LED current
  • capwizard
    • Jun 2016
    • 1991
    LED current
    LED 3535, Lumens 85lm, Current 300mA, Voltage Up to 19V
    I have a question when we going to buy LEDs they say 300 mA is that means at 85 luminance condition.
    we know LED can go very low and up to 800 mA for short time. So, what is the factor that determines LED marks current?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Re: LED current
    "marks current"? or do you mean maximum current?
    Lots of things, but maximum current is determined by how much heat the die/wirebond can deal with before melting down. There is a heat capacity of the die and wire, so short (milliseconds), high current pulses can be tolerated as long as there's enough off time to let the heat generated dissipate. Thermal resistance dictates how much off time is needed, and there are portions of the die that have higher thermal resistance than the side contacting the heatsink.
    • capwizard
      • Jun 2016
      • 1991
      Re: LED current
      Yes...Max. Reverse Current 350MA but how can I test it?
      this is for my next project is for an unknown LED I can test the maximum forward current and luminance then sorting and reclaim used leds.
      Maybe I can use my own standards. I put 100 mA to the LED see how much luminance come out and use this to sort all the LEDs.
        Re: LED current
        Do you have full spec sheet?
        I.E. see page 4. https://cdn.badcaps-static.com/pdfs/...ae1f01f265.pdf
        http://www.giangrandi.ch/optics/lmcdcalc/lmcdcalc.shtml
        • capwizard
          • Jun 2016
          • 1991
          Re: LED current
          the manufacturer used 100 mA current to test leds.
          the beamwidth (beam divergence) 2θ, which is the angle of the cone of light emitted, we can do an approximate calculation
          In fact, my next question is how to test leds with diffusion lens? It is already written in the article and taught me how to calculate luminance.
            • 31084
            Re: LED current
            it's all about disipating the heat - like any semiconductor.
            however, there is little point taking the piss with it because the current to lumens curve levels off fast near the top.
            doubling the current may only give you an extra 20% lumens - the rest is more heat.
              Is there any high current pouch battery that are size 60mmX80mm maximum thickness 21mm for a battery operated tab welder
              by sam_sam_sam
              I have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
              I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
              I tested the battery cells there are installed right now and they are testing good with no issues that I...
              02-04-2025, 08:08 PM
            • unimatrix93
              Which resistor should I remove/replace to decrease current to backlight leds?
              by unimatrix93
              Dear community, I want to increase the lifespan of my backlight led in my TV by decreasing the current.
              However I need some help identifying the resistor I need to replace to achieve this.
              Thank you!
              11-29-2024, 05:05 AM
              Diodes AP21X2SG-13 AP21X2MPG-13 Current Limited Power Switch for Laptop Computer Datasheet
              The AP2182 and AP2192 (AP21X2SG-13 AP21X2MPG-13) are integrated high-side power switches optimized for Universal Serial Bus (USB) and other hot-swap applications. The family of devices complies with USB 2.0 and available with both polarities of Enable input. They offer current and thermal limiting and short circuit protection as well as controlled rise time and under-voltage lockout functionality. A 7ms deglitch capability on the open-drain Flag output prevents false over-current reporting and does not require any external components.
              All AP21X2SG-13 AP21X2MPG-13 devices are available...
              10-23-2024, 03:33 AM
            • DynaxSC
              Extreme High Current & Low Voltage Short Killer ??
              by DynaxSC
              Hi Folks
              I'm looking for a extreme high current short killer solution for a reasonable cost.
              I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
              After taking off the socket, the shorts dissappear again.
              The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
              10-15-2024, 10:13 AM
            • Pipolups
              Corsair K70 LUX RGB dying LEDs
              by Pipolups
              Hi there !
              I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
              Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
              10-08-2024, 11:58 AM
