Burned out PSU Corsiar HX1200 and NZXT C850, connected to wrong Molex/Sata cable from EVGA.
  • coinwizx
    • Sep 2025
    • 5
    Anybody has experience repair PSU burned out due to connect to EVGA molex/sata cables. I know the cable is not compatible (i got them mixed up), but I though i can connect it and use a PSU tested to find out which is the wrong sata/molex cables. As soo as I pluged in the powered molex cable to the PSU tester, the power supply short out, and will not turn on anymore. After the incident, the PSUs (both HX1200 and C850) try to power on and shut itself off immediately. The ATX PSU tester survice the short circult, still working perfectly. Anybody know if it's an easy fix or know which parts need replaced? Possible just an internal fuse burned? Thank for helping.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8354
    Usually the PSU survives, but the HDD / SSD etc not. Done the same thing before. I made a thread about it 9 years or so ago here on badcaps. Oh! You used the wrong cable on the ATX tester? Hmm… I think it’s either the 5V or the 12V rail that’s a goner.
    First off make sure nothing is connected to the power supply, jump the green (PSon) wire to black (GND), then plug in the power supply to power mains and see what happens. Measure the orange, red and yellow wires against the black (GND). Just one wire from those colours.
    If it doesn’t turn on, the supervisor IC detected a fault on one or more power rails and that isn’t just a fuse problem rather a diode or something else.
    I’d suggest you making 2 threads, one for each PSU. Open it up and upload some nice straight shot high resolution pictures, so we can see something.
    • Agent24
      I see dead caps
      • Oct 2007
      • 5112
      • New Zealand
      The wrong HDD cable itself shouldn't damage the power supply, but if Ground and some power rails were swapped in the cable pinout...
      What you have normally on a HDD cable is 12v and 5v plus ground going into the PSU tester, and two of those pins are ground, and assumed to be connected together.
      But if the cables that were meant to be ground, were actually 12v and 5v, well now you got 12v rail and 5v rail shorted together at the PSU tester on what is supposed to be a ground connection, and quite possibly the power supply has back-fed 12v into its own 5v (or even 3.3v rail if it's a SATA connector) and something has been damaged on the 5v or 3.3v rails, either the monitoring circuitry or if the PSU uses DC-DC converters for the 5v and 3.3v, maybe that instead or as well.
      That's going to be a fun one.
      You're going to need to start posting photos, and find out which rail(s) aren't working anymore
      -David VanHorn
      • kotel studios
        • Dec 2024
        • 206
        • Poland
        Another cause for your issue of them not wanting to power on, is that the OCP/UVP kicked in and needs to be reset. Usually it's enough to cut mains power to the PSU and wait a few seconds before powering it on again, but I suspect you have waited out at least 30 sec before you turned them on again...
        • coinwizx
          • Sep 2025
          • 5
          David analysis is right. The 12v back feeded to the psu own 5v damaged something inernally, now the psu try to turn on, but internal monitor circuilt shut itslf down when try to power on. I got no reading on 5v and 3v, but 12v has split second of power, then shut off itself as i turn the power on. I saw the fan span for a few seconds The power supply then will not turn on again until it reset a few minutes later. So, the question is if this possible an easy fix? if yes, i will open them up...if not, then i may RMA them..
          • coinwizx
            • Sep 2025
            • 5
            • Agent24
              I see dead caps
              • Oct 2007
              • 5112
              • New Zealand
              It may be easy to fix, it may be not.
              You won't know until you open it.
              -David VanHorn
                • 31316
                and post pictures
                • coinwizx
                  NZXT C850 connected w EVGA molex cable, 12V pin back feeded to 5V. Anybody has experience in this damages repair?
                  by coinwizx
                  The power supply is 2024 newest version of NZXT C850 modular power supply.
                  Cause of damage: I connected EVGA molex cable to the Sata port and test it with a ATX tester. Since the pin out on the EVGA is wrong, result in the 12V pin shorted to the 5V pin, in the 12V back-feeded to the 5v port.
                  Damage: Power supply shorted out, shut off itself internally, damaged the 5v or 3v rail or the monitoring circuitry. The self protection circuit shut off the power supply when power up because it detected some abnormal/defect. I waited a few minutes, let it self reset then...
                  09-15-2025, 12:44 PM
                • coinwizx
                  Corsair HX1200 connected w EVGA molex cable, 12V pin back feeded to 5V. Anybody has experience in this damages repair?
                  by coinwizx
                  The power supply is 2020 Corsair HX1200 modular power supply.
                  Damage: Power supply shorted out, shut off itself internally, damaged the 5v or 3v rail or the monitoring circuitry. The self protection circuit shut off the power supply when power up because it detected some abnormal/defect. I waited a few minutes, let it self reset then try to re power up....
                  09-15-2025, 12:46 PM
                • onix331
                  EVGA RTX2070 Weird power stage/I2C issue
                  by onix331
                  Asking here as a last ditch effort:
                  GPU: EVGA RTX2070 Black Edition XC Gaming
                  A few weeks ago i noticed a burning electronics smell in my room, after a bit of confusion i realized that the RGB LED light of my GPU was out. Weird.
                  I didn't think much of it until i tried to look at the power usage in HWinfo, i then noticed that the entry "GPU Power (Total)" was gone entirely, it would also not boost above 1410Mhz.
                  Looking further i noticed that "Performance Limit - Utilization" was always at "Yes". The card did perform mostly...
                  05-27-2024, 08:34 AM
                • s_henya
                  EVGA GTX750TI BIOS Request
                  by s_henya
                  Hi guys,
                  Got this EVGA GTX750TI 2GB GPU
                  MB Bios is beeping when GPU is connected.
                  When booting with onboard GPU, MB is booting but the GTX isn't showing in windows device manager.
                  I would like to reprogram the bios EVGA 750Ti 2GB non-6pin 82.07.55.00.50
                  I searched around but couldn't fins 256kb BIOS like mine.
                  Anyone can please assist?...
                  05-05-2024, 12:30 PM
                • competition
                  Replacing capacitors in Evga PSU
                  by competition
                  I have Evga G2 1300w and I want to replace all the electrolytic capacitors because PSU is already 12+ years old and I want to give it more life before any capacitor does damage. There are no blown capacitors, but I want to protect myself by replacing them with new ones as a precaution. And now comes the main problem. I have 5 pieces of Bulk (I think they are KZE) 16v3300uf with dimensions 10/35/5, but I can't find them in that size, only 12.5/35/5.I have one KY 16v1000uf 8.5/19/3.5, one KY 16v220uf I think it is 6/13/3.5 but it is in holes of pitch 5 I have 4 pieces of KZE 16v2200uf with dimensions...
                  11-14-2025, 11:12 AM
