Is Magnaxox really that poor quality?
  • Fud
    • Mar 2009
    • 62
    I'll keep to the point. I have a Magavox 42 in LCD model # 42MF531D/37 . One day the screen started flashing then went out. The power light just kept flashing over and over.
    So I took it apart and found blown Capxon caps and replaced them with another brand same specs and everything. Nothing else on the power supply looked burned or buldged. So after recapping and turning it back on the audio worked but no picture at all just black but the power switch doesn't flash now at all like when it totally failed.
    Been reading this is a common problem with magnavox/phillips dying right after warranty.
    What would be the best approach to this? Changing out the whole power supply and hope that solves it instead of getting a technician to charge a fortune just to look at it then sit in the shop for a month.
    On a side note a dell monitor powers up sometimes then goes black too then back on sometimes. I tried to take it apart but can't for the life of me figure out how to get to the PSU of it even after prying they back off where it spaps in. It's like everything inside is spot welded together with no screws hardly. That is a 21 in flat screen Dell and would hate to throw it away or the TV if it can be fixed without some shyster charging 500 bucks to do each of them.
    Any help would be appreiciated.
  • sofTest
    • Aug 2008
    • 361
    Re: Is Magnaxox really that poor quality?
    You only replaced the visually bad capacitors? If so, you should try replacing the others also.
    Be a mensch
    • Fud
      • Mar 2009
      • 62
      Well all the radial ones were replaced
      Even the one that didn't look bad, the transformers looked kind of yellow aged the wrapping but didn't look burned at all. Someone told me the backlight could have burned out then someone else said you can still see a picture if that is the only thing that goes just very dim.
      So obviously there is no power going to the screen just the audio. I'm not even sure where to start tracing this other than the PSU or replacing the whole board instead hoping that might work.
      • Logistics
        • Apr 2007
        • 721
        I thought the test for seeing if the backlight was broken was to shine a flashlight at the screen to see if there actually is video.
        Presonus Audiobox USB, Schiit Magni 3, Sony MDR-V700
        • Toasty
          • Jul 2007
          • 4171
          The "Old Heads" will remember Maggotboxes.
          Pics please. WE LIKE PICS!
          veritas odium parit
          • Fud
            • Mar 2009
            • 62
            The only pic I have now is from the actual psu from a website. It doesn't show much just what the board looks like. the three on the type right were Capxon and the other on the bottom right the same just a different voltage.
            Oh Toasty I love that rambocat.gif and have been using it on other forums for a while.
            • Toasty
              • Jul 2007
              • 4171
              >>Oh Toasty I love that rambocat...<<
              TY!
              But does yours carry Ltec frag grenades? Or, Rulycon* incendiaries?
              * Not to be confused with Rudycon gas cannisters.
              veritas odium parit
              • Wizard
                • Mar 2008
                • 2296
                Show rest of the picture of this tv with back off please to see if it is really philips or not.
                Philips does make their own boards and PSU and use P-LG panels but i know they do contract with other generic makers.
                Cheers, Wizard
                • Toasty
                  • Jul 2007
                  • 4171
                  Do what Logistics said - "shine a flashlight at the screen to see if there actually is video."
                  Better to use the attachment feature instead of the image link. Dang pic is huge and messes with the topic. Ugh!
                  Look around on the board for a tiny black fuse. May look like a resistor, but will be marked similar to "F201". It's found on several others and yours may have one too. Might even be that brownish-red piece right in front on the pic. You'll need an ohmmeter to check continuity. Unit unplugged please, lest you look like the cat.
                  When you can - a down shot of the board is better for us to see components.
                  Purchasing a new board will get you going. Then you can mess with this one as time permits. How short is your fuse and what's your time worth???
                  veritas odium parit
                  • Fud
                    • Mar 2009
                    • 62
                    This is really, really embarrasing
                    I took the back cover off to take detailed pics of all the boards and wires, then i noticed a lead under the cover that i overlooked and didn't plug in. Man I feel so stupid wasting anyones time here since you are so helpfull. But you can smack me around if you like because I deserve it.
                    Good news is the recap worked and it's working like new now. I knew something wasn't right when doing the flashlight trick and still nothing then suspected a lead not plugged in
                    Thanks for putting a forum up like this for novices and advanced alike.
                    You rock.
                    • Toasty
                      • Jul 2007
                      • 4171
                      Yup, been there, done that!
                      Good job!
                      veritas odium parit
                      • Wizard
                        • Mar 2008
                        • 2296
                        Excellent and post pictures!
                        Cheers, Wizard
                        • howardc64
                          UN55NU7100F failed edge lit LED bar, poor quality replacement LED bar AND bulging cap on PSU
                          by howardc64
                          Just typical LED bar failure repair but discovered a couple of things worthy of posting
                          PSU had a bulging cap (470uF 25V). Likely AC/DC bridge rectifier filter. Have seen a ton of 470uF bridge rectifier filter failures on a bunch of difference devices (not just TVs) Stock up on 470uF 25v 35v
                          2nd thing worth of note is after all the work to replace edge lit LEDs. Discovered 2 LEDs with phosphor coating differnce produing slightly differnet color temp. Result on edge lit TV = dark veritical band Can't detect when testing the LED bar along...
                          10-13-2025, 05:56 PM
                        • mikey5791
                          Need help to replace burned resistor in 350w atx psu
                          by mikey5791
                          Hi to all forum members,
                          Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                          The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                          Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                          Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                          12-26-2024, 04:55 AM
                        • DXseekerMO
                          Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
                          by DXseekerMO
                          Hello everyone!
                          Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
                          I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
                          Yes
                          0%
                          1
                          All backlight strips are the same quality
                          0%
                          1
                          No
                          0%
                          0
                          12-16-2021, 03:58 PM
                        • corrize
                          Identify a burned component in Gimbal Zhiyun smooth-q3
                          by corrize
                          Hello, in this device, there is a chip (managing battery I guess) burned.
                          I can’t read the full marking code because it is really damaged/burned.
                          With a best pictures, I deduced that :
                          8HA (or 5HA ?) and probably not 2HA or EHA or BHA
                          K20
                          296
                          But I can’t find a component on the web with these marking code. Do you know what it is please ?...
                          11-12-2025, 02:57 AM
                        • coinwizx
                          Burned out PSU Corsiar HX1200 and NZXT C850, connected to wrong Molex/Sata cable from EVGA.
                          by coinwizx
                          Anybody has experience repair PSU burned out due to connect to EVGA molex/sata cables. I know the cable is not compatible (i got them mixed up), but I though i can connect it and use a PSU tested to find out which is the wrong sata/molex cables. As soo as I pluged in the powered molex cable to the PSU tester, the power supply short out, and will not turn on anymore. After the incident, the PSUs (both HX1200 and C850) try to power on and shut itself off immediately. The ATX PSU tester survice the short circult, still working perfectly. Anybody know if it's an easy fix or know which parts...
                          09-09-2025, 03:11 PM
