Increasing input voltage of DC-AC inverter - possible ?
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Good day folks. Some of you may remember that a while ago I wrote about a colleague of mine who likes tinkering with batteries and design all kinds of crazy devices using them. He reached out to me again and asked me if it would be possible to increase the maximum input threshold of a DC-AC inverter he's using for god knows what. The reason he wants to do this is because this inverter runs at 15v max according to the label, while the battery pack he built puts out 18v which causes the inverter to shut off - some sort of OVP on the input there.
    Not really having the time and not wanting to ruin someone else's junk, I kindly brushed him off so I could think about it. What would the limitations be here or is such a hack even remotely possible ? Sounds like a window comparator to me. An IC of sorts (at the most basic level an op-amp) has a fixed reference voltage on its N/I input and a resistor divider on its inverting input (or vice versa depending on whether the output swings negative or positive when OVP is triggered). The "top" of the resistor divider goes to the input and the two resistors are calculated in such a way that when the input is under the threshold, the voltage is lower than the reference and the op-amp is not triggered. When the input causes the resistor divider's output to go higher than the reference voltage on the other input, the output swings low or high stopping the device one way or another - perhaps by cutting VCC to a switching IC. It's a fairly cheap thing so I doubt it's fancy enough to have a micro in there - THAT would be a problem since the threshold might be internally programmed !
    Aside from the theory, an immediate practical issue would be the capacitors (and other components along the input for that matter) since they're very likely not rated for anything more than 16v, so those would require swapping for 25v or higher ones....
    That's all I can think of TBH...doesn't sound too difficult on paper, but who knows what I'm faced with once I actually pop the cover off It's rather small in size, so I don't think it's rated for anything higher than 200w - maybe 300 pushing it...
    Any thoughts ? Cheers and thanks
    Wattevah...
    Re: Increasing input voltage of DC-AC inverter - possible ?
    I would find out what kind of chips are being used then look up spec sheet and application notes circuits.
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      Correct. I must first see what's connected on that input and their maximum ratings.
      Wattevah...
      • petehall347
        • Jan 2015
        • 4425
        can you not use a regulator to drop the 18v to 15v ?
          It will be too much power wasted since it is DC-AC inverter so it probably draws lots of current.
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            He's already using a DC-DC converter between the batteries and the inverter to make it somewhat functional, but it's not ideal, hence the idea to drive the inverter directly somehow.
            Wattevah...
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              Could you use more batteries and regulate the batteries voltage to the desired input voltage??
                • 30951
                list the details - power source, wanted output,
                parts he has.
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  parts he has.
                  I shall post pics and other details once I actually get my hands on the inverter, but what I do know for now is that he wants to power it with a 4S-4P battery pack, so around 16v input voltage - 230v out, modified sine wave most likely - don't even need to check, since all cheap inverters are like that...
                  Wattevah...
                  • Retro-Hipster
                    Tinkerer
                    • Apr 2019
                    • 125
                    Yeah, pics and such would definitely be good. In particular, pic\s of the chips and close ups of surrounding circuitry between the switching mosfets and the chip would be helpful. Depending on the configuration and how cheap the inverter is, you may need to replace certain things like resistors or capacitors. (16v limit may be due to the use of 16v capacitors.)
                    “Men always seem to think about their
                    past before they die, as though they were
                    frantically searching for proof that they
                    truly lived.”
                    – Jet (Cowboy Bebop) -
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      A while back I managed to repair a small inverter like this, though that one was designed for 24v and I had the opposite issue: it wouldn't run on my 12v input Part of the board was burned to a crisp and I had to redo traces and other things. I remember it had a linear regulator (I THINK a 7805) somewhere in there to power the various ICs and other small things, making it rather inefficient in the grand scheme of things, as an input of 24v means 19v are being dropped by this regulator !
                      I'm expecting this one to have something similar, so by increasing the input, we're also increasing the heat and dissipation...
                      Wattevah...
                      • Retro-Hipster
                        Tinkerer
                        • Apr 2019
                        • 125
                        Oh, yes indeed. haha Well, you never know! Maybe it's actually a Gem and we are all just doubting it. :'D
                        truly lived.”
                        • petehall347
                          • Jan 2015
                          • 4425
                          a good enough amount of heat to run my fridge i would think . although i thought it was only 150 watts inverter that should only draw a few amps .maybe 10 amps .
                            • 30951
                            the invertor is probably clamping the input because it thinks it's a surge - probably a big mov or zener diode.
                            • Dannyx
                              CertifiedAxhole
                              • Aug 2016
                              • 3912
                              This is the inverter he's using, though it's not the 24v version like I linked to here...I don't speak Polish so I have no idea what it says there - just wanted to show you guys at least what it looks like. I thought it looked a bit on the cheap side, but apparently it's 500w, though that's probably peak.
                              All well...let's crack it open now I'll keep you posted.
                              Wattevah...
                              • ugamazing
                                820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                                by ugamazing
                                So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                                1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                                2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                                04-10-2024, 08:06 AM
                                Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
                                The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
                                The bq24745 features dynamic power management...
                                10-23-2024, 02:50 AM
                              • x_orange90_x
                                Vizio E55-E1 bad backlights or bad inverter?
                                by x_orange90_x
                                I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                I don't know how exactly to test the inverter itself. Is it...
                                01-29-2025, 09:24 PM
                              • Gentian
                                APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                by Gentian
                                I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                03-06-2023, 07:07 AM
                              • valvashon
                                Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                by valvashon
                                For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                01-04-2024, 01:44 PM
