Where can I find good quality LEDS through hole type
    • Jul 2011
    • 6070
    I have been having a very hard time finding good quality LEDs does anyone have a good source for them
    Re: Where can I find good quality LEDS through hole type
    What are the requirement?
    https://www.cree.com/led-components/...rightness-leds
      • 31283
      water-clear 3mm and 5mm, ali-express in 100's
      if you want traditional foggy-plastic ones - not so sure
        • Jul 2011
        • 6070
        Have you tried them before and what is there quality
          • Jul 2011
          • 6070
          Originally posted by budm
          I am looking for something like this
          Cree® 5mm Round LED C503B-WAN
            • 31283
            the colour ones are really good, i use flat-top ones to indicate various voltages in psu circuits.
            but your after high-flux white - i never had anything like that.
            i do know the main maker of those is not CREE, it's Nichia.
            http://www.nichia.co.jp/en/product/led.html
              • Jul 2011
              • 6070
              Is this a good price for them
              https://www.ebay.com/itm/200-High-Br...sAAOSwPrtcGw6p
                • 31283
                USED white leds?
                a good price is if THEY PAY YOU to take them!!
                  LOL, I like the "Sealed pack of 200 pcs.", they are used so what's the purpose of saying 'Sealed pack', trying to make it looks like new? $150?????
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    ROFLOL! at the $150 lot!
                    what is the application you need these for?
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8706
                      They look like they don't have leads cut or soldered, not sure if they're really "used" ...
                      I think these LEDs are NOS not used... though better to clarify.
                      • the_rem
                        Unknown transformer : how to find a good replacement part ?
                        by the_rem
                        Hello guys,
                        I would like a quite old but still good 800 W ATX PSU to be repaired. The problem was an extremely heavy coil whine coming from the small secondary transfomer on the PCB.
                        I desoldered it hoping the references on the upper side would allow me to find a adequate replacement part. Sadly the written references drove me nowhere but to the manufacturer (I-MAG). I sent them a message like a bottle in the see asking them to send me a datasheet of the transformer. And... They responded ! I received a kind of datasheet (see attachment) but my competencies do not allow...
                        04-23-2025, 01:48 AM
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
                        by momaka
                        03-15-2023, 10:17 PM
                      • wolf1976
                        samsung ue43nu...
                        by wolf1976
                        hello on the above tv i changed lent normally at the bottom i put the leds look strongly round at the point where they are installed and up to the middle it has very good bright lighting from the middle and up it is a little darker and looks ugly this difference can someone advise me what can be to blame as it was the old ones i placed and the new ones precisely Simply because the plastic through which light is transmitted 7 of the old leds had burned and made a hole in it when I placed the new leds I turned the light transmission plastic and put the top of it at the bottom to be straight with...
                        01-29-2024, 01:20 PM
                      • tmhobadcap
                        Samsung un65h6203af led replacement question
                        by tmhobadcap
                        This tv is with sound but no picture. When light shines on the screen, we can see the image. This is a typical backlight problem. I opened it and found quite a lot of the leds are damaged. But the damaged ones are all shorted. No one is open. Is there a special reason? (From my past experience, both can be happened)
                        When I supply 3V to each of the good leds, the currents range from 105mA to 154mA. From these figures, I think the leds are 3V and about 0.5W. I plan to replace all the damaged leds only (because the price of the led strips is very expensive), but I could not find 3V 0.5W...
                        10-03-2023, 11:37 PM
