120 volt ( AC LED Clip-on Lamp ) 48 volt LED module Hack
    • Jul 2011
    • 6057
    I found these LED lights at Walmart for $3.50 Clearance priced
    I know ( I have to hit the Clearance items just about every time I am in this store )
    I took one apart it does not have the best power supply board but the LED module is very nice with heat a sink
    I bought 11 of them for a lighting project I going to do very soon
    The bendable flex rod is very nice the biggest complain is that the clamping clip is made of plastic
    Which probably only for a little while the plastic cover for the LED module and switching power supply is made from same cheap plastic
    The plastic that on this item is crap to say it nicely
    Re: 120 volt ( AC LED Clip-on Lamp ) 48 volt LED module Hack
    It looks like line operate non-isolate single transistor buck converter, fusible resistor for the AC inout protection, since the 6 LEDs are connected in series, the output is around 18V or so.
    Not bad for $3.50 to play with.
    How bright is it? I may get some at my local Walmart.
    Do you have pictures of the box?
      BTW, since those LEDs are mounted on the heatsink, if there is insulation breakdown on that heat sink, the heat sink will be at Line Voltage so be careful on how you handle the heatsink.
      I wonder what AC V you have if you measure between safety GND and the heatsink.
        • Jul 2011
        • 6057
        No the operating voltage is 49 to 51 or so volts not 18 volts
        The ( LED module ) has 3 small LED in one module is my guess
        The out put cap is rated for 160 volts DC on the power supply board
        I will check the the heat sink isolation to the power rail sometime today I hope
        I have one question can these power supplys run with very low current load or no load so I can measure the working voltage
        ( I have not played with this type of power supply module at line voltage ( 120 volt AC )
        I have played with this type power supply boards but at lower voltages before
        I going to use a table top 48 volt switching power supply to power them
        Use these power supply for something else later
        The brightness is decent for it size as long as you do not put to much current to the module otherwise it heat up very quickly
        When I run the LED module at 48 volts the brightness is decent and the heat sink module stays cool to the touch
        Now when you go to 49 volts the heat sink module start to get real warm and brightness is a lot more but I am not going to drive them that hard
        I will take a photo of the box later on today
        This is the type of power supply that I going to use to power these LED module with
        http://www.mpja.com/48VDC-208A-Adapt...info/32492+PS/
          • Jul 2011
          • 6057
          Here is a photo of the box
          I have a correction to make on the voltage for the LED module at 48 volts it is than 10 milliamperes at 51 volts the milliamperes is about 20 and dose start to get warm
          The power supply that I am using only goes to 51.5 volts
            • Jul 2011
            • 6057
            Here are the results of this test
            At 48 volts to run the LED module one lead of the meter to the heat sink and the other lead to the positive terminal of LED module there is a little over 12.5 volts
            This is a good reason not run this LED module on this type of buck converter
            When I look at this power supply module I had not seen this setup before and decided not to use them for my lighting project
            Thank you for pointing out what type of power supply this is and the part about leaking voltage to the heat sink from the LED module
            Now if you were to use it way it build it might not be a problem
            But I am going to mount these LED modules in a metal housing
            this would a problem
            I going to a insulation disk that are used in mounting t220 devices to heat sinks
            to keep from having problems with voltage feed back to the power supply
            I going to use something like this in the link below
            https://www.cpumedics.com/10thcocobl...SABEgJ5_PD_BwE
              Testing the AC Voltage as in original power supply you want to test is between heatsink and AC outlet safety GND, not to the LED connection.
              If you are going to mount in the metal case then you need safety GND which will be 3-prong AC plug unless your power supply is well made.
              Use current limiter of some sort, do not connect the LED to the power supply directly, the current draw of the LED is not linear, it will not take much Forward bias Voltage increase to shoot up the LED current draw.
              You should measure the current draw of the LEDs as they are with its power supply to find out what it is first since we do not know the spec of the LED.
                • Jul 2011
                • 6057
                I will try to do this maybe tomorrow if I have time after work
                  • 31142
                  power it up with the original supply, and read the voltage across one led.
                  then multiply it by 6.
                  then set your meter to current and put the probes across one led - see how hard they get driven.
                    You will put the DC A meter is series with either one of the two LED wires to read current.
                      • 31142
                      i was interested in the individual leds actually.
                        They are connected in series. If one LED is bypassed by the AMP meter then the current may go up big time if the constant current circuit cannot handle one bypassed LED, OP can try and find out.
                          • Jul 2011
                          • 6057
                          UpDate
                          I have made a light bar with these LED modules that I got from Walmart for $3.50 each there 18 LED modules
                          This light bar is for my new table that I made for my shed
                            • Jul 2011
                            • 6057
                            UpDate for LED module power supply
                            I going to make LED module for outside yard light and use a few of them
                            I will post it when I get started
                            I will have to take one of them and see how much voltage and current that this module put out and I will post it when I have the results
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              I guess keep us updated how long they work. I find that cheap LED module assemblies don't last more than a few years, if even that much. The cheap flexible 12V LED strips from eBay (and elsewhere online) usually die within 6 months @ 12V, simple because they are driven too hard (120 Ohm resistor in series with three series LEDs). At 9V, they work just about right. Not as bright as at 12V, though.
                                • Jul 2011
                                • 6057
                                Here are the results of the LED module has
                                The following
                                51 volts @ 62 milliamperes
                                51/6=8.5 volts @ 62 milliamperes
                                So if the Individual LED has 3 small LEDs in it 8.5/3=2.333 I have seen some white LEDs that there work voltage is 2.3 to 2.5 volts these are not normal
                                Which really does not make sense at all 62 milliamperes for one single LED on this module the heat sink could not handle that heat it gets warm very quickly I checked
                                I will be running at 48 volts @ 20 milliamperes which more realistic for this heat sink
                                I was going to use one of these for a night light but now I do not think so with out modificating the power supply or something
                                  • 31142
                                  if you want a cheap linear strip, look on banggood.
                                  like these - various lengths and colour-temp.
                                  https://www.banggood.com/17cm-3W-600...p-1017718.html
                                    The following
                                    What does the DC meter show when you measure the DCV right between the two legs of each LED?
                                      • Jul 2011
                                      • 6057
                                      I will have to do this maybe next few days but it not going to be easy to do
                                        You can easily see the solder joint of the LED, especially the one that is connected directly to the input wire.
                                        • AlexVG
                                          Replacing the WiFi module on a vacuum cleaner iROBOT i7
                                          by AlexVG
                                          I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
                                          I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
                                          (This board does not respond, only the LEDs light up in a circle.
                                          The liquid damage is catastrophic and restoration is impractical).
                                          (I bought this board to get the WiFi module and camera).
                                          The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
                                          If...
                                          10-22-2024, 07:20 AM
                                        • Yanleb
                                          Sharp LC-60LE810UN Lamp Error
                                          by Yanleb
                                          I have this Sharp LC-60LE810UN that stays off and blinks a Lamp Error (1 long flash followed by a short flash, in a loop).
                                          I already confirmed that the first backlight strip has an open LED using a LED strip tester. The other 3 LED strips are fine.
                                          Before tearing the LCD panel apart, I want to make sure that the rest of the TV set is good. I've tested the power-supply/LED inverter board by sending 5 volt to PS-ON, to PNL-POW (that commands power the T-CON board only), OFL and STB pins. The power-supply is good.
                                          I've tried all the key...
                                          08-24-2021, 11:48 PM
                                        • m1ch43lzm
                                          70mai Dash Cam A510 - help identifying connector on camera module
                                          by m1ch43lzm
                                          Hi everyone
                                          I have a 70mai Dash Cam A510 which failed after about 3 months of being installed in my car, likely due to heat, i got it from aliexpress so no point in trying to return it for warranty (and shipping it back would cost me almost the same as a new one from ali)
                                          The camera would boot loop showing 70mai logo on the screen, sometimes it would boot fine then the live view would freeze or display purple lines
                                          I already took it apart, and found out that the camera boots fine if i unplug the camera module from the main PCB, sometimes "playing" with the connector...
                                          05-11-2025, 06:02 PM
                                          Light that has a bug zapper in bottom section of light fixture the LED light module took a crap but the zapper still works
                                          by sam_sam_sam
                                          So I got the bright idea to remove the LED light module from the fixture and put it on top of another enclosure and keep using the zapper
                                          The removal of light module was a successful and now I just have to cut a hole in the enclosure and put a power cord that has an on and off switch on it
                                          You are lucky to get about two years of service out of one before the LED module starts flicking and just stops working because it is mounted on an aluminum plate and these are hard to solder on it and it is not worth messing around with them and especially this one because it has line...
                                          09-07-2024, 07:26 PM
                                        • vestaviascott
                                          Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
                                          by vestaviascott
                                          Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
                                          Here's what happens:
                                          1) Power on
                                          2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
                                          3) Blue status light flashes for appx 4 minutes...
                                          07-29-2020, 06:08 AM
