Noob ohm low question
  • prow
    • Jul 2020
    • 14
    • croatia
    I have a very basic question...regarding ohm low on motherboards. So, lets say i have laptop and 19,2v power adapter and on AC main net on the board i have 143 Kohm resistence to the ground. When i plug adapter i can check with multimeter and i have 19,2 V on ac main net. If i am not calculating something wrong i should have 0,13 mAmps ? But that doesnt seem right? Or?
    Thx
  • PeteS in CA
    • Aug 2005
    • 3583
    • USA, Unsure of Planet
    Re: Noob ohm low question
    Many ICs draw little current unless powered with the proper voltage. Your ohm meter probably sources ~2V, which is way too low to cause active operation of a circuit that designed to be powered with 18V-20V. Further, many ICs are a mixed resistive and constant-current load. That is too complex for an ohm meter to measure accurately.
    If you really need to know how much input current your MB draws, either put a .01-.1 ohm resistor in the "+" lead to the MB, measure the voltage drop (be sure the resistor power rating is high enough), and do the calculation or get a clamp-on current probe (meter or oscilloscope).
    PeteS in CA
    • prow
      • Jul 2020
      • 14
      • croatia
      thx for answer...but probably i was not clear...What i was saying is if i have 19.2 V and 143 Kohm resistence i should have somewhere near 0,13 mAmps according to the ohm low? A=V/R = 19,2 V/143 kOhm ? But that doesnt seem right?
      Or i am figured something wrong?
        The 143K Ohms you read is not pure resistive load, the circuits you are measuring the resistance contain many active devices, since your meter is only putting out very low Voltage as explained by Pete so not all the devices may be turned on, but when you applied 19V to the circuits, then lots of devices will be turned on and draw more current.
        • prow
          • Jul 2020
          • 14
          • croatia
          So, you are saying when checking with multimeter (no power adapter) the resistence is 143 kOhm, but when i apply 19V adapter and because there are many active devices that resistence will not be 143 kOhm but much lower?
            Yes.
            If you want to learn you can do the experiment by building simple transistor circuit such as one in figure 4.37, then use variable power supply that can show low current display and Voltage. You will apply about 3V to the circuit and observe the current flow, then you turn up the Voltage to 18V you will observe that the current draw will go up, so if you use Ohms law you will see that the load resistance at 3V is higher than load resistance at 18V.
            https://cdn.badcaps-static.com/pdfs/...83431ecd0b.pdf
            • prow
              • Jul 2020
              • 14
              • croatia
              Thank you...one more question...is it safe to measure resistence with multimeter while power adapter connected?
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                No, you will risk destroying the multi meter.
                • prow
                  • Jul 2020
                  • 14
                  • croatia
                  I understand. Is there any way i can measure resistance while laptop is on? without risking destroying equipment...
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    Not directly, but you can do it like Pete described above:
                    • prow
                      • Jul 2020
                      • 14
                      • croatia
                      I think i understand...if i check voltage on "current sense resistor" of lets say 0.05 ohm before and after...i can calculate the current?
                      hmm but how? lets say the difference is 0.2 V?
                      • Per Hansson
                        • Jul 2005
                        • 5895
                        • Sweden
                        I = V/R
                        0.2V / 0.05R = 4A
                        http://www.measurementest.com/2010/0...ing-shunt.html
                        • prow
                          • Jul 2020
                          • 14
                          • croatia
                          All is clear now thank you all very much!
                          • prow
                            • Jul 2020
                            • 14
                            • croatia
                            Update.... so i checked on the motherboard and i have 0.01 ohm (10m Ohm) current sense resistor and i have drop in voltage across ressistor by 0.01 V. So if i use ohm calculator the current is 1 A. Is this correct?
                              That is correct, so that 19V power supply is seeing about 19 Ohms load.
                              • Per Hansson
                                • Jul 2005
                                • 5895
                                • Sweden
                                Yes, but do keep in mind the accuracy of your multi meter.
                                If the drop is just 10mV but the multi meter does not have a dedicated millivolt range then the measurement error can be very significant.
                                • darkness77
                                  lenovo y520 confused
                                  by darkness77
                                  First i am noob
                                  Second, i received this laptop, it was powering on but no display. I found that +1.2 v is missing. Then i found that +1.2V_S5 is shorted to ground. I removed and replaced RT8231AGQW and short was gone.
                                  But...on PR1418 i have resistence 85 kohm and that resistor is 100 kohm. So i replaced it but again 85 kohm. Then i removed resistor and found out that resistence between those two lines (GND and +1.2V_VID) is more then 100 kohm, putting multimeter probes both way...but with resistor is 85 kohm??? how is that possible? i checked 5 times and resistors are...
                                  11-09-2021, 02:54 AM
                                • Junkrepair
                                  Calculating ESR from tan delta -- tan delta's dependence on capacitance
                                  by Junkrepair
                                  I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
                                  I found this nice little description of the conversion:
                                  Calculating capacitor ESR from Tan(delta)
                                  https://forum.digikey.com/t/calculat...-from-tan/2633
                                  It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
                                  06-12-2023, 02:45 PM
                                • Guest
                                  A noob needs help for Apple Macbook Air M1 2020 A2337 - logic board short circuit
                                  by Guest
                                  Hello all!
                                  Recently I've got a broken Macbook Air M1 2020 A2337 of eBay with a broken screen and not turning on issue.
                                  After some tinkering I've found C5201 capacitor to be blown. This is where I hit a wall since I am a total noob in this area and have no idea what else to look for. C5201 is on one line with 3 more capacitors which visually seem ok, but beep on continuity mode and also both sides of all capacitors beep when tested with ground from the board. This to me sounds like a short, but I am not able to find what component is before the capacitors to test it....
                                  09-26-2024, 03:31 AM
                                • lapfix
                                  HP OMEN NO power no light
                                  by lapfix
                                  HP OMEN : DAG35DMBAD0
                                  NO power ,no short ,no corrusion
                                  Consumption : when charger plg in = 0.004 amp
                                  Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
                                  when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
                                  No light at power button led
                                  All coils resistances :
                                  Pl 2001 =3v measured with kohm.
                                  pl 2004 = 5v measured with kohm
                                  pl 6001 = 49.7ohm
                                  pl 4012 = vccsa = 24.4 ohm
                                  pl 3001 =...
                                  11-03-2025, 07:48 AM
                                • Doesronnieevenlift
                                  Help a noob! Wson8 Pogo/Needle Adapters to read/Write
                                  by Doesronnieevenlift
                                  I had recently tried to reflash the bios on a dell latittude that has a Wson8 Chip however to no avail.
                                  My question is, Has anyone had much success using the Pogo/Needle adapters to read and write bios without removing the chip from the main board?
                                  I seem to struggling with the solder process wofh my reflow station and currently have 4 machines waiting for a bios mod/reflash.
                                  For context I have just ordered a EZP2019 SPI flash so this is what I would be using alongside the Pogo Adapter.
                                  Apologies if this is the wrong subcategory....
                                  06-22-2025, 04:51 AM
