Help to identify a vintage IC
  • powermax
    • May 2017
    • 49
    Hi crews,
    I'm trying to repair a vintage computer circuitry that contains an unknown IC in the DIP-8 package. It was used in several Macintosh computers around 1993/1994.
    The IC in question is marked with the Apple logo and contains the following digits: '90 0120'. I attached a zoomed picture of the IC as well a schematic showing the related components.
    The IC in question (U12) could be an ASIC. But it could be also a custom version of some other IC like the Cuda MCU (U17) which is just a custom version of the 68HC05.
    The unknown IC (U12) is attached to a non-rechargeable 3.6V lithium battery. Its purpose is supposedly to manage the power source for U17 that implements a small nonvolatile RAM. U17 is therefore always powered either by the mains or the battery.
    Any ideas on what it could be? Did you ever see anything like this?
    Thank you in advance!
  • R_J
    • 9514
    Re: Help to identify a vintage IC
    I would guess its a Pram storage, similar to cmos time/date backup in a pc. S1 could be the clear "cmos" switch?
    It might help if we knew which computer etc. it is used in.
      • 30910
      looking at the schematic, it may be a serial sram.
      probably because that mcu is a poor choice with no internal eeprom.
      • powermax
        • May 2017
        • 49
        Thank you for the interesting suggestions!
        I know for sure it's used at least in Macintosh Quadra 840av and PowerMac 6100.
        Assuming it's a serial SRAM, what's your guess on the possible pin functions? From what I see in the schematic:
        1 seems to be +5 V power source + that strange S1 switch
        2 is connected to the trickle power (standby power) coming from the PSU
        3 is connected to PC1 of the MCU (data line)
        4 GND
        5 not connected ?
        6 is connected to PB0 of the MCU (another data line)
        7 backup battery (3.6V lithium)
        8 +5 V
        Well, U17 was probably a custom model of 68HC05 that does include 4096 bytes of programmable internal ROM and 368 bytes of RAM.
          • 30910
          1 reset
          2 +5v standby
          3 interface
          4 0v
          5 ??
          6 interface
          7 battery supply
          8 +5v
          • R_J
            • 9514
            Max801 or max808, looks like pin 8 output connects to R120 and R83 and maybe elswhere? S1 is likely refered to as the cuda switch
            • powermax
              • May 2017
              • 49
              Max801 or max808
              Yes, I agree that the unknown IC looks like a power supervisor thingy, similar to Max801/Max808 but not exactly. If I'm reading the schematics correctly, Cuda gets its power from our IC via pin 1, not 8. That's because Cuda's VDD is on pin 13.
              Pin 8 of U12 seems to be connected to +5V of the logic board.
              Bingo!
              • powermax
                • May 2017
                • 49
                Pressing S1 will short pin 1 to the ground and thus cut off Cuda's power efficiently resetting the latter. Right?
                • R_J
                  • 9514
                  U12 pin 1 seems to be connected to +5v (triangle with lines) Pin 2 via r112 (22Ω)to +5TRKL.
                  Without the complete schematic its hard to say where pin 8 (triangle) also goes other than where I mentioned
                  pin one +5v is not likely supply +5volts but a source with the (3line triangle)
                  • fab13
                    Need to identify a +ALJ component 022 nitendo switch Lite (Unknown?) shorted
                    by fab13
                    Hello everyone =D
                    After checking only this chip is shorted and does not start my switch Lite.
                    I removed this chip and the short circuit is no longer present.
                    Do you have any idea of the exact part number of this chip?
                    I can't find it anywhere on the internet
                    Reference +ALJ 022
                    How do you think it works?
                    Thanks a lot...
                    07-14-2022, 05:57 AM
                  • thesame
                    DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                    by thesame
                    Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                    The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                    02-27-2024, 04:31 AM
                  • SolomonMan
                    Vintage BK Precision 1403 Oscilloscope....
                    by SolomonMan
                    All,
                    Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
                    Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
                    I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor...
                    12-03-2023, 10:39 PM
                  • chth96
                    How can I identify varistor which have been blew up?
                    by chth96
                    I mistakely pluged 100v japanese retro game console to 220v outlet.
                    So It seems that glass fuse and varistor have been blew up.
                    I can identify that voltage and ampere value of glass fuse(250V LF 1.6A),but It is impossible to identify varistor type in my sega saturn PSU(YAMAHA 35M07U XR258)
                    Is there any way to identify varistor type in my sega saturn PSU?
                    Any reply would be appreciated.
                    EDIT:
                    It seems that I finally found out what type this black varistor is. It is Panasonic ERZV05D221 “ZNR” Transient/Surge Absorbers (Type D) Varistor Voltage...
                    11-26-2023, 08:52 AM
                  • Stachujones
                    Dell XPS 13 9370 unknown USB devices in device manager
                    by Stachujones
                    Hello, i bought a faulty Dell xps 13 9370 after installing windows in device manager i Can see 2 unknown devices, one is thingerprint reader because it dissapears after i unplug it and second one is i believe bluetooth because it also doesnt work and in bios there is no bt also.
                    Device manager says "unknown device, failed to request device descriptor"
                    Can somebody point me in right direction what to check?
                    I updated bios to the newest version and thunderbolt controller firmware still no luck
                    04-05-2025, 07:35 AM
