t=8596
        I put a link there on a good deal on 50 feet of the Techspray braid about 19 bucks shipped. A lifetime supply for infrequent use.
        I bought a few rolls of it and love it.
        50 feet seems to last me about 1 year to a year and a half. I'm the exact opposite I use braid for everything and my solder sucker rarely.
          • 30978
          you should try to keep it in an airtight container like a tobacco tin,
          the flux will absorb moisture from the air over time & not be so good.
          • Krankshaft
            • Jan 2007
            • 2328
            These come in vacuum packed bags from the factory. Their packages are pretty tight fitting as well.
            • ss627
              Super Member
              • Mar 2008
              • 52
              I have yet to use a 'good enough for me' solder wick. I prefer various sized suckers, some extra solder and some flux for repairs.
              After buying MULTIPLE wicks from ebay,radioshack,digikey and mouser, I've given up on these stupid things. With newer products using leadfree solder, all they did for me is soak up a pathetic amount of solder and fubar the plated holes.
              • Pyr0Beast
                • Feb 2009
                • 406
                Leadfree solder eats a bit of copper the moment it has contact with. Removing of the pads might be also due to high temperature of soldering iron.
                Personally, I use wick made from wires/cables. Dip it into flux for a bit and it is perfect for the job.
                • Krankshaft
                  • Jan 2007
                  • 2328
                  Well there is a technique to using wick it's just like soldering.
                  It did frustrate me at first but once I learned to work with it I never went back.
                  When working with lead free I tend to wet the joint with some leaded solder to help suck up the stuff.
                  • larrymoencurly
                    • Oct 2004
                    • 960
                    Bad wick can be made to work better by coating it with rosin.
                    • aliasdck
                      • Sep 2009
                      • 100
                      Thanks for the tips guys.
                      I'll look into getting some better wick then.
                      My desoldering skills probably could use a little practice - with wick that is - as I haven't done it in years. Been using the solder sucker ALOT and have gotten very good/comfortable at it... but with this current project I definetly would say wick is the way to go.
                      I'm trying to solder a smd component with a lot of tiny pins which are very very close together... can't see any way to solder it in place other than to solder all the pins as best I can and then clean up the pins that will get inadvertently bridged together with some wick.
                        • 30978
                        there are tricks to that,
                        one is the "gravity-flow" trick.
                        you cover the pcb with masking tape to protect it - other that the chip.
                        then hold or stand the board on it's edge and solder the vertical sides from top to bottom very fast - gravity will pull the excess solder from each pin to the one under it tell the last few.
                        then a big blob will fall off - why you taped it up!
                        sometimes that's 100%, sometimes the last few pins are still bridged.
                        • NxB
                          • Feb 2009
                          • 1595
                          Old wick probably oxidized too. The radio shack stuff works fine for me. But.. I always dip it in flux first.
                          • Pyr0Beast
                            • Feb 2009
                            • 406
                            I have it coated with flux. Once it oxidizes the ordinary flux does not work anymore. You would have to use a stronger (Acid based) one.
                            That's why I make fresh from the wire
                            • hardwareguy
                              • Jun 2006
                              • 405
                              As others have stated...NO!
                              Radio Shack braid is OK for a month after its opened then it goes bad and its messy. I use TechSpray No Clean wick and love it. (and its made in Texas!)
                              • ktmmotocross
                                recommend good solder wick on aliexpress
                                by ktmmotocross
                                I get som bad cheap wick that im furious with so i need to order wick that suck solder like it should. best on aliexpress...
                                02-08-2024, 12:48 AM
                              • acedogblast
                                by acedogblast
                                11-02-2024, 05:13 PM
                              • corrize
                                Best way to solder LVDS connector for beginner (and qfn) ?
                                by corrize
                                Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
                                I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
                                I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
                                See the test :
                                https://youtu.be/bNAzC-EvqHs?t=1767
                                With hot air from bellow the board, that's...
                                03-09-2023, 02:57 AM
                              • myth77
                                UV solder mask - high temp resistent, recomendation?
                                by myth77
                                Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
                                Is there any solder mask...
                                03-28-2022, 04:04 AM
                              • petemanuk
                                BGA solder balls not connecting - help pls
                                by petemanuk
                                So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
                                I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
                                I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
                                11-16-2022, 05:21 AM
