Re: Mechanical Relay Quality
direction is not important because none of the parts are polarised.
When using a snubber with a AC circuit the direction of current flow matter, if so should the cap be on the Line side or the neutral side of the switch/relay?Leave a comment:
Redwire does 10R stand for 10 ohms or 10 thousand ohms?Leave a comment:
well then guess i will go with a 200v cap 505-mks2g031001k00ko or 505-mks2g031001k00jo which ever is in stock...
In the interest of science would it be a problem if i used only one resistor with a double throw switch/relay
I know it would only save $0.10 but it is 1 less part to solder, now that the logical reasons are out of the way... i am really just curious about it if you can do that
EDIT:
Would i need a snubber for a relay that controls a incontinent light bulb and a florescent bulb?Attached Filesif you find these attachements useful please consider making a small donation to the site
Last edited by evilkitty; 01-02-2018, 06:45 PM. Reason: 200V not 400V (mixed up AC /DC voltage specs)Leave a comment:
I would use a higher voltage capacitor as 63VAC/100VDC is close to the part's limit.
The load R L values and math and what you can fit/have on hand- it's easier to just look at it with a scope. Zone valves have a lot of inductance 200mH. I can post SPICE sims.
With no snubber I got 300-500V spikes, and down to about 100V with a 0.22uF/10RLast edited by redwire; 01-02-2018, 12:16 PM.Leave a comment:
Tesla once said that too much theory and not enough experimenting will get you nowhere.
so these are good then?I just did a snubber design for 24VAC zone-valve controller.
The values are not critical, I found 0.1uF-0.22uF 160V and 10R 1/2W worked fine.
This is to keep the back EMF from arcing relay contacts or damaging a triac.
The cap ends up being large physical size, I used junkbox X or Y-caps.
https://www.mouser.com/productdetail...s2d031001a00ko
https://www.mouser.com/productdetail...os1-2ct52r100jLeave a comment:
The cap ends up being large physical size, I used junkbox X or Y-caps.Leave a comment:
Had my microwave oven's relay go kaput recently, jury rigged a replacement until I can go order one (with other stuff).
It died when a capacitor died... Contact life exceeded/destroyed.Leave a comment:
Or you could use this
Crydom S3013A S3 Series Solid State Relay, PCB Mount, 3.5-8 VDC, 3A, 20-140 VACLeave a comment:
It's not the amperage or the voltage but, rather, the rate of change of voltage/current that drives the design.
The capacitor (in series with the resistor) ensures there is no DC path through the snubber -- you wouldn't want current flowing AROUND your switch contacts all the time as that would defeat the purpose of the switch! The capacitor ensures that only the "transient" (spark) finds its way through the snubber, being dissipated in the resistor.
With the mercury switches, the mercury acts to "clean" the electrical contact. Hence the use of mercury-wetted relays if you want to avoid the snubber.Leave a comment:
IL = Amperage, given my meter peaked at 1A , guess that is 1
E = ???
k= (unknown value from 0.1 to 2)
this is the issue i have when i go to look a circuit formula, i have no idea what the variables stand for...Last edited by evilkitty; 01-01-2018, 08:05 PM.Leave a comment:
during the switching process my clamp-on meter measured 0.67, with a peak of 1A (slowly climbed and slowly dropped off)
*I need to get fuses for my other meter (in my mouser cart)Leave a comment:
have a read.Attached Filesif you find these attachements useful please consider making a small donation to the site
On the note of a snubber
Assuming the power is 1A @ 27VAC (60Hrz i assume)
what size/wattage resistor and film cap do i need?
The spark i saw when it used the tubes was like you would get from a little static (petting cat and touch it's ear near the fire place)Leave a comment:
Do any of:Yesterday i had to replace a relay i installed about 2.5 years ago
This relay i used in my thermostat to use 5VDC logic to control 27VAC logic
I had used the cheap relays you can get on ebay for about $0.50 each (Songle SRD-05VDC-SL-C)
It failed cause the contact plate on the load side became dirty from electrical arcing- Add a snubber across the contacts
- Use Hg-wetted relay
- Exert more control over when the armature is moved wrt the AC waveform
I know the current is small, 26awg wires do not get warm
wonder what my clamp on meter says...
0.67A up to 1A then back downLeave a comment:
by valvashonYesterday I successfully repaired a Middle Atlantic UPS2200R-IP that had inadvertently been used as a surge suppressor at our transmitter site. It has already been replaced with an updated one but it's coming home with me now instead of being e-cycled. To be specific, this is the MA model that has the blue backlit display and has been discontinued, although this design may have been used in many UPS units including the smaller Middle Atlantic ones in this series.
Here's what happened: We experienced a brownout/surge at the site, which damaged the UPS and took our broadcasting... -
by CoinCoin88Hello everyone,
I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver... -
by DXseekerMOHello everyone!
Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...Yes0%1All backlight strips are the same quality0%1No0%0 -
by CuriousJohnBurco BCPLSAFWM5L 5 Litre Wall Mounted Automatic Water Boiler With Filtration UK 240v
Does anybody have any experience with these Burco units at all there is no record of them on the forum lol and a proper service manual would be nice. I invite you all to pesuade me not to botch repair it with a 5v relay, read on.
This unit was rescued from a skip 3 years ago, the only fault it had then was no backight display (plus it wanted a new probe set and top seal) but the screen was never an issue you can still see the screen as is and I just use it to get 5 Litres of very hot... -
by SluggerBI have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,... - Loading...
