How to make a spot welder.
  • capwizard
    • Jun 2016
    • 1991
    The easies video I ever found. I will try it with 120vAC. the capacitor in the video is a 440 volt 20uf AC capacitor. we can make a one with two DC capacitors.
    https://youtu.be/sYR4RuqEIjs
  • Curious.George
    • Nov 2011
    • 2305
    • Unknown
    Re: How to make a spot welder.
    You DO understand that you've now got ~150V sitting on those test leads (lying on the bench)?
    • capwizard
      • Jun 2016
      • 1991
      I am so blessed by the God. unlike the video he used 240v and we're in the US only 120v.
      I connected two capacitors polarized reverse together I thought I've made an AC capacitor but the fact was I only make a nonpolar DC capacitor. So it blow out with white smoke.
      Does anybody know who make the decision USA uses 120v I need to say thank you to that person.
      I going to use real AC capacitor from HVAC unit.....to be continued...
      • petehall347
        • Jan 2015
        • 4426
        • United Kingdom
        you should wire capacitors in series so you end up with 2 negatives or 2 positives .
        • R_J
          • 9535
          Petehall347, I just looked at the first picture that is NOT the way to make a bi-polar cap. they must be connected like you said, in series (+2+ or-2-) Those caps also likely won't handle the current.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8696
            I've seen 1F capacitor discharge at ~4V, so to not need a 1F capacitor,
            1F * 4^2 = 440uF * x^2
            x=191V
            So yeah looks about right, need those high voltage in order to not need those low ESR 1F caps...
            Note that you can just rectify the line voltage and not deal with bipolar capacitors. And yes the capacitor needs to be low ESR...
            • capwizard
              • Jun 2016
              • 1991
              But can DC capacitor use in AC? From the experience I just got they became really hot. what are those difference?
              • Curious.George
                • Nov 2011
                • 2305
                • Unknown
                To be clear, you're proposing rectifying the mains to CHARGE the cap; not to use in place of the cap.
                (the point of the capacitor is that it represents a fixed energy reserve; once spent it automatically "shuts off" without any "timing controls")
                I think a smarter approach might be to dump the charge from the cap (or even a voltage source) into the load through a step-down transformer (trade I for V). Sort of like a CDI -- but in reverse!
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8696
                  The original "idea" is sort of flawed, you can't really "charge" a capacitor with AC. The charge that happened to be on the capacitor is pretty much luck of the draw depending on when in the cycle it got disconnected. It doesn't make sense to "store" AC on the capacitor.
                  You have to charge the capacitor with DC no matter what.
                  On the other hand, I was wondering is whether just using a old solder gun to weld with... Get rid of the resistive tip and use two probes there instead, and depend on that low voltage high current to weld with. It's on the order of a hundred amperes, which is a bit low, but might be enough...
                  • Curious.George
                    • Nov 2011
                    • 2305
                    • Unknown
                    But, most of the time, the AC waveform is >> 0V, so the odds are that you will have substantial potential across the cap, regardless of where (randomly) you break the cycle.
                    I had recently asked a colleague if I could use a Mig welder "shorted" to the surface to be welded to act as a spot-welder (I was actually looking to weld something substantial -- not flimsy battery tabs). He seemed to think I "needed" to draw an arc for it to work.
                    (I doubt that but am reluctant to try without some better information)
                    E.g., in "shop", the spot welder was just a pair of semi-stationary electrodes (brought together by a foot pedal), a giant transformer and an electro-mechanical timer. Turn sweep arm of timer to desired pulse duration, engage power, watch timer arm spin to zero, hear laminations in transformer groan as sparks flew, done!
                    (i.e., could I do the same with the Mig's transformer?)
                    • capwizard
                      • Jun 2016
                      • 1991
                      yes, AC capacitor was worked good but not enough energy. i need to add more capacity or raise up the voltage.
                      One thing very strange is i measured charged capacitor which has no AC output only has DC around 80v then slowly drop down the voltage? why?
                      Does the capacitor has the same rectification function as rectifier diode?
                      PS: I haven't changed battery for this meter about two years. picture 4.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8696
                        There's no such thing as an "AC" capacitor, just a capacitor that won't blow up with AC due to polarization. The rectifier diode is used to convert the AC to DC, and the capacitor will charge from the proper DC.
                        These low capacity capacitors are easily discharged with a typical 1MΩ-10MΩ input impedance of a multimeter so yes they will drop down in voltage as you keep it connected (plus any leakage resistance within the capacitor, which is also a sign of a bad capacitor). Estimate with the RC time constant and you'll see why it drops visibly, quickly.
                        • Curious.George
                          • Nov 2011
                          • 2305
                          • Unknown
                          [QUOTE=capwizard;877277]yes, AC capacitor was worked good but not enough energy. i need to add more capacity or raise up the voltage.[/QUIOTE]
                          Or, arrange for it to be disconnected from the line closer to the peak of the mains voltage.
                          One thing very strange is i measure charged capacitor which has no AC output only has DC around 80v then slowly drop down the voltage?
                          A capacitor only stores DC. An "AC" capacitor can store DC of either polarity. I.e., some times you may find "lead #1" is positive wrt "lead #2" while at other times lead #2 will be positive. It all depends on the polarity of the charge inside the capacitor when it was disconnected from the (AC) voltage source.
                          (in theory, half of the time it will be disconnected while the mains voltage is "positive" compared to neutral and the other half of the time it will be disconnected while the mains voltage is negative. Do the experiment an infinite number of times -- for an ideal capacitor -- and the results will be 50:50)
                          No. It's just CAPTURING the charge in one direction -- or the other -- depending on the instantaneous polarity of the AC mains signal feeding it at that instant.
                          If, instead, you take eccer0r's (?) suggestion and rectify the mains before connecting the rectified signal to the cap, you could use a DC (or AC) cap and always be assured that the lead that is connected to the positive output of the rectifier would always be more positive than the other lead.
                          Additionally, because the rectifier isolates the cap from the AC line WHENEVER THE INSTANTANEOUS MAINS VOLTAGE IS LESS THAN THE VOLTAGE STORED ON THE CAP, the cap will tend to stay at the peak AC mains voltage, regardless of when you disconnect it from the mains.
                          (the voltage will gradually decay, over time, but at a much slower rate, based on the cap's leakage characteristics)
                          A friendlier circuit would include a "ballast" to limit the rate at which charge can flow into the capacitor when charging it up (yet not be present in the "discharge path" as you want maximum current flow, then)
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8696
                            Incidentally I love my Fluke 77, I got a cheap 50¢ PP3/6F22 battery in there and it's lasted YEARS so far... I think I've gotten its life out of that carbon zinc battery even if knocking on wood fails and dies a minute from now, but suspect it may still keep on working...
                            My other PP3/6F22 multimeters eat their batteries and I have to replace them biannually at best, but usually much worse, depending on how much I use it.
                            • capwizard
                              • Jun 2016
                              • 1991
                              [QUOTE=Curious.George;877286]
                              Thank you very much, but I have one more question. I saw the Amp-meter. It has been using 1.7 amps of AC current even after 3 minutes, This capacitor should be 40 uf now only has 36 uf, long time using 1.7 amps of AC current is because the leakage or low ESR? I mean after capacitor charging up the current should drop down? If I use a DC capacitor will it be better than an AC capacitor.
                                • Jul 2011
                                • 6033
                                I hate to tell you that to me this is real dangerous I would not even give this idea the time of day
                                If you want to build a spot welder I can give you some very good idea on how to do this
                                I just bought a battery spot welder that the transformer is not heavy enough to do a good job of welding but I like the controller
                                I have another battery spot welder that the transformer is heavy enough but the controller board has to many issues to fix
                                So I am taking out the transformer out new one and put the transformer out of the one that the controller went bad
                                So now the battery spot welder works real good now
                                Now if you want to build a capacitor discharge battery spot welder
                                I have everything figured out except one thing and it a very big problem
                                I would really like to build one—————>
                                That this is how to control the discharging the capacitor with out destroying the capacitor or the SCR I have not found a circuit that I like to use
                                The type of SCR I want to use one that handles about 200amps
                                If anyone has a good idea on how to do this please post it
                                I have also tried a capacitor discharge stud welder to do battery welding that was a very bad idea because it was so hot that it burn a hole in the battery to much power
                                This happen with control set at the lowest setting
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8696
                                  "You're doing it wrong." Capacitors, "AC" or not, show up as reactive resistances under AC. So basically you and the video are shorting line to neutral like a resistor when you connect it like that through the capacitor.
                                  As said, it will never "charge" up, it will continually charge and discharge as long as it's connected. Depending on when you disconnect it will show up as the remaining charge of the capacitor.
                                  • capwizard
                                    • Jun 2016
                                    • 1991
                                    The type of SCR I want to use one that handles about 200amps.. ..............Kweld (STM32 equipped) will be good for you but they used 6 MOSFETs. i would like to modify to IGBT, i think IGBT is the way to go, I will use plasma TV's IGBT junk parts to built one, can handle 200Amp with just one IGBT.
                                    kWeld - "Next level" DIY battery spot welder
                                    https://endless-sphere.com/forums/viewtopic.php?t=89039
                                    kWeld - The best 18650 spotwelder?
                                    https://www.youtube.com/watch?v=4UgBG0oFAwU
                                      • Jul 2011
                                      • 6033
                                      Let me know if you get it to work
                                      • capwizard
                                        • Jun 2016
                                        • 1991
                                        You may misunderstand what I mean. I replaced the no energy and expensive 9v battery with two powerful 18650 batteries.
                                          New Super Capacitor 5v DC Battery Spot Welder with a 12 volt power supply
                                          by sam_sam_sam
                                          This is a new item at Battery Hookup that I bought I have always wanted to buy a good capacitor battery stud welder but they are to expensive for my budget that I want to spend on one this was surprisingly moderate price for what it can
                                          It came by FedEx today so I decided to try it out on some tabbing that my battery stud welder has a little issue making constantly welded with out having to redo some because it would not get hot enough to do it properly
                                          Well right out the box when the super capacitor charges up with the setting as follows does a very good job the first...
                                          05-21-2023, 04:28 PM
                                        • spleenharvester
                                          Reverse engineering of DoCreate DHJ567 handheld spot welder
                                          by spleenharvester
                                          Hello everyone
                                          I attach a schematic and teardown photos for the DoCreate DHJ567 handheld spot welder. I bought this welder for temporary use while my supercapacitor welder was waiting for replacement parts. It cost only £24, though there is a screenless version available for £17.
                                          Performance: The absolute maximum it can handle appears to be 0.15mm of pure nickel. Reliability was not great - welds were very inconsistent, ranging from weak attachment to burning through the strip. However, I was able to build a 5S2P pack without losing any cells. It's a bit difficult getting...
                                          05-08-2025, 02:52 PM
                                        • shanedev93
                                          Spot welder capacitor blew up
                                          by shanedev93
                                          Spot welder capacitor blew up should just replacing them fix it? The board is very dirty gonna remove it and clean it an see if I notice anything wrong that could cause this issue.
                                          Video of the smoke show
                                          https://youtube.com/shorts/AFJgRbsHGhs?feature=share
                                          06-21-2023, 01:02 PM
                                          Modifing a Battery Spot Welder because of Controller Issues
                                          by sam_sam_sam
                                          I keep having the same exact issue with these battery spot welder controller boards
                                          They either do one of two things
                                          One the controller does not send the signal for the transformer fire which is a very common problem with this controllers micro controller failure
                                          Or
                                          The controller has some malfunction which means that it does not cycle the pluses more than once or none at all and should do it any where from 1 pluse to 20 pluses because you can not change the setting does not respond to its input micro controller failure
                                          This...
                                          10-12-2019, 08:51 AM
                                        • chth96
                                          If I replace with inferior capacitor, Is it No harm to other IC components at all?
                                          by chth96
                                          I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                                          Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                                          It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                                          So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                                          I know that these capacitor will not last as long as nichicon capacitor...
                                          12-22-2023, 04:34 AM
