MSI GE62VR, MS-16JB burned motherboard
  • myth77
    • Feb 2017
    • 380
    • Croatia
    I received this laptop, no history and the motherboard was in short circuit on main power rail. Then i noticed that motherboard literaly burned in one part...near the capacitors PC85 and PC86...there were almost 5 mm burned part of the board
    That part and capacitors are on PWR_SRC_FBVDDQ rail...and that is main rail powering FBVDDQ mosfets. It was shorted to gnd. Then i cleaned everything, cut all that was burned and with microscope inspection couldnt find any part touching or burned. The resistence is now only 58 ohms relative to GND and that is not good for main power rail. Then i removed U30, U24, U23, PQ25,PQ23, PEC12,PEC10 and PC134 and on PWR_SRC_FBVDDQ i have resistence 58 ohms relative to GND and on all other main power rails readings are in killoohms.
    So, i checked with multimeter is there a short between PWR_SRC_FBVDDQ power rail and any other on the board but there is not...it is just showing 58 ohm resistence to ground but it seems it is not conected to any other rail on the motherboard (with above mentioned smd components removed).
    So i dont get it? maybe it is still touching somewhere something..but then i would have multimeter beep?
    Have anyone else repaired burned motherboards or/and have any other idea?
    I attached boardview.
  • reformatt
    • Feb 2020
    • 1513
    Re: MSI GE62VR, MS-16JB burned motherboard
    They're multi layer boards, burning can potentially create a short or leakage to a ground plane. Rule out that you don't have shorted CPU drivers and CPU itself before you start wasting your time.
    • myth77
      • Feb 2017
      • 380
      • Croatia
      No short on cpu, gpu, pch...i checked. I believe i probably have leakage to the ground...but i can not determine where...
      • myth77
        • Feb 2017
        • 380
        • Croatia
        Ok, finally i made it....I used a very small rasp (file) and gently use it on those thorn layers of burned place on motherboard...that way i removed rough cooper edges of the layers....and made them smooth. Then i checked resistence PWR_SRC_FBVDDQ to gnd and it was 800 ohm...So i knew i was doing something. Then i used rasp a little more and after.. reading was 2,7 kohm but reading on multimeter was jumping...and finally when i used rasp once more the problem was gone...Now there is no resistence between PWR_SRC_FBVDDQ and gnd at least my multimeter can not read it (with already mentioned smd components removed).
        Then i used solder mask...to fill that whole.
        I hope when i put everything back it will work.
        • Nagy Daniel
          Lowest possible resistance on laptop motherboard rail - Guide Table request
          by Nagy Daniel
          Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
          I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
          I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
          So, I generated a table with AI so I can...
          03-04-2025, 08:24 AM
        • glovecaps
          Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
          by glovecaps
          I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
          My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
          The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
          11-25-2024, 04:23 PM
        • Andreasbest
          Lenovo P50 dead with burned motherboard
          by Andreasbest
          Hello.
          I received a P50 in very good shape that is dead and smelled burned board when on power supply.
          I strip it and found a heavily burned area, there should be some cap but now are smoke.
          Not sure where the one copper trace stops and starts the next, they seem mixed probably due to heat, this is my main problem as i'm not sure where should i solder what, so any help is appreciated.
          Schematics & boardview here
          Pictures os the affected area attached below.
          Not sure if it can be saved but i'll give it a try.
          Thank you in advance!...
          03-26-2024, 06:22 AM
        • Archimedes
          HP Envy 17-3290NR 3D Blank Screen - motherboard Louis V1.1 6050A2489901
          by Archimedes
          Subject is a blank screen issue in HP Envy 17-3290NR 3D version laptop with motherboard Louis V1.1 6050A2489901 MB-A02. Production year is 2012. This one is a 2nd hand motherboard which I could use it for few months only. Suddenly no output from the internal display and also no signal from HDMI port then Windows out of order after few boots.
          Caps lock working normally and no HP's caps-lock warning blinks. Making a hard reset and replacing the RAM sticks or using different slots didn't help.
          Fans are spinning. Blindly could install windows11 and got the device manager...
          07-30-2024, 05:14 PM
        • Phantomax
          Hp Omen 15 motherboard with burned mosfet
          by Phantomax
          Hi, maybe someone can help me find the replacement for this burned mosfet, it's on the other way of the power connector. The motherboard model is: FPC54 LA-H482P.
          At first I thought it just unsoldered, once re-soldered it worked for a week then no power again so i want to swap it with a new one.
          Thanks for the help!
          06-19-2023, 03:55 PM
