Linear PSU Pass Transistor Question.
  • maxbarjr
    • Mar 2016
    • 46
    • Philippines
    I made a linear power supply for HAM Radio use. The transformer has a secondary voltage of 18-0-18 at 240VAC input. Transformer has no labels or markings except for the primary and secondary voltages. The secondary wire size is 3.5mm. The transformer core dimentions are 11mm(h)x 8mm(d)x13.5mm(w). So no idea how many amperes the transformer was. Anyway, I made a 13.8vdc psu base on an Astron RM-50M schematics. The only difference are the pass transistors as I can't source the 2n3771 so I used the 2N3055x6 with 0.1 5W emitter resistor. Power supply works ok except that the pass transistors gets pretty hot at 1min keydown at 100W. Heatsink with thermal paste applied. Heatsink thickness is 3mm with fins. Any advice, suggestions to improve is welcome.
    Thank you in advance.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8707
    Re: Linear PSU Pass Transistor Question.
    Are you talking about a 100W (rated) transmitter or is your transmitter drawing 7.2 amperes at 13.8V? The former likely can draw 200W to transmit 100W radiated power.
    A transformer supplying 18-0-18 likely uses a 2-diode full wave rectifier and will supply about 18V RMS DC (25.4V DC peak at no load). This needs to be dropped to 13.8V.
    At 7.2A, the regulator would need to dissipate ~ 30W which would get warm, you probably can use a 40W incandescent light bulb as a reference to how hot they would get - though the 30W is spread across all the transistors and heat sink.
    If your transceiver is trying to transmit 100W RF, then it will likely be drawing double the above at 14.4A and would heat the transistors at a full 60W, now a 60W light bulb indeed gets quite warm.
    I would say this is "normal" if:
    - your ham radio is working
    - the output remains at 13.8V
    - the transistors stay relatively cool when not transmitting (I'd suppose most transceivers are no more than 500mA-1A when receiving, which should cause minimal heat-up of the heatsink.)
    100W is quite a large load, regardless if it's power draw or RF power radiated, and I would expect this heat-up.
    • redwire
      • 3912
      It's hard to know the transformer's rating and what voltage it is making. The core seems very small for steel.
      A chinese trick is to use too small transformer and full-wave bridge rectifier, so the DC voltage is very high at light loads, and then it sags under heavy load. The transformer's regulation is ~20%.
      Consider adding a cooling fan for this much heat.
      • maxbarjr
        • Mar 2016
        • 46
        • Philippines
        Thank you for your comments. Yes, it's a 100W RF transmitter. I should have added, intermittent transmit of 5sec on, 5sec off for 60secs to a 150W dummy load. Yes it goes to 2 diode for a fullwave rectification and filtered with a 64,000uF 40V capacitor. You are correct, on the peak voltage of 25.4V at no load. The regulator board is powered by a 1.5A separate transformer with 21-0-21 secondary to provide a 29V to the regulator circuit. Output so far is 13.85V without load, 13.80vdc with load (100W RF). Transistor get a bit warm when on receive. Idle current is about 1A. Does the 6 2N3055 pass transistors enought for this application?
        • maxbarjr
          • Mar 2016
          • 46
          • Philippines
          Not really very small transformer. It's very heavy. Maybe about 10kg. It's 4.5 inches tall x 5.5 inches wide x 3 inches thick.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8707
            Well, that's one thing, transformer getting hot versus transistors getting hot. Is the transformer getting hot too?
            But most likely this is normal for a linear dissipative PSU. How hot is "hot" and is the heatsink heating up (expected) vs just the transistors themselves (meaning your thermal interface needs work)? How good of a heatsink are you using - lots of surface area or just a flat piece of steel?
            This being said, you may have other issues: though 2N3055 is a readily available, its safe operating area as a PSU transistor is smaller than of a 2N3771. At worst, this means the transistors will blow earlier. You're probably close to the limit of the 2N3055's with your current application I think, while using 2N3771s would give you considerably more headroom.
              So you are using 6 2N3055 in parallel with each transistor has it own 0.1 Ohm resistor, so how hot are the transistors? What is the ambient temperature?
              Any pictures of the set up, especially the heatsink?
              What are the Voltage readings when measure between E and C, and the Voltage drops on the 0.1 Ohm resistor?
              • redwire
                • 3912
                Originally posted by maxbarjr
                ... The transformer core dimentions are 11mm(h)x 8mm(d)x13.5mm(w)
                OK cm not mm.
                Astron RM-50A rated 37A uses eight 2N3771's. About 29V no load and 25V full load from the transformer. 2N3771 has 30% better heat transfer from the die to the case compared to 2N3055 for the 150W vs 115W rating.
                2N3055 (assuming not fake) safe operating curve max. is about 10A at 12Vce but this is at 25C.
                It depends on your heatsinking- but count on getting 1/2 of that, once you add in the thermal insulator and grease and heatsink temperature, the transistor die is getting pretty hot.
                • maxbarjr
                  • Mar 2016
                  • 46
                  • Philippines
                  I used a Kenwood TM-281A at H power output of 65W into a dummy load. Here are some results of the measurements.
                  Between C and E: 10.2V with radio keyed, 12.5V unkeyed
                  Across the 0.1 Ohm resistor: 0.15 with radio keyed.
                  Temperature taken with a Fluke 287 meter and a Fluke 80BK-A probe: 140F 1min keyed.
                  Pictures of my homebrew power supply attached.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8707
                    Let me first say that your PSU looks nice. Much better than my homemade PSU (and my PSU isn't nearly as powerful either, only 2A!).
                    That poor transistor on the back is going to hurt, as that one is the worst cooled of them all! Is it just that one that's heating up badly? Is it just the steel part of the transistors heating up or is the heatsink also heating up with the transistors?
                    I also wonder if the diodes are hurting too, they would also be dissipating many watts too, but not as many as the transistors.
                    140°F is definitely in the concern zone but sort of expected with the current that's being passed. At 0.15V = I*0.1 I=1.5 amperes per transistor, dropping 10.2V =>15.3 watts (plus base current which adds another ~3%, so say 16W).
                    16W is a considerable amount of heat, and you have 6 of these transistors dumping 16W. Not sure if you've ever touched a CPU with the fan removed, they get quite warm too!
                    • maxbarjr
                      • Mar 2016
                      • 46
                      • Philippines
                      You must be referring the the single transistor at the back just above the output terminals. It warms up a bit but not much. This transistor is the Q100 that drives the base of the pass transistors. It is not part of the 6 pass transistors. The heatsink and pass transistors has almost the same temps when measued. The rectifiers are just warm being fitted on those copper bus bars.
                      Oh yes, I have been repairing computers before and have seen a cpu really smoking without the heatsink and fan.
                        • 31284
                        so an interesting question - that probably needs an experiment.
                        can you regulate the output by messing with the input.where the current is lower?
                        maybe by phase clipping with a triac based dimmer.
                        it works for switching psu's - why not linear?
                          140F (60c) at the case, may be OK, the safe junction spec is 150c is typical for 2N3055.
                          You can calculate the junction temperature if you know all other parameters.
                          You can study there here:
                          https://www.rohm.com/electronics-bas...or-temperature
                          https://cdn.badcaps-static.com/pdfs/...973d256525.pdf
                          https://cdn.badcaps-static.com/pdfs/...b33cb2f696.pdf
                          http://www.cypress.com/file/38656/download
                          https://toshiba.semicon-storage.com/...conductor.html
                          • kaboom
                            "Oh, Grouchy!"
                            • Jan 2011
                            • 2507
                            As for most TO-3s and some of the "flatpacks," which are usually 125c.
                            But this is without dissipation!
                            At TjMax, devices are derated to zero watts on the collector.
                            "pokemon go... to hell!"
                            EOL it...
                            All style and no substance.
                            guilty,guilty,guilty,guilty!
                            guilty of being cheap-made!
                              Heatsink.
                              • maxbarjr
                                • Mar 2016
                                • 46
                                • Philippines
                                Heatsink.
                                Thank you for sharing those documents. Very interesting. Thinking of adding 6 more 2N3055 on another heatsink mounted on the other side of the case. Will that reduce the heat on the heatsink and will it increase the power handing of the psu? Any improvement suggestions are welcome.
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8707
                                  The amount of heat is still the same, it's how much the heat is spread out between them.
                                  Is your heatsink getting warm or are just the transistors?
                                  • maxbarjr
                                    • Mar 2016
                                    • 46
                                    • Philippines
                                    Both the heatsink and the transistor. Measured the temps on them and almost the same.
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8707
                                      oh... if both are getting warm, then "working as intended" most likely.
                                      Yeah it's probably best to spread them out more and at least add two more transistors, should help keep it within range; unless you want even more current (and your diodes/transformer can handle it) - then even more transistors would be great. Watch out for base drive though that 2N3055 for base drive should be sufficient for even more pass transistors.
                                      • maxbarjr
                                        • Mar 2016
                                        • 46
                                        • Philippines
                                        Thank you.
                                        • learnmore
                                          Help choosing replacement transformer for Levoit 600S SMPS
                                          by learnmore
                                          Hello Community,
                                          I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                                          Peace
                                          LM...
                                          11-04-2025, 09:35 AM
                                        • CapLeaker
                                          Astron RS-7A/10A not regulating output voltage low
                                          by CapLeaker
                                          Either I am getting old or dumb, probably both.
                                          This “simple” linear power supply is driving me insane. Should be easy, right?
                                          Here is the story. Got that Astron RS-7A or 10A as stone dead. I mean turned on and got 0.00V not even an mV on the output. Why dat? Darn electrolytic output capacitor shorted at the binding posts. No, problem… new one in stock and mounted.
                                          Turned the PSU on again and now I got 0.1V on the binding posts. Everything clear like sunny day and replaced the LM723 regulator IC in the socket. Had it made, I thought....
                                          09-17-2023, 08:33 PM
                                        • mikey5791
                                          Is it possible for transformer substitution?
                                          by mikey5791
                                          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                          My questions are
                                          1. How do i test to see if the transformer is in good working condition?
                                          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                          Hope you guys understand what i was asking. My intention is...
                                          11-03-2022, 02:11 AM
                                        • dennis_elx33
                                          3PHASE STEP-DOWN Transformer in Check
                                          by dennis_elx33
                                          Hello All,
                                          i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                                          Problem statement: Power tripped Off
                                          Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                                          Action Done:
                                          1) Replaced the faulty parts with good spare.
                                          2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                                          12-02-2024, 06:52 AM
                                        • Mark R
                                          The Overseas Only Kenwood Model KR 790
                                          by Mark R
                                          I am Repairing this unit. It had many problems. One major one was the power transformer being about 4-5 volts low on the main B+ line which called for 66.5 Vols after the Main Filter caps but only showing about 62 Volts. Caps and the 5 amp Diode bridge were replaced which helped slightly.
                                          The other strange problem was the small secondary winding from the PT which supplies 18 Volts AC to the "FM FLUORESCENT DISPLAY" circuit, and the small winding that supplies 8 Volts AC to the push button grain of wheat lamps. Those voltages were down from 18 Volts to 16 volts. Which was...
                                          09-23-2025, 08:27 PM
