What kind of diode is this?
  • roadrash
    • Oct 2015
    • 490
    • U.K.
    I have a diode to replace on a computer disk drive. I had just removed the pcb to allpw access to clean out the masses of dust build up and general cleaning and read errors.
    When i put the pcb back in and powered it up I got a feint burning smell and pulled the power. After removing it again I noticed one of the wires (red) on the power connector had come out (badly crimped) and I dont know what happened but it was the only thing I could see that could have caused this (maybe it touched something).
    Anyway I could only see signs of a track getting hot and a diode discoloured. It connets to CN4 power input 12v or 5v.
    I dont know if any other damage is done but I must replace this diode now but I am not sure what type this is. It looks like a zener but knowing how many there like a avalanche etc can someone tell me please? and any advice would be welcome.
    • 31281
    Re: What kind of diode is this?
    is it commodore??
    • roadrash
      • Oct 2015
      • 490
      • U.K.
      Originally posted by stj
      is it commodore??
      No its actually a sony single sided 3.5" drive out of a vintage Apricot.
      These look a bit differnt to most other zener diodes so I better check. I cant see any identification markings.
      • R_J
        • 9623
        Don't you have the apricot service manual?
        The one I have shows a slightly different drive
        • petehall347
          • Jan 2015
          • 4448
          • United Kingdom
          if one side of it goes to ground it is most likely a zener .
          • redwire
            • 3912
            You'd have to trace each end of it, where it goes. SN75492 or connector.
            The PCB traces are thicker than the nearby small-signal diodes.
            I would guess a zener diode probably to lower 12V to less
            A model number would help.
            • roadrash
              • Oct 2015
              • 490
              • U.K.
              Thanks for the help the model number is OA-D31V-94
              • R_J
                • 9623
                something must have changed here, I can't upload the manual
                • roadrash
                  • Oct 2015
                  • 490
                  • U.K.
                  I think i got a manual for it actually thanks. Do you think damage went further than that diode?
                  • R_J
                    • 9623
                    not enough info to tell. what does the red wire do, you said it supplies +5 or +12v? what did it touch when it came out? where is the diode in the circuit?
                    None of the board layouts or location numbers in the manuals seem to match your drive, so you need to trace what the diode is connected to.
                    • roadrash
                      • Oct 2015
                      • 490
                      • U.K.
                      Thanks for helping again RJ I am having a lot of crazy hicups here. This was a surprise to me. I had stripped both drives to clean them out. It seemed impossible for anything to go wrong as all connectors were different and all wires were held in clips away from anything else. So a short or getting connections wrong was impossible. I sripped and cheked everthing again but found bothing wrong except when i went to check the ribbon cable i noticed the red power cable was adrift from its plug and the crimp on connector still inside the plug. It was a complete fluke. I have 4 of these drives (2 as spares) from another computer that maybe beyond repair. But I hate scrapping something as rare as these drives are if they can be fixed. Obe side of that diode goes to a black wire on the power connector which is most likely ground -.
                      • R_J
                        • 9623
                        Looks to me like D2 anode goes to the red wire, pin1 on J2 plug (5volts). You said it goes to CN4, Where does CN4 go? D2 could just be a regular glass diode and not a zener. Maybe a 1S2348 or 1S1555
                          • Jul 2011
                          • 6070
                          You should be able to repair this
                          You need to find out how to remove the pin out without damaging the pins or the housing
                          Once you have the pin out of the housing you can try open the crimp where the wire is and re-crimp the wire or put a new wire in it place and reinsert the pin in the housing
                          Or solder the wire to the pin DO NOT be tempted to solder the wire to the pin while in the housing you will melt the housing I know because I have tried to do this way before
                          It can be done because I have had to do this a few times before
                          • roadrash
                            • Oct 2015
                            • 490
                            • U.K.
                            Here are 2 puctures of the pcb both sides to make it easier
                            Sam_sam_sam ive repaired the connector and soldered the wires to the pins (not crimped).
                            • R_J
                              • 9623
                              Is CN5 connected to the stepping motor? if it is the diode could be a D107 1S2348H as seen on page 69 of the manual
                              • redwire
                                • 3912
                                The drive looks like a Sony OA-D30V circa 1981, the original 3.5" drive. Used on Apple and Apricots. You have to manually slide the metal disk guard over before plopping the disk in.
                                I cannot find a service manual or schematic for it, to see what D2 does.
                                Sony OA-D30V OEM Manual
                                I notice the FD-3 PCB silkscreen shows a zener symbol for zeners like D1, D10 but D2 is an ordinary diode symbol. One end connects to CN5-2 and CN5 seems to be internal connecting to 12V head stepper motor.
                                On the OA-D32W schematic, assuming a similar circuit, it would be D107 (1S2348H 65V 0.75A high-speed switching diode) on CN105, so the diode there goes between +12V_switched and +5V.
                                To smoke this diode... CN5 pin 1 or 2 shorted to GND, stepper motor cable pinched?
                                • roadrash
                                  • Oct 2015
                                  • 490
                                  • U.K.
                                  Thanks i will check that although all the wires were routed and secured in a way that shouldnt be possible but recently ive seen many impossibilities happen.
                                  • roadrash
                                    • Oct 2015
                                    • 490
                                    • U.K.
                                    I found the diode and ive ordered some. I stll cant understand how it got pinched. Look at pictures and you will see what mean. The connector is keyed so its nit like it could have been one pin out of line. Another mystery.
                                    • WildPuppy
                                      • Mar 2018
                                      • 61
                                      • Romania
                                      Maybe someone pressed CN5 too hard and physically broke the glass of the diode. Upon powerup, it shorted and burned ?
                                      • roadrash
                                        • Oct 2015
                                        • 490
                                        • U.K.
                                        I am still waiting on some of those diodes coming but I noticed another problem with tthese disk drives that I will need to ask your advice about. I have 4 drives in total and when i restored this vintage computer originaly I could only get one car drive to read and boot a disk. Since Ive had the drives apart ive noticed that when the computer boots up and moves the heads to read the disk it also switches the power on to the drives motor (one that spins the disk) but some are not moving. One of them is but only if I give it a nuge to get it moving and it will keep spinning until I remove the power. These are brushless motors and if they are little a/c motors, dont htey need a capacitor to start them spinning? )lioke a a/c induntion motor).
                                        There are some really tiny caps on the circuit board near the motor but not sure if maybe I need to replace them and where I would even start to look for capacitors that small. Whayt do you think? here is a picture.
                                          NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                                          by sam_sam_sam
                                          I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                                          I bought this from an eBay seller but unfortunately they only had one
                                          I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                                          I bought three of from them to also make battery packs with this output power limit in mind
                                          I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                                          04-23-2025, 05:50 AM
                                        • nev1001
                                          What zener diode might fix the sound on Maestro Mayhem gaming chair?
                                          by nev1001
                                          Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                                          The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                                          It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                                          I think an issue could be a zener diode (or capacitor) which has shorted out.
                                          The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                                          04-17-2025, 05:09 PM
                                        • Vincenzo2
                                          Element 32 inches tv (ELEFW328B) Unknown component: Diode or zener?
                                          by Vincenzo2
                                          My Element 32 inches tv (ELEFW328B) lost it's backlight (confirmed with a flashlight test) and the connector on the PCB (it has one board that has a processor chip, switch mode power supply, and backlight circuit) that has the two wires that go to the backlight LED strips has a very low voltage (28-29 volts) when turned ON, in my opinion.
                                          Started testing components and found an SMD diode or zener that is shorted (even zero fusing resistors read a few tens of milliohms, while this thing reads zero).
                                          I put some pictures here to show that it is labeled "M7"....
                                          09-07-2023, 07:43 PM
                                        • hobostove
                                          Corsair RM1000e - Help identify 5VSB Zener diode
                                          by hobostove
                                          Hey there guys. I've got a Corsair power supply that's come across my bench dead. I usually don't mess with power supplies, but it's a slow week so I'm giving it a whirl.
                                          Taking it apart I heard a screw rattling around inside, and when I got it apart I found a couple blown components near what I think is the 5VSB area.
                                          There's a 22ohm resistor that's melted and open, but it still has the bands.
                                          The other part is a zener diode and it's top went to jesus, so I can't read the marking.
                                          It looks like the diode connects the source and drain of a TNY284...
                                          03-27-2025, 02:25 PM
                                        • debidoobs
                                          Yamaha delay D1500, zener diode broken with no marking
                                          by debidoobs
                                          im actually trying to save a d1500 delay from yamaha. I found the service manual but schematic is missing and BOM list is a bit unclear as components listed have no reference linked to the pcbs... In my case, one zener diode was broken (114 code on the pcb in attached file) and couldn't be repaired : it was a zener type package. In the BOM list i found 3 reference on this board : 1S555 (can be replaced by 1N4148), RD4.7EB2 (approx 5v rectifier), RD7.5EB3 (approx 7v rectifier)...
                                          Actually the cathode goes to VCC of sram M5M5118P, without this diode missing, i have...
                                          04-24-2024, 09:01 AM
