Comparison of LED Backlight Testers
  • alexthefifth
    • Jan 2019
    • 3
    Hi All,
    There seems to be a lot of devices on the market that claim to be LED backlight testers, ranging in price from $20 to $$$. Does anyone have experience with these particular types and can chime in if they're adequate for LED TV repair? I'm in North America so looking for devices that run on 100V but I included all voltages just in case it's useful for others.
    And yes, technically one could build a tester themselves, but if you're like me and are not very technically inclined then you'd rather spend $20 than learn how to solder :p
    Type #1 shopjimmy.com SID GJ2C LED TV Backlight Tester
    https://www.shopjimmy.com/sid-gj2c-l...n=sid-gj2c-led
    or much cheaper here: https://www.ebay.ca/itm/GJ2C-0-320V-...v7UQ:rk:1:pf:0
    Type #2 GJ2C alternate version
    ~28USD: https://www.ebay.ca/itm/GJ2C-0-320V-...ZsDg:rk:5:pf:0
    Type #3 DLV300
    $18.50 USD: https://www.ebay.ca/itm/New-0-300V-T...GvF:rk:84:pf:0
    Type #4 220V
    $16 USD: https://www.ebay.ca/itm/LED-Strips-T...Yox:rk:78:pf:0
    Type #5 KS210A
    ~$23 USD https://www.ebay.ca/itm/Digital-LED-...5jD:rk:83:pf:0
    Type #6 Blink 220V
    ~$23 USD https://www.ebay.ca/itm/AC220V-LED-T...Daz:rk:81:pf:0
    Type #7
    ~$23 USD https://www.ebay.ca/itm/AC-220V-Bead...s8X:rk:92:pf:0
    Type #8
    ~$23 USD https://www.ebay.ca/itm/0-200V-Outpu...QY:rk:104:pf:0
    • Jul 2011
    • 6039
    Re: Comparison of LED Backlight Testers
    Which one of these units do find is worth the cost of it
    • alexthefifth
      • Jan 2019
      • 3
      I don't know lol I was hoping someone could tell me which are good and which are bad
      My aim is to spend ~$20 on a device that performs as well as a ~$50 one
      • llonen
        • Sep 2014
        • 495
        • hampshire
        I got interested in the whole LED Backlight Tester gig some time ago with the view that it might speed up testing of said back lights, and came across a cheap example of the SID GJ2C I think I paid around £10.00 via Ebay. What I found along with others that have tried these is they don't really develop sufficient drive to adequately test the LED panel, kind of a good thing really as they can produce upwards to 300 volts across the probes and to me that is a potential safety issue.
        Overall findings then, having one is better than not having one, although they give very mixed results with bad led's often passing, I mean see what others say but I have mostly gone back to my old testing methodology. A variable high voltage supply (upto 60 volts) with current sense set) I can usually test one or more complete strips with this at varying loads.
        Hope this helps
        • kiko1
          • Apr 2016
          • 48
          • croatia
          They all supply too low testing current....good thing is that you can adjust current but limit is R-C direct power from mains...20-30mA...not enough...I want 100mA, sometimes 250mA !
          and sometimes you have to wait few minutes with powered led bar to show up a problem.
          CV CC lab supply is perfect for testing separate led bars...never had a problem with that.
            Output of 300Vdc @ 30mA is 9 Watts of power, so way you can do any mod to those LED tester to make it deliver 300V @100mA = 30 Watts.
            Those LED tester is not for 100% proving if the LED's are good or bad but it can tell if you have open circuit condition or not without disassemble the panel. It also help to verify if the video function is working or not if the backlights power supply went and you want to verify if video function is still OK or not by being able to light up the screen with the LED tester.
            • triplefour
              by triplefour
              09-13-2023, 10:43 PM
            • DanPoka
              Guide me through repairing a Dell p2210f LCD ccfl backlight monitor
              by DanPoka
              I bought this p2210f dell monitor to fix. Schematic is the same as p2210.
              Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
              This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...
              02-15-2025, 05:05 AM
            • Comp_Pro
              No Backlight Macbook A1990 820-01041
              by Comp_Pro
              Hello all,
              Am trying to figure out this backlight issue with this A1990 Macbook Pro.
              Tests performed:
              There is no backlight even with a good screen.
              Backlight IC is receiving the correct support voltages.
              Fuse F8400 ok
              Current sense resistor R8400 ok
              Backlight IC is receiving 3.3V on enable pin.
              Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
              Backlight IC receiving 5V from PP5V_G3S
              Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
              I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
              05-06-2024, 10:23 PM
            • cheebster
              iPad Pro 12.9 5th Gen Backlight Issue
              by cheebster
              Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
              Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
              Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
              The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
              Anyone...
              05-20-2025, 09:17 AM
            • canadaboy25
              LG Flatron 24EN33TA No Backlight When Cold
              by canadaboy25
              I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
              I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...
              03-07-2023, 12:23 AM
