Will different systems will work on ATSC?
  • capwizard
    • Jun 2016
    • 1991
    I have one question.
    The TV is from outside of the United States different systems will work on the ATSC system? the HDMI should be the same all over the world? but the customer said nothing works on this TV? is that right?
  • capwizard
    • Jun 2016
    • 1991
    Re: Will different systems will work on ATSC?
    I checked on tuner it is NTSC system because of the connector I thought was PAL system.
    Samsung BN40-00164A Tuner-Dtvs30Cvh071A, Ntsc
    Is that missing an adapter?
      • 30979
      pal does not use a phono socket, it uses a belling-lee usually.
      that tuner would have had an adapter on it - probably to an F socket.
      so, what is the u.s. digital tv standard these days, and what is it in canada?
      same question for the frequency range it's transmitted on.
        UNxxc8000: N = North America.
        You need one of this adapter: http://www.samsungparts.com/Products...UN55C8000XFXZA
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8696
          USA DTV standard is ATSC 8VSB when transmitted OTA.
          Frequency range is the same as the old analog VHF/UHF channel frequencies, pretty much. Just that the virtual channel numbers may not match the physical RF channel numbers...
          • capwizard
            • Jun 2016
            • 1991
            Okay, then tv problem is no input works.
            How can I know which IC has a problem? Pic (1) and what are those useless porcelain heat sinks for? I threw in the garbage, right away. (2)
            I'm going to guessing is the metal one. Bag reflow begin.
            • capwizard
              • Jun 2016
              • 1991
              After (1,2) tv still no input. do I need to use oven bake?
                • 30979
                check your menu's first - make sure it's set for the right region or it will scan the wrong frequency range.
                  Do other TV's you have in the shop able to pick up anything? How about hooking it up to other video source that has ch 3 or ch 4 RF out?
                  The HDMI inputs are OK, correct?
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8696
                    Are there any cheap ATSC encoders yet (set top box to convert analog to something an atsc set can pick up on a channel)?
                    • capwizard
                      • Jun 2016
                      • 1991
                      The strange situation, all the input sources are not working and TV will take a long time to turn on the screen.
                        OK, then it is just not tuner problem then.
