Can I use the Transformer in reverse?
  • capwizard
    • Jun 2016
    • 1991
    Can I use the Transformer in reverse to get some high voltage?
    Transformer Connected Backwards
    https://youtu.be/ZCNQXzOp6Io
    Re: Can I use the Transformer in reverse?
    Sure, why not.
    For example: How do think the UPS convert the 12V battery power to 120VAC?
    What is transformer?
    https://www.galco.com/comp/prod/trnsfmrs.htm
      • 31281
      actually, no - atleast not always.
      the secondary can have a lower breakdown voltage by how it's wound or the type of insulation on the wire.
        If the secondary is rated for 24VAC then you are not going to put in 120V AC on that side, common sense.
        • desert-rat
          • Mar 2014
          • 4103
          I knew a guy that would put 120 v 60 hz on the small speakers they used in cheep tranny radios in the 60s . They had a real loud buzz for a secount or two .
          • Thedoc298
            • Apr 2018
            • 6
            actually yes, the secondary will always be rated for what you would be putting back into it, 24v out 24v in, 12 volts out 12 volts in 500 out 500 in. just never put more in than it put out to begin with.
            • Curious.George
              • Nov 2011
              • 2305
              • Unknown
              The OP hasn't stated that his intent was to apply the rated secondary voltage TO the secondary. He just said, "Can I use the Transformer in reverse to get some high voltage?" For all we know, he may cherry pick a 6V xformer and apply 24VAC to the secondary in an attempt to generate ~500V on the primary!
              • hikomalek
                SYMSI70 gas heater, TOP247Y exploded, power supply, snubber network
                by hikomalek
                Hello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
                When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
                Transformer:
                |Info| Primary | Aux | AB | CD|
                |Ratio|1|25|40|12|
                |Voltage AC|230V|9.2V|5.8V|19V|
                |Voltage DC (*1.41)|230V|13V|8.1V|27V|
                I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up...
                09-19-2025, 03:30 AM
              • SoulFreeze
                Inverter Charger architecture question
                by SoulFreeze
                Hello all, I have a mastervolt charger inverter I'm trying to repair, as I have no schematics I decided to trace our some of the parts to figure out the general operation.
                I managed to trace our a rough block diagram of the power stage, and I'm quite interested in the operation.
                Here are my questions.
                I noticed there seems to be no dedicated charging section in the circuit. After some googling I assume this is what they called a bidirectional power design. Would like to know if my assumption of the operation are right.
                Given that there are no diodes. I am assuming...
                05-07-2025, 09:53 AM
              • learnmore
                Help choosing replacement transformer for Levoit 600S SMPS
                by learnmore
                Hello Community,
                I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                Peace
                LM...
                11-04-2025, 09:35 AM
              • ohren
                Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                by ohren
                Hello!
                I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                Measured voltages with no load:
                After rectifier diodes
                12V: 6.17 V
                5V: 5.67 V
                Secondary transformer pins AC measurement (really don't know if this says anything)
                12V: 2-2.5 V
                5V: 1.04 V
                I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                03-18-2023, 10:33 AM
              • mikey5791
                Is it possible for transformer substitution?
                by mikey5791
                Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                My questions are
                1. How do i test to see if the transformer is in good working condition?
                2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                Hope you guys understand what i was asking. My intention is...
                11-03-2022, 02:11 AM
