Any way to improve distance of toy remote control car?
  • Sparkey55
    • Jan 2010
    • 1523
    Re: Any way to improve distance of toy remote control car?
    Originally posted by eccerr0r
    Well, then need to know what's expected behavior for this device, should it really be conking out at 10ft?
    Not sure if bandages like antenna hacks or preamplifiers should be done to fix an underlying problem like battery weakness or improper tuning.
    I do not know. Could just be designed that way or may need fresh batteries. Most of these really cheap toys (<$20) skimp on parts needed to "tune" for optimum performance to save a few cents on the Dollar. Cheap 27Mhz or 49Mhz crystals that drift like Trump in a porn cenvention. Maybe a 60Khz to 100Khz or more bandwidth on the carrier. This is not competition grade race cars here.
      • 31157
      try a foot-long bit of spring-steel wire on the car.
      it's what they used to come with.
      • Sparkey55
        • Jan 2010
        • 1523
        Read the thread completely, I have posted that solution above.
        • caphair
          • Nov 2011
          • 1249
          Finally had some time to take this thing apart and check out the antenna. It's just a square piece of paper with a shiny side that's connected to the antenna wire. Other side is non reflective and glued to the plastic.
          Could I just replace it with a coiled piece of wire?
            • 31157
            replace it with a vertical wip, your trying to catch waves, not just match the frequency.
              master hoarder
              • May 2008
              • 12175
              • Bulgaria
              #26
              Originally posted by caphair
              Finally had some time to take this thing apart and check out the antenna. It’s just a square piece of paper with a shiny side that’s connected to the antenna wire. Other side is non reflective and glued to the plastic.
              Wow, I've never seen an antenna like that in a cheap RC before, and I used to have (and play) with quite a few when I was a little younger. Most of my *toy* RCs are from the late 90's / early 2000's, and they all come with typically a 15-30 cm (0.5 to 1 foot) straight antenna (sometimes just wire in a straw). Many of these RCs got about 10 meters / 10 yards of range or a little more in my town neighborhood. This was back before WiFi and Blutooth had become popular, though. So I'm not sure if that has changed anything nowadays.
              That said, I do have one old Tyco RC (called "Jacknife", IIRC) that had an integrated antenna, which basically consisted of a long wire ran along the whole body of the car in a loop. Some years later, I was repairing one for a friend's kid, and that RC had a metal circular loop antenna inside - about 6-8 cm (2.5-3 inches) in diameter. I don't remember what kind of range that one got, but it wasn't bad IIRC.
              Anyways, you can try replacing that current "antenna" piece with something else. I'd sat a long piece of wire would do just fine for testing. But if that doesn't appear to do anything, it could be indeed like Sparkey55 mentioned: just bad design. And of course, fresh batteries are absolutely a must with these.
              One more sidenote: going by the pictures you posted, your receiver board looks very familiar to one of these on eBay:
              https://www.ebay.com/itm/4CH-40MHZ-R.../202425771105?
              These are much newer than the ones I have in my late 90's / early 2000's RCs (none of them have SMD components). So I just cannot attest to how good or bad these are. But I can tell you that my older toy stuff with longer antennas didn't perform too bad... save for some of them frying a few BJTs on the motor outputs (at least the ones that came with all TO-92 stuff).
              *EDIT*
              Talking about toys... I just hit post # 8448. That's the dream LEGO Technic car of my childhood. Ironic coincidence?
              • llonen
                • Sep 2014
                • 495
                • hampshire
                #27
                I used to get upto 40 meters on similar rc stuff in the past outside mind you, so look at the transmitter crystal then check with a frequency counter and look at the amplitude with a scope see whats coming out.
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Are you sure that's an antenna, looks like a grounded shield for the PCB? What's it look like on the other side of the PCB?
                  • tmhobadcap
                    Pioneer VSX-522-K remote control not working???
                    by tmhobadcap
                    I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
                    At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
                    12-24-2020, 01:44 AM
                  • piipo
                    Old Privileg 5.1 speakers remote control question
                    by piipo
                    Hi, I have an old Privileg brand 5.1 speakers. I have lost the remote control. I have an universal Harmony remote but there is no Privileg brand in it's software to add. Does anybody have an idea what alternative brand for a remote can I try instead? I'm attaching an image of what the speakers looks like. The image shows 2 main speakers, they are 5 + 1 in total. Thank you very much
                    09-18-2024, 01:55 AM
                  • hemant_2222
                    Schematic for Denon Remote Control RC1156
                    by hemant_2222
                    Hello Everyone,
                    Hope everyone is enjoying their repairs at hand!.
                    I am looking forward to get the schematic of Denon remote control RC1156. Actually long time no use of the remote leaked the battery thereby corroding few parts as well as the tracks.
                    I was able to join few of them but the remote is still not working, so i am looking forward for your help, in case anyone understand the schematic or the remote circuit diagram and could me assist me in repairing it.
                    Please refer to the attached picture, i think the voltage divider is missing...
                    10-06-2023, 02:05 AM
                  • dfear
                    hitachi 75hl16t64u - not responding to remote control
                    by dfear
                    I have a hitachi 75hl16t64u tv in for repair and it is driving me crazy.
                    It came in for a power issue which I have finally resolved by replacing the power supply.
                    The current issue is that the TV does not respond to the remote control. I have replaced the IR sensor board with a used one but the fault persists.
                    Anyone have a clue how to fix TV?
                    FYI: I have checked the remote work s by pointing it at my camera on my phone....
                    09-02-2024, 12:15 PM
                  • wolf1976
                    wireless receiver for 6 speeds fan control with remote control
                    by wolf1976
                    hi i have a receiver that is destroyed from the overvoltage i guess
                    my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
                    the motor fan has not label
                    i have an other receiver operational
                    In your opinion can i measure the voltage at the output ?
                    what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
                    thanks in advance...
                    07-23-2025, 03:12 PM
