Samsung un65h6203af led replacement question
  • tmhobadcap
    • Apr 2019
    • 168
    • CANADA
    This tv is with sound but no picture. When light shines on the screen, we can see the image. This is a typical backlight problem. I opened it and found quite a lot of the leds are damaged. But the damaged ones are all shorted. No one is open. Is there a special reason? (From my past experience, both can be happened)
    When I supply 3V to each of the good leds, the currents range from 105mA to 154mA. From these figures, I think the leds are 3V and about 0.5W. I plan to replace all the damaged leds only (because the price of the led strips is very expensive), but I could not find 3V 0.5W leds online. Instead, 3V 1W leds can be easily found. Can I use the 1W leds? (I think if the tv supplies a constant current to the leds, then I think using 1W to replace the 0.5W is no problem. But I do not know if the tv supplies a constant current or a constant voltage to the leds.)
    One more question. Since there are quite a lot of damaged leds, I also plan to replace some more leds (which still light up but may fail very soon) so that the tv can last longer after repair. How can I find them? Will the current drawn give a hint on that? Which one will have a longer life left (the one will draw lower current or the one will draw higher current)?
  • nomoresonys
    • 12370
    • U.S.
    Re: Samsung un65h6203af led replacement question
    I would go with the whole set at around 37 bucks: https://www.ebay.com/sch/i.html?_fro...076A+&_sacat=0
    • Storyteller12
      • Jun 2020
      • 625
      i would go with the whole set at around 37 bucks: https://www.ebay.com/sch/i.html?_fro...076a+&_sacat=0
      +1
      • EazyBone
        • Jun 2023
        • 1408
        • United states
        • Anything I can do with my hands
        +2
        • tmhobadcap
          • Apr 2019
          • 168
          • CANADA
          Thanks for your suggestion. I have placed the order for the led strips.
          But I still would like to know the answers to my above questions. They would be useful for me in case I have another tv which needs only to replace just a few leds.
          • nomoresonys
            • 12370
            • U.S.
            Well they are 3 volts, that's all I know.
            • labello
              • Mar 2018
              • 310
              • italia
              Hey man if I can suggest something to you is just don't waste your time because you need only change all of led to do a best job. So don't give it to time of your life to do experiments, the bast way is change every strip. 👍👋
              • handsworth
                • Oct 2015
                • 175
                The single leds that you spend time replacing, will only buy time. The ones you dont replace have aged and will go out soon after. I suspect that tv is a 2015 or 16 model. Glad you bought new ones.
                • Boardview and Schematic Bot
                  09-07-2024, 05:50 AM
                • Ukdigger
                  Samsung UE65KU6400UXXU Should it have Blue LEDs
                  by Ukdigger
                  Power Supply Board - BN44-00073A (LPF5G-6LM)
                  Main board BN94-10777A
                  TV was only showing faint picture at the left and right edges with nothing in the middle.
                  Took the TV appart and found that the plastic defuser sheet was cracked and burnt on the left and right edges. The LED strips are on the left and right edges. I managed to get a scrap TV with the same size defuser sheet in good condition. The LEDs were blue, all the TVs I've done before have white LEDs so I thought I needed new ones. I ordered some new ones from Aliexpress and they were blue....
                  01-28-2026, 10:08 AM
                • R12345678910
                  Samsung Galaxy Book3 Pro 360 (16") - No Charging After Battery Replacement
                  by R12345678910
                  Looking for some help diagnosing a charging fault on my Samsung Galaxy Book3 Pro 360.
                  Device details:
                  - Model: NP960QFG-KA3UK
                  - Board codename: MARS3-16_WIFI
                  - Motherboard P/N: BA92-24423A
                  - CPU: Intel i7-1360P, 16GB LPDDR5
                  - Part number visible on motherboard: M14Q01W8400114 (not 100% confirmed)
                  Symptoms:
                  - Laptop will not charge at all
                  - Charge indicator light is intermittent — sometimes it comes on when the charger is plugged in, sometimes it doesn't
                  - No actual charge reaches the battery regardless...
                  03-22-2026, 11:57 AM
                  09-06-2024, 11:40 PM
