How to make a spot welder.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8706
    Re: How to make a spot welder.
    Well, just saying, I spent 50¢ per 9V battery and it lasted at least 4 years so far, I don't think it's a bad deal, and nothing sticking out of the meter... This is specific to the Fluke.
    That is not to say the same 9V battery (out of the same 2-pack) lasts less than 2 years, possibly only a few months on my other 7106-based meters...
    • Sparkey55
      • Jan 2010
      • 1523
      Originally posted by capwizard
      The easies video I ever found. I will try it with 120vAC. the capacitor in the video is a 440 volt 20uf AC capacitor. we can make a one with two DC capacitors.
      https://youtu.be/sYR4RuqEIjs
      I once blew a hole into a 1/4 inch screwdriver when shorting a 25,000UF 75VDC capacitor.
        • 31278
        http://ultrakeet.com.au/write-ups/cdWelder
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8706
          I guess the trick is for capacitor discharge welders is finding good capacitors...
          Ever since I destroyed a capacitor by repeatedly charging and shorting it (for entertainment purposes) it's something to consider...
          Currently I've been using a 51mF capacitor charged at ~18V to blast through shorts in NiCd cells... Doesn't always work but at least this capacitor is capable of dealing with shorting, at least its performance hasn't dropped compared to that other capacitor I was playing with when I was younger...
            • 31278
            shorting large caps can melt the wire inside the bung where it's flattened to go into the foil.
            the cap can store more current than the wire can hold.
            it's also not a good idea to short a crt anode by shoving a pair of screwdrivers under the cap - you can damage the diode with the emf spike!
            i'v seen old gits damage them a few times like that - modern-ish transformers arent as robust as the 70's
            besides, does a chain of resistors really cost that much? /sarc
            • capwizard
              • Jun 2016
              • 1991
              If you want to make best spot welder then you need to use the best and biggest capacitor in the world and that is battery.
              So I'm going to switch my attention to 12 v battery spot welder is that sound right?
                • 31278
                no, batteries explode!!
                what's wrong with using a microwave oven transformer and changing the windings?
                others have done it.
                • capwizard
                  • Jun 2016
                  • 1991
                  Yes that will be a workhorse. then we pretty much go back to old solder gun like this guy eccrr0r said...
                  I was wondering is whether just using a old solder gun to weld with... Get rid of the resistive tip and use two probes there instead, and depend on that low voltage high current to weld with. It's on the order of a hundred amperes, which is a bit low, but might be enough...
                  I have tried that before I think old solder gun has no enough current.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8706
                    Using a car battery, you must have some sort of control like an IGBT or MOSFET bank. People have welded with a car battery but that tends to blow small battery tabs up. A capacitor is good because the amount of energy stored in a capacitor is limited.
                    Might need to look for a bigger solder gun that has a bigger transformer in it...
                      • Jul 2011
                      • 6070
                      All you need is transformer controller and these are easily found today on eBay ( when I get home I will post where you can find some)
                      The hardest part is getting a 1000 watt microwave transformer (or two of them depending how hot you want the weld to be) and converting it with out distorting the primary winding but if you take your time it can be done
                      Now the battery spot welder that I have if I change the breaker from 15 amp and went to a 30 amp breaker I could get some very hot welds and I might have to do this I would have to change wiring to go to a 30 amp breaker and just have not been motivated to do it so far but if I keep getting cold welds that the battery tabs do not stay on I will have to do it
                      Because I can only turn the current controller to no more than 70% with out tripping the 15 amp breaker
                      Another reason that I have not change the breaker is that when the current controller start taking a shit when you hit the trigger button it bounce and rapidly fires the transformer and trips the breaker
                      Or
                      This happens when you first turn power on it rapidly fire the transformer and this might happen a few times before it stops doing it so you can use it
                      In either case when it works right it does not do this
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8706
                        So, that's another benefit of the capacitor discharge welder versus transformer based
                        Alas the recycle time of the transformer based should be quite a bit faster...
                        • MORETTIGIAN
                          by MORETTIGIAN
                          Title:
                          Description:
                          Procedure performed:
                          - Removed backplate
                          - Reapplied thermal compound
                          - Reassembled card
                          09-18-2025, 12:14 PM
                          New Super Capacitor 5v DC Battery Spot Welder with a 12 volt power supply
                          This is a new item at Battery Hookup that I bought I have always wanted to buy a good capacitor battery stud welder but they are to expensive for my budget that I want to spend on one this was surprisingly moderate price for what it can
                          It came by FedEx today so I decided to try it out on some tabbing that my battery stud welder has a little issue making constantly welded with out having to redo some because it would not get hot enough to do it properly
                          Well right out the box when the super capacitor charges up with the setting as follows does a very good job the first...
                          05-21-2023, 04:28 PM
                        • spleenharvester
                          Reverse engineering of DoCreate DHJ567 handheld spot welder
                          by spleenharvester
                          Hello everyone
                          I attach a schematic and teardown photos for the DoCreate DHJ567 handheld spot welder. I bought this welder for temporary use while my supercapacitor welder was waiting for replacement parts. It cost only £24, though there is a screenless version available for £17.
                          Performance: The absolute maximum it can handle appears to be 0.15mm of pure nickel. Reliability was not great - welds were very inconsistent, ranging from weak attachment to burning through the strip. However, I was able to build a 5S2P pack without losing any cells. It's a bit difficult getting...
                          05-08-2025, 02:52 PM
                        • shanedev93
                          Spot welder capacitor blew up
                          by shanedev93
                          Spot welder capacitor blew up should just replacing them fix it? The board is very dirty gonna remove it and clean it an see if I notice anything wrong that could cause this issue.
                          Video of the smoke show
                          https://youtube.com/shorts/AFJgRbsHGhs?feature=share
                          06-21-2023, 01:02 PM
                        • littlejohn
                          Sunkko 737g battery spot welder
                          by littlejohn
                          I bought this welder to spot weld some 1.5mm tabs onto batteries , which kinda worked , now I'm given some batteries that have 4.2 mm tabs that are found in Makita , dewalt and snap on battery packs . Can I modify it to do this ? The triac is a Q6040K7 which shows 6.3 vac and 36 amps output and don't know if it is accurate due to the short on time when foot pedal is triggered ....
                          11-09-2025, 01:27 PM
