How the LED Keeper Works
  • Spork Schivago
    • Mar 2012
    • 4734
    • United States of America
    I'm watching this video on something called the LED Keeper: https://www.ledkeeper.com/4-minute-d...ration-videos/
    At around minute mark 1:24, they show how the LED Keeper can power an unlit section of a string, once a bad bulb is found.
    You plug the string into the LED keeper instead of the AC receptacle. You find the wire leaving the bulb and put the LED Keeper on that string. You pull the trigger and it punctures the wire, lighting the rest of the string.
    Does anyone know how this works in theory? I was under the impression strings are usually wired in series. If you're by-passing any bulbs, essentially removing them from the circuit, wouldn't that increase the voltage drop across each bulb and wouldn't you risk burning them out?
    Thanks!
    -- Law of Expanding Memory: Applications Will Also Expand Until RAM Is Full
    • 31086
    Re: How the LED Keeper Works
    i think i'v seen a video of this by electroboom.
    dangerous as hell, because it was intended for incan x-mas lights.
    ion led strings if it's a series set you need to short it, but if you short a parallel set - boom.
    you could use a resistor, but what value?
    and your still damaging the insulation.
    • R_J
      • 9555
      All it is is a led tester, it will locate the defective lamp so you can either replace the bad lamp or replace the bad socket (PODS) it does not bypass the circuit.
      It is similar to those led testers for backlight led testing
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        yeah pretty simple constant current source and insulation piercing solution, should only work with LEDs as it can't source enough current for incandescent bulbs.
        It looks like it uses those "pods" to short out (or rather use a 33 ohm resistor) opened sockets/LED bulbs. They could have gone one step further and "pod"ded another LED there, but chances are it'd look different and people would rather a dark spot than some weird looking LED?
        I was hoping it was doing some inductive/RF method to find breaks in the circuit, but nonesuch luck, vampire testing through insulation is unacceptable to me...
        • R_J
          • 9555
          I was wrong
          • Spork Schivago
            • Mar 2012
            • 4734
            Those pods don't look like LED replacement sockets to me. I think eccerr0r is correct, and it's just a "dummy" load with no LED.
            I'm more interested in how the device works when it powers a previously unlit section of the strong. It pierces the wire after you find a bad LED, but let's say there's 4 LEDs before the pierce on that series. To me, it seems like it's changing the circuit, by removing the lights before the pierce from the string from the circuit.
            Is that not what's happening?
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              that's what it looks like what it's doing, just generating a, say, fixed 1mA current source and the pierce will complete the circuit when the original LED could not, breaking the circuit, because its die bond or socket broke.
              Pretty primitive I think. I just wonder how many volts max it will generate to light strings of LEDs, that's the trick...
              • Spork Schivago
                • Mar 2012
                • 4734
                Yeah, that's where I'm getting a bit confused I think. The voltage that it generates to light the string of LEDs, without it knowing ahead of time how many LEDs need to be lighted.
                To me, it seems it'd work just like this. Say I put the device after the 5th LED. That would be equivalent to just shorting out the previous 5 LEDs, right? The voltage drop across each LED would increase, if it was a series circuit, and possibly damage the remaining LEDs...
                • R_J
                  • 9555
                  I guess I was wrong, they are just resistors not replacement sockets. I'm sure they could have made a socket that clips on the same way.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    (If it is)/(It should be) a fixed constant current source, the LEDs on the string will automatically reduce the voltage to a safe voltage due to their intrinsic voltage drop - and it wouldn't matter how many LEDs are in the string as long as it's within the range of the CC source.
                    • redwire
                      • 3910
                      The good (light string) lamp testers (incandescent) use a non-contacting electric-field sensor.
                      Sort of like a non-contacting voltage (NCV) probe, except it does not use the handle/case as one electrode. It has two tiny electrodes in the probe you put on top of a lamp and move along the string, lamp by lamp.
                      At a lamp that is open-circuit, you will get a 120VAC electric-field across the lamp, for either LED or incandescent.
                      It's better than breaking the insulation and piercing the wire, outdoor light strings always get wet...
                      • Spork Schivago
                        • Mar 2012
                        • 4734
                        Yeah, I watched the video. I think the reason they didn't was to make it more universal. For example, we've noticed the LED lights from icicles might not be compatible with the LED lights from our 5mm ultra-wide straight strands or whatever you call them.
                        I bet with a little heat shrink tubing and a donor set though, you could easily replace the broken socket with another socket.
                        My mother-in-law brought us a whole bunch of LED net lights that didn't work. With one set, it was like half the LEDs were bad! We used that set as a donor set to the get the other ones working.
                        I'm not sure what happened that took out half the lights in that string. My only guess would be some sort of surge. I believe LED strands usually have some sort of current limiter. Perhaps one of the current limiters failed? I dunno.
                        • Spork Schivago
                          • Mar 2012
                          • 4734
                          I agree. Do you have a link to one of these testers that would work with LED as well? Thanks!
                          • redwire
                            • 3910
                            LightKeeper-Pro
                            https://www.homedepot.com/p/LightKee...3-CD/100686478
                            Actually, you might be able to use a NCV tester and just move along the string, as in the video. I haven't tried that.
                            • Spork Schivago
                              • Mar 2012
                              • 4734
                              LightKeeper-Pro
                              We have that Home Depot's LightKeeper Pro and just could never get it to work properly...we could only use it if we manually pulled a bulb and put it on the prongs, which didn't really work with LEDs...
                              • redwire
                                • 3910
                                The NVC tester is seeing the E-field difference between your hand and the probe tip. If your other hand holds the string close to Line or Neutral wire, or has no stray capacitance to ground, you get mixed results. Or if you hold the tester in your hand, far from the pcb and batteries it will not pick up much.
                                The old one I had was two prongs for the probe that went almost around the lamp, like a cup. It looked at the E-field inside the cup and didn't care or work as you moved along the string. Like a differential probe.
                                I've never seen a difference with (series) LED strings. But some strings keep working when an LED or lamp fails, they have extra parts.
                                Another way is to use an audio signal tracer and listen to the hum as you move the probe along the string. I have an LM386 box I use.
                                • Spork Schivago
                                  • Mar 2012
                                  • 4734
                                  I will try it again when we put up our christmas lights. I probably wasn't using it correctly! I have to admit, I never used it on LED lights. My father borrowed it once for his lights and I didn't realize they were LED. He manually pulled a diode and fry it each time (or have the polarity reversed and it wouldn't light at all).
                                  Thanks for sharing the info! I do have a probe generator / wire tracer. It only works on non-energized wires. It's the Fluke Pro 3000 Probe and Tune:
                                  https://www.homedepot.com/p/Fluke-Ne...-900/202290922
                                  • repair-it
                                    TOSHIBA DLP 52HM95 How to reset timer module on bulb
                                    by repair-it
                                    I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                                    Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                                    10-11-2023, 07:18 PM
                                  • ezenia
                                    LUMIMAN Smart Bulb IC ID?
                                    by ezenia
                                    I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                                    In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                                    04-28-2025, 05:56 PM
                                  • CapLeaker
                                    Dell ATX PSU won’t start, but forcing it works fine?
                                    by CapLeaker
                                    Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
                                    Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
                                    10-28-2024, 06:59 PM
                                  • rounin
                                    MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                    by rounin
                                    🛠 Original Issue
                                    ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                    04-19-2025, 01:18 AM
                                  • ex250
                                    Kenwood SW-505D no sound issue and pops from time to time when it works
                                    by ex250
                                    Hello mates,
                                    I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
                                    It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
                                    12-29-2024, 03:27 PM
