mosfet question
    Re: mosfet question
    As I indicated in post 14, more likely that the Gate drive outputs of the IC are bad (stuck on) so the new MOSFETs are damaged.
    • Brucetafer
      • Jun 2018
      • 133
      Re: mosfet question
      yep, you were right.. Ordered a new one! ill post up after its fixed (hopefully)
      • Brucetafer
        • Jun 2018
        • 133
        Re: mosfet question
        Welp bud you knocked it out of the park. I pulled that chip and its locked up cock stiff. Changed the mosfets and chip and works a treat... stupid cap must have totalled that thing.. amazing job, you just saved me 1500 bucks.
          Re: mosfet question
          Thanks for the follow-up on the repair.
          • petehall347
            • Jan 2015
            • 4440
            Re: mosfet question
            nice fix well done to all concerned .
            • Brucetafer
              • Jun 2018
              • 133
              Re: mosfet question
              well, i just picked up 2 more of these underwater scooters with the exact same problem.. they are eating the chip and mosfets.. any idea why? one is brand new in the box and is stuck on... the other is only 1 year old..
              • Thedoc298
                • Apr 2018
                • 6
                Re: mosfet question
                Originally posted by Brucetafer
                I have a seadoo RS1 seascooter that is stuck on and its pretty basic inside.. I have narrowed it down to a mosfet that is totaled, showing open on all 3 legs. part nmber is FB3306 on both but one has 012p and the other 904p under the part number.. does that make a difference or are they the same thing??
                I would take a picture but they one is barely visible under mag glass..
                Looks like if the fet is open, you device would not be stuck on, but stuck off.
                  master hoarder
                  • May 2008
                  • 12175
                  #28
                  Re: mosfet question
                  Maybe just bad design or assembly job that exposed the original parts to excessive stress??
                  How about your repaired ones? Are they failing too? If not, I'd say design or assembly flaw is the most likely case here.
                  • Jane
                    How do you test MOSFET in laptops ?
                    by Jane
                    I tried to use this method:
                    Testing an N-channel MOSFET:
                    Step 1: Discharge the Gate (turn off the MOSFET)
                    Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                    Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                    Step 2: Charge the Gate (turn on the MOSFET)
                    Now, place the red probe on the Gate (G) and the black probe on the
                    09-27-2024, 03:31 AM
                  • Nooy
                    VGA MOSfet permanently shorted and loss of MOSfet pad
                    by Nooy
                    Hello everyone, I recently found this badcaps site and super Learn Electronics Repair youtube channel. And I wanted to learn how to troubleshoot power supplies and VGA cards and how to practice soldering, since I already have a properly defective piece of them. I am currently trying to solve two problems:
                    I have a Gigabyte GV-RX460WF2OC-4GD type card. I managed to find the faulty MOSfet (AON6414A) on it, which I replaced. The card starts up, but after about half a minute, the MOSfet in the same position will be shorted again. Is it possible that the PWM controller driving the MOSfet...
                    02-14-2024, 02:26 AM
                  • redbaron1007
                    Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
                    by redbaron1007
                    I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
                    Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
                    09-09-2025, 11:10 AM
                  • AppleLover123
                    Asus X712EA 3 volts after the first mosfet
                    by AppleLover123
                    Hey guys,
                    i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                    I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                    Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                    I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                    Now i thought something...
                    12-15-2024, 07:49 AM
                  • MicroSMD Lab
                    by MicroSMD Lab
                    I used the same replacement part (purchased from Mouser) and I'm certain the soldering was done properly since it took just as much effort to remove as before. What could cause this same mosfet to fail? I'm thinking if it was unsuitable then the others would fail too. I looked for similar failures on YTube and the mosfet was replaced with AOE6930 in one instance and AOE6932 in the other but it's possible that the...
                    01-10-2024, 06:36 AM
