Inverter Charger architecture question
  • SoulFreeze
    • Jun 2023
    • 27
    • Usa
    Hello all, I have a mastervolt charger inverter I'm trying to repair, as I have no schematics I decided to trace our some of the parts to figure out the general operation.
    I managed to trace our a rough block diagram of the power stage, and I'm quite interested in the operation.
    Here are my questions.
    I noticed there seems to be no dedicated charging section in the circuit. After some googling I assume this is what they called a bidirectional power design. Would like to know if my assumption of the operation are right.
    Given that there are no diodes. I am assuming the operation of the components served different purposes depending on whether it's charging or inverting.
    My understanding is
    When inverting:
    -the low voltage side mosfets are in high frequency DC to AC switching
    -The IGBTs act as active rectifiers and do the HV AC-DC conversion
    -The last stage of IGBTs do the final sine wave low frequency DC to AC switching
    When charging the reverse happens
    The last stage IGBTs act as active rectifiets
    The middle stage of IGBTs do the HV High freq switching into the transformer
    Then the low side mosfets rectify the voltage to low voltage DC to charge the battery.
    Is this correct?
    Further more, there are 3 extra IGBTs circled, wired in kind of a differential pair (the ones facing each other), along with a large torroidal inductor on the HV DC positive rail.
    What is the purpose of these components? I'm assuming it's related with regulating the HV DC rail? Is it for charging?
    (Kindly note that due to the lack of proper schematics the circuit trace attempt might have significant errors, especially with low resistance components that may exist where I assumed they are just connected.)
    Anyone willing to explain the operation further would be highly appreciated.
  • SoulFreeze
    • Jun 2023
    • 27
    • Usa
    My understanding is
    When inverting:
    Is this correct?
    Made a mistake on the diagram, the torroid should be between the tranformer side fets, as shown
    • Gentian
      APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
      by Gentian
      I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
      It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
      03-06-2023, 07:07 AM
    • motormayhem
      Lenovo T460 Only Charges on One Charger
      by motormayhem
      Laptop Question
      I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
      A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
      05-12-2023, 01:46 PM
      NVDC charger configuration...
      11-05-2024, 03:28 PM
    • flat-earther
      how to prevent a connected charger from draining battery when not charging?
      by flat-earther
      I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
      So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
      but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
      So the battery is backfeeding the charger and being drained.
      How can I prevent...
      08-07-2025, 01:04 PM
    • flat-earther
      ASUS X54H laptop thinks it's always charging even with charger unplugged
      by flat-earther
      The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
      Windows also shows ''Plugged in'' when charger is not connected.
      This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
      Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
      If I let battery run out and say it has 3% Windows will...
      06-24-2025, 09:32 AM
