what did i do wrong?
  • ivanew
    • Sep 2020
    • 9
    i tried to make three signal/radio frequency/radiation detector (please tell me if there are any differences between the three since i dont really know what i am doing), but none of them worked. what did i do wrong? is it me? is it the diode? the capacitor? the transistor? the coil? all of the above (i hope not)?
    https://youtu.be/5hu_6P1CMxI
    in this one, i read in some of the comments that it is fake or does my coil need to be a 24 awg?
    https://youtu.be/vHVmJ5lD9jc
    in this one, i suspect that my diode was not what it was meant to be which is why i made this thread:
    https://www.badcaps.net/forum/showthread.php?t=88828
    https://youtu.be/dTmlQKvVVEk
    in this one, my buzzer rings the moment i stick the red wire into the middle pin. i suspect that my transistor & diode are both not as what they were advertised, if so then can someone please share & paste a link of a trusted seller in here on where i can buy legit transistors & diodes that i need for all these?
    i will truly appreciate any sort of advice & or help that i could possibly get in here.
    thank you very much
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8706
    Re: what did i do wrong?
    The capacitor just mucks with the low frequency gain of the circuit, but does not do anything about the high frequency. The antenna design is the sole contributor to the RF gain as there's no RF amplifiers.
    1. The gauge of the wire does matter to an extent, especially the higher frequencies.
    2. The sensitivity of these things are very low as demonstrated. Inverse square law...
    3. Mobile phones are all sorts of different bands, you'll need to tailor your antenna to your specific band.
    For proof of concept doing the GMRS/FRS one would probably be good to see if the idea works as that's on a fixed frequency. The ISM 2.4GHz one if you have a microwave oven nearby could work, remember it still needs to be quite close. If you got your ham license you're welcome to try the ham bands of course.
    All in all, do not expect high sensitivity with any of these, even the one with the IC.
    • ivanew
      • Sep 2020
      • 9
      do you have any suggestions for a legitimate signal/rf/radiation detector? i mean, an already built one that i can buy? maybe i can start from there and try to strip it & maybe figure out which is which
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8706
        You need to specify which band for starters.
        Getting a spectrum analyzer is the end all, but I'm pretty sure you don't want to strip it and analyze such as I'm not sure what you can do to duplicate it without actually duplicating its complexity... and you still may need to get one that is sensitive in the band you want.
        • ivanew
          • Sep 2020
          • 9
          first off, thank you so much for replying, i really appreciate it. any other alternatives aside from a spectrum analyzer? something handheld, something similar that can be used for counter surveillance? i sincerely apologize for taking some of your precious time. again, thank you so much for helping out
            • 31283
            what are you actually trying to do - the end goal?
            because if your hunting for transmitters, you can use a $15 SDR radio dongle with a USB-OTG adapter and an android phone/tablet to scan a huge range.
            • ivanew
              • Sep 2020
              • 9
              my end goal will be the following:
              1. try to get some legitimate 1ss86 diodes
              2. try to detect/locate the signals of pet microchips which are:125 kHz, 128 kHz, 134.2 kHz
              3. at least try to detect the signal/frequency/bandwidth of any cellphone which from what i read are the following:
              https://en.m.wikipedia.org/wiki/GSM_frequency_bands
              https://en.m.wikipedia.org/wiki/UMTS_frequency_bands
              https://en.m.wikipedia.org/wiki/LTE_frequency_bands
              https://en.m.wikipedia.org/wiki/5G_NR_frequency_bands
              4. detect microwave signals/frequency
              https://en.m.wikipedia.org/wiki/Microwave
              5. or better yet, if possible? all of the above
              but how? & a spectrum analyzer is really expensive for me, any other alternatives? or tutorials on how i can build things that can detect the signals/frequencies of those that were mentioned?
              • R_J
                • Jun 2012
                • 9623
                I use this adafruit 1497: Digikey 1528-1524-ND. and sdr-sharp software on a PC, there is also other sdr software that works well.
                • ivanew
                  • Sep 2020
                  • 9
                  thank you. i will give it a try, but do you have any suggestion for something hand held? something that can be used for counter surveillance? e.g. sweeping hidden cameras, etc?
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8706
                    As much paranoia is around, this won't do much for a wired camera...
                      • 31283
                      not happening.
                      1: maybe
                      2: no chance, those rfid chips only transmit in short bursts when you put a coil over them and energise them with an ac magnetic field.
                      you can get modules from china for the task though.
                      3: your talking about very high frequency's - 2.4>5GHz or much higher for 5g
                      • ivanew
                        • Sep 2020
                        • 9
                        yes, but wired cameras are way more easier to spot with the naked eye than wireless ones, unless there are now wired cams that are as deceitful as its wireless counterparts.
                        may i please have links? thank you so much
                          • 31283
                          https://www.aliexpress.com/wholesale...xt=rfid+module
                          • ivanew
                            • Sep 2020
                            • 9
                            i appreciate the help, but i watched some tutorials on youtube & if i am not mistaken these things are for building badges/id's to allow entry of a personnel, unless there are other tutorials out there that i missed then i would love to see them, either that or i am much more in deeper trouble for being a total beginner in regards with these things so if there are links of these rf modules sweeping signals/frequencies/radiation then i would most definitely be more grateful than i already am. thank you all so much for trying to help me, i am sincerely hoping that with the continuous help of everyone here i will finally find a solution regarding this silly problem of mine.
                            as i was browsing i found this:
                            https://youtu.be/Id68OFLSuzg
                            as you all already maybe aware i am a complete total beginner regarding these matter so i only tried simpler tutorial guides, if there are anything that is more simple than this complex one (for me) that is almost close to the first 3 vids that i posted then if there are any more words of gratitude on my very limited vocabulary then i will use it, but really - thank you guys so much for the help, they truly mean a lot.
                              • 31283
                              the modules dont sweep, they function on specific frequency's
                              but you first need to understand the chips.
                              they are just tiny memory chips with a capacitor and transciever combined.
                              the field coil on the module charges the capacitor and allows you to read or write to the memory chip - that's all they are.
                              now what you store on them is up to you, your AMIBO data(nintendo characters), your dog's id code, or your credit for a cashcard. and also car immobilisers.
                              in the case of cash or travel passes they use more expensive chips that need a password to write to them and use encryption.(MYFARE) but the principle is the same.
                              car immobilisers are differernt, they transmit a rolling code based on a secret key - but that's not an issue.
                              • asr
                                Finding replacement diode iPad Pro 3rd gen A1701
                                by asr
                                Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
                                Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
                                07-09-2024, 06:24 PM
                              • unimatrix93
                                TV backlight zener diode
                                by unimatrix93
                                Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                                So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                                Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                                The led strips has 9 6V leds.
                                02-10-2025, 12:13 PM
                              • PITERPENY
                                Macbook A1989, 820-00850, won't boot. 20V, 0A.
                                by PITERPENY
                                Today I have a MacBook A1989 at work 820-00850. When assembled, the laptop switches to 20 volts but the consumption is 0.00 ampere. if the motherboard is on the table then the consumption of all ports is 5 volts and0.35 amperes and does not go to 20 volts only if you assemble a MacBook.
                                Here are some measurements, maybe someone can tell what the problem is.
                                The initial problem was a burnt out induction coil L8504 (replaced).
                                When connected to another MacBook, it constantly hangs in dfu and cannot install updates, something is wrong.
                                here are some measurementsmotherboard...
                                01-16-2024, 02:19 PM
                              • Baste
                                MBR3045CT and SR3045LCT Schottky diode testing help.
                                by Baste
                                Hello experts,
                                Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
                                Aneng ST182 Meter.
                                Diode mode.
                                MBR3045CT:
                                Diode mode
                                Pin 2-1 - 0.150v
                                Pin 2-3 - 0.150v ...
                                10-21-2025, 06:14 AM
                              • NicRac
                                monowheel repair,Is the diode the problem?
                                by NicRac
                                Hello everybody☺️ I am glad to be here and looking forward to a good discussion.
                                First of all, I am new here. Therefore I will shortly introduce myself.
                                I am Nico and currently I study Physics.
                                In my freetime I like to build and repair stuff. Especially big battery's.
                                A few years ago I got myself an electric unicycle, monowheel or however you call that.
                                The battery bms was broken so I replaced and resolder that. Nothing big.
                                I used this thing for some years and had a lot of fun. Unfortunately I used it last time in heavy rain. Usually everything...
                                07-26-2024, 06:13 AM
