Need advice from experts for a cmos battery replacement
  • kamel
    • May 2011
    • 129
    • TUNISIA
    Urgent!
    My MTX 3352 digital oscilloscope cmos battery got low and need replacement.
    Original battery specs : varta brand Li-Manganese dioxide With PCB solder tags
    1/2 AA 3V-950mah, non-rechargeable battery.
    Found available on the market : NX brand Lithium-thionyl chloride ER14250 1/2 AA 3.6V 1.2Ah PP (Ref : PCL9005) without solder tags.
    Question : Is it risky to use the 3.6V 1.2Ah battery instead of the 3V-950mah ?
    If so, do I need to use a diode to drop the +0.7V excess and then what about the +250mah ?
    Or is there any simpler and more efficient circuit to fit the 3.6V without risk for my oscilloscope.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8706
    Re: Need advice from experts for a cmos battery replacement
    I think you should use the correct voltage if you can. I have a Tektronix 2440 that I had to replace the battery in - I tried 2xAA-alkaline, 3xAA-alkaline, LiMnO2 -- none produced satisfactory results (scope keeps complaining) until I put in another Li-Thionyl Chloride battery into it like the one that got replaced.
    If you must use the 3.6V, you may be able to just stick that silicon diode in series, and other than mechanical fitting it should be fine.
      The load dictates the current draw from the battery so in this case higher Amp rating of the battery has no effect.
      Yes you can try using 1 or may be two diodes on the output of the battery, the Vf of the diode will depend on the If and the temperature, etc.
        • 31277
        Lithium Thionyl chloride are rechargeable cells - totally different tech.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8706
          Lithium thionyl chloride is not rechargeable... it's an old high capacity, high internal impedance, low leakage lithium technology designed for memory backup.
          Lithium ion and lithium polymer are rechargeable.
            • 31277
            pretty sure i have a tube of lithium thionyl rechargeable cells here from server raid cards!
              https://www.eetimes.com/author.asp?s...doc_id=1322276
              • kamel
                • May 2011
                • 129
                • TUNISIA
                I wish to thank every contributor.
                Problem was solved by soldering a 3V Li-Manganese dioxide battery 1200A instead of the 3V-950mah with PCB solder tags, and gluing the battery to the mobo for better security.
                Please note that the initial issue was my oscilloscope refused to turn on : it always went to sleep mode, when switched on. Replacing the cmos battery solved the issue. This might help others having same problem.
                • Genghis_Khan
                  ThinkPad T470p – CMOS Checksum Error Persists After Main Battery Removal (even with new CMOS)
                  by Genghis_Khan
                  I’m currently troubleshooting an issue on my Lenovo ThinkPad T470p (Type 20J6) and would really appreciate any insights or solutions.
                  Issue summary:
                  Whenever I remove the main laptop battery and AC adaptor, then place them back, the system gives a “CMOS checksum error” at next boot, and the BIOS clock resets to its default time/date.
                  However, the RTC works fine as long as the main battery remains attached — even if the laptop is unplugged for hours. Same as I remove the battery while the AC is attached, RTC remains. Obviously,...
                  Yesterday, 11:51 AM
                • questore
                  XPS 13 9370 CMOS battery voltage always low
                  by questore
                  Hi Everyone,
                  I have brought you a mistery item
                  This laptop have come with some strange faults.
                  1. CMOS battery was flat 0v
                  Symptoms:
                  - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
                  Amp drawing was stuck at 0.005 milliamps.
                  - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
                  After inverstigation RTCD1 diode had a low value...
                  09-30-2025, 05:47 AM
                • Bowline
                  by Bowline
                  06-11-2025, 10:13 AM
                • mferna14
                  MacBook Air A2681 battery problem after Screen Replacement
                  by mferna14
                  Hi, my dear friends., Maybe this might be a stupid question or something I missed or do not know. I have 2 MacBook Air A2681 (Indentical color & EMC #), both LCD screens broken. Before ordering the LCD Screens I confirmed both worked with their respective batteries & AC Adapters, & they did 100%. The LCD Screens came in today & I replaced LCD for the 1st A2681. (Removed Battery Terminal cable for both Laptops before installation of LCDs). Perfect Screen & Booted up fine. But it did not work with battery. I checked the battery connector & it was seated in well/perfectly....
                  12-06-2024, 08:10 PM
                • dhenion
                  Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
                  by dhenion
                  I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
                  The original board was:
                  ASUS X510UNR REV 3.0 A
                  The replacement board is:
                  ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
                  It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
                  01-30-2024, 01:45 PM
