I'm trying to repair my ATX PSU and I'm sort of trying to follow the flow of current to see where it goes wrong. I was doing fine until came across with two transformers. I'm pretty sure the big one is supposed to output 12V and the smaller 5V. So I need to measure voltages of the primary and secondary parts of both to see if there's something wrong.
After some research, found two datasheets that seem to correspond to my transformers (not sure however):
https://pdf1.alldatasheet.com/datash...06-ERL35R.html
https://datasheetspdf.com/pdf-file/1204705/FPE/EE19/1
Despite having basic electronics knowledge, my experience is limited. I've only seen transformers with three or two pins each side. According to the datasheets, bigger has 14 pins and smaller has 10 pins. I'm confused. Can someone explain what I'm looking at?
