Shredder very slow to start
  • jinu_j
    • Feb 2016
    • 90
    • India
    Hi Folks
    I have a shredder, the problem is after putting the paper it takes about a minute for the motor to start and shred.
    I trouble shooted a lot and figured out that the problem is the voltage at the coil end of the relay is taking time to reach 24V. It rises very gradually and as soon as it reaches 20V the motor starts.
    The question is what component could be causing this ? Could caps be the problem. Please see PCB images below
  • petehall347
    • Jan 2015
    • 4431
    • United Kingdom
    Re: Shredder very slow to start
    try new solder on those bad joints .
    if that doesn't fix it then you may as well change all 3 electrolytic capacitors .
    if that hasn't worked change relay driver transistor
    • R_J
      • 9580
      Also check that the gears etc. are not full of paper dust and causing things not to operate, Check the motor to make sure it is turning freely and that the bearings are not causing the fault.
      • jinu_j
        • Feb 2016
        • 90
        • India
        Thanks. This is a new shredder and not used much so no issue with gears. I have ordered the replacement CAPS. will replace those and update once done. Thanks folks
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Other possibility is that one of the resistors went open or one of the tracks broke. Some of the tracks on the bottom looks corroded or something weird is going on with them ... could they be to blame?
            I see some crappy solder joints too.
            • jinu_j
              • Feb 2016
              • 90
              • India
              Hi Folks
              I have replaced the caps with new ones. and resoldered some of the joints showing poor solder. But still the same problem, infact replacing the capacitors seems to make it worse. Now the voltage across the coil of the relay is stuck at 10V. i believe it has to reach 24 volts for the relay to trigger. What else could be the problem ?
              I looked at the transistor. All that written on it is A44 B331. Cant find the data sheet for this transistor. Is there an equivalent you are aware off.
              Some voltages i have recorded
              - Voltage at the receiver end of the IR recerive when path is blocked : 2.5V
              - Voltage at Base of Transistor (pin 2) : 1 V
              - Voltage between C and E (Pin 1 and 3) : 30V
              - Voltage across coil of relay : 8v (This should be around 24) but this is gradually very gradually increasing and climbing upwards
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                I'd also make sure the paper sensor is actually working properly too...
                • jinu_j
                  • Feb 2016
                  • 90
                  • India
                  Paper sensor is working fine. Without the paper blocking the path between the sensors i see volts 0.5v and when i put the paper the voltage rises to 2.5V
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    what's the reference point of base of transistor when you say 1V ?
                    • petehall347
                      • Jan 2015
                      • 4431
                      • United Kingdom
                      transistor looks duff . try shorting emitter to collector and see if relay clicks in .
                      • jinu_j
                        • Feb 2016
                        • 90
                        • India
                        The problem is i cant find the specs on the Transistor. It is just numbered as A44 B331.
                        I think its ground. Please see image below. The voltages measured are:
                        - Voltage at the receiver end of the IR receiver when path between IR Transmitter and receiver is blocked (Points C and D : 2.5V
                        - Voltage at Base of Transistor (pin 2) Points C and H : 1 V
                        - Voltage between C and E (Pin 1 and 3)Points G and I : 30V
                        - Voltage across coil of relay Points E and F : 8v (This should be around 24) but this is gradually very gradually increasing and climbing upwards
                        - Points A and B are points to the IR Tranmitter - 1V
                        - The transistor is at points G, H, I
                        • jinu_j
                          • Feb 2016
                          • 90
                          • India
                          Actually it did. When i shorted the Emitter and collector the Shredder started working. Thanks a lot.
                          So can i assume the transistor is bad and needs replacement. If so the problem is i cant find the replacement of a transistor with the name A44 B331 is there an equivalent.
                          • R_J
                            • 9580
                            This could be it. Either the transistor is bad OR the base is not being turned on enough.
                            • jinu_j
                              • Feb 2016
                              • 90
                              • India
                              Is there anyway i can test for the second issue (base not being turned on enough) ?
                              • R_J
                                • 9580
                                Check the voltage between emitter and base. It should be around 0.7 volts or a bit more, also what is the voltage across C2
                                • jinu_j
                                  • Feb 2016
                                  • 90
                                  • India
                                  The voltage between the Emitter and base is 0.45V
                                  • R_J
                                    • 9580
                                    That seems too low to turn on the transistor, check the voltage across C2 (or R6) also check R7 10k, it could be open
                                    Check that the trace that goes from R9 to D5 to R6 to ZD1 is not open, this is the ground or common point
                                    C1+ seems to be the low voltage supply (5V?) It then goes through R5, through D6 to C2+
                                    • jinu_j
                                      • Feb 2016
                                      • 90
                                      • India
                                      Voltage across C2 is 1.8V. R7 is 10k and is not open. That would indicate a a problem with the diode D5? If I check the voltage between points after R7 and before D5 it about 1V, but i move it to after D5, it drops to 0.45V
                                      • R_J
                                        • 9580
                                        D5 has nothing to do with the base circuit, it connects the emitter of Q1 to ground.
                                        Check the voltage across C1. C1 negative is the ground of this circuit.
                                        There are 2 wires next to the relay (Violet and Grey) where do they connect? The violet wire connects to ground, and the grey wire seems to control the voltage going to the Q1 base
                                        • juergenb
                                          Nescafe Aeroccino, still fails with new Motor (red flashes only once)
                                          by juergenb
                                          i am asking for some Help.
                                          I have one of these Nescafe Aeroccino (Milk Frother) things with a bad motor.
                                          The Motor didn“t start anymore and internet is full of users just swapping the motor for a Mabuchi RF-500TB-12560.
                                          So i got a few of these from Banggood.
                                          I swapped the motor and now i have a new fault condition.
                                          In a working Frother you would press the start button, it will light red and work for a few minutes.
                                          If you press longer it will light blue and just mixup the milk.
                                          With the new Motor it just starts...
                                          03-23-2021, 11:24 AM
                                        • sbt123
                                          charnwood w821 mini wood lathe motor problem
                                          by sbt123
                                          hi there,im having a look at repairing a wood lathe for my dad,(charnwood w821)the problem is when turning up the variable speed control,the motor starts to stop and start by itself,if i continue to turn up the speed it will trip the mcb in the consumer unit,there is also a slight smell of burning from the speed controll box.,Another strange symptom is the lathe can be unplugged from the mains after switching it off and the motor will spin a couple of times by itself,so far ive put a new speed controll potentiometer on and new motor brushes,ive also tested the motor windings and everything looks...
                                          10-27-2024, 03:43 AM
                                        • mikey5791
                                          Help identify this motor
                                          by mikey5791
                                          Hi all forum members,
                                          Found this unknown motor discarded in a junk yard and took home for learning experience. By the look of it, I suspect it is taken out from a type of air blower probably running on ac power. I used digital multimeter on ohm/resistance scale and it doesn't read anything on those 2 black wires. So, this motor is not shorted and should be good to run.
                                          Correct me if i am wrong on the initial test.
                                          Can anyone kindly advice on how to test run this motor based on visible external two black wires. Fyi, i don't see any marking on the motor body nor smell anything...
                                          11-24-2023, 07:54 PM
                                        • Per Hansson
                                          Motor run capacitor physical size vs voltage rating & measurements?
                                          by Per Hansson
                                          (TL;DR skip the first paragraph)
                                          I encountered my first dead motor run capacitor at a customer this week.
                                          For some fields I guess it is a very common occurrence but the usual way for industrial machines here is to use 3-phase motors.
                                          (Unless a servo motor makes more sense that is).
                                          But for some reason this 3-phase machine uses a 1-phase motor for its liquid coolant pump.
                                          The pump would run but sometimes trip the 10A breaker.
                                          I monitored it starting and stopping for over an hour until it finally stopped in a specific spot between its windings:
                                          Then it could...
                                          09-20-2020, 06:32 AM
                                        • gjlpereira
                                          MacBook Pro A1708 - CPU extremely slow, locked @ 0.39ghz; fan full speed
                                          by gjlpereira
                                          Hi forum.
                                          I'm working on a macbook pro, model a1708, that is running extremely slow.
                                          Everything on it seams to work just fine, it just works extremely slow; painfully slow; especially running macos (windows and linux actually run OKish on it, slow, but usable).
                                          One other symptom of the problem with the machine is that the fan is always running at full speed.
                                          This machine has been worked on by someone else previously; they tried to repair it, but with no success. The motherboard does have sings of being worked on, but it all looks good/OK; like...
                                          09-06-2022, 07:45 PM
