battery id
  • dj_ricoh
    • 2073
    battery id
    does someone know how they are called?
    I need to buy a few. I notice lots of devices are using them
    Even in headphones but those ones are a little bigger.
    This is one very tiny <3
    Ty
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: battery id
    Looks like it has a [plastic casing. Open it and take a look. Might have a cell with an ID.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8700
      Re: battery id
      Actually don't bother opening it if it is what I think it is, you'll just get a mess. It looks like a rechargeable lithium ion polymer "pouch" cell. You buy them by the dimensions and unfortunately likely you'll have to get the right size which may be hard as there are no generics and likely many are off a millimeter or so on some dimension. There should be a set of numbers printed on it indicating the size which is basically in millimeters in each direction, else you'll have to deflate and measure it...
      Last edited by eccerr0r; 11-03-2017, 11:05 AM. Reason: dementia dimension (spelling error correction)
        • 30994
        Re: battery id
        yes, li-po cell with a protection board under the kapton tape.
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          Re: battery id
          Very interesting.....I've never seen one.
            • Jul 2011
            • 6037
            Re: battery id
            Ty
            You MUST check every cell you buy to see if the protection boards work right
            Be very careful when buying these on eBay a lot of these are China made cells
            There quality is mixed sometimes you get good cells but the other problem is with the protection board this is a mix of quality as well
            Here is an example of what I mean
            One thing you might notice is
            One when changing the voltage at the cell does NOT go over 4.2 volts per cell
            the other thing watch for is that the protection board shuts off the power when the battery voltage goes below 2.8 volts to 3.0 volts
            What I have seen is that the cut off voltage is some time high than 4.2 volts @ 50 millimeters if it keeps going higher than this do NOT use this protection board
            Also you will find some protection boards that with a 50 millimeters loads and below
            do not turn off with this current until way below 2.8 volts
            Another problem you will sometimes time see is that let say the board is rated at one amp which is supposed to mean that if you over load this it should TRIPs I have some time seen that this dose not always work or you can not even get it close to one amp before it trips
            One way you can tell a cell is going bad is when you are charging it and the charging light does not change colors or does not go off or the running time is a lot shorter
            Make sure when you buy these types of cells that you test the protection and make sure that they work right
            One note if you are VERY careful you can unsolder the protection board and use it on your new cell if the protection board on the new cell does not work right I have had to this before in a tablet because the protection board on the new cell did not work right
            If you do have to remove the protection board from a cell use a popsicle stick or a tooth pick
            to remove the battery leads from the protection board when unsoldering it for safety reasons
            be VERY careful with the positive lead on these cells it is very easily toren off if this happens you will not be able to use this cell again unless you have enough of a lead left and have a battery spot welder if you do have a spot welder do not use a lot of current to weld them with a longer lead to soldier to the success rate of doing this this s about 30%
            I hope this helps you
              • Jul 2011
              • 6037
              Re: battery id
              Ty
              Here is eBay link to where you buy some
              https://www.ebay.com/itm/10-x-3-7V-3...IAAOSwNuxXa5hV
              • NeedsMoreFlux
                • Oct 2017
                • 121
                • California
                Re: battery id
                Ebay will have them. search by mah if you cant figure out the size in metric.
                I've pulled alot of these out and put in bigger batteries.
                They are probably lithium ion.
                This looks like an 80-150mah.
                Disclaimer: Don't trust a thing I say-I am frequently wrong!!!
                I have tons of spare parts, some used, some N.O.S. ham transistors and caps. Message me if you need any parts.
                Some of the things I've fixed:
                60" Vizio-bad LED's. iBook G4: Resoldered VCC Plug. Geo Tracker ECU: Swollen / Leaking capacitors. Windows Laptop: Soldered broken LVDS wires. Dryer: Burned contact on temp switch. Oven in R.V.: Bad contacts in relays-Exploded by the looks of them! Samsung Oven: Burned contacts on Relays. MSI Motherboard: BSOD-Swollen capacitors, bad graphics card, Moved SATA Input from SATA 1 to SATA 2 plug
                • dj_ricoh
                  • 2073
                  Re: battery id
                  Can't wait for payday. I have 2 Bluetooth headphones and one small 640x480 camera.
                  Never had something like this.
                  Do they have memory or I can charge them willy nilly?
                  • Techgeeky
                    • Oct 2017
                    • 15
                    • Turkey
                    Re: battery id
                    Looking them for the first time in my life.
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8700
                      Re: battery id
                      Do they have memory
                      No
                      Yes, if you want them to explode
                      No. You can't. I don't think they have protection boards for batteries that small, it's likely on the device that it's connected to so that it won't blow up.
                      • dj_ricoh
                        • 2073
                        Re: battery id
                        that is so sick! >
                        if i keep them do they go bad? like they won`t work after one year if i don`t use them.
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8700
                          Re: battery id
                          Did you do LiPo-suction on that dead bloated battery so that you can measure it? (badam-tish)
                          Wow, only 30mAh capacity? A CR2032 is around 180mAh (if only it were rechargeable...)
                            • 30994
                            Re: battery id
                            there are rechargeable versions, i think they are lithium,thionyl-chloride.
                              • Jul 2011
                              • 6037
                              Re: battery id
                              that is so sick! >
                              If you keep an eye on them another words every 3 month or so check there voltage if they are close to 3.0 put the on charge until come back up to 3.6 and good to again
                              I have some for a couple years now and they are still good but still need to check the batteries and protection boards to make sure they work right
                              I found a a couple of batteries that have gone bad they started to heat up while charging this tells me that have come to end of there useful life
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8700
                                Re: battery id
                                The rechargeable CR2032 (LiR2032?) capacity is just as bad as these cells here.
                                I suppose it depends on what you use the device for; but for things like CMOS clocks that don't charge the battery, I don't think the rechargeable CR2032 is a viable option, they'd require more effort to recharge and replace as it'd need to be done more often.
                                In fact I'm not sure what the value of those 40mAh rechargeable CR2032s are, can't really think of something that could take 1/4th the capacity that will self discharge much faster than primary lithium-manganese CR2032 cells - means more frequent disassembly, unless they were designed with the rechargeable nature in mind to begin with. In that case they might well use those pouch cells.
                                  • 30994
                                  Re: battery id
                                  the lithium-thionyl are often used to back the cache-ram on raid controllers.
                                  those li-po pouches are short life'd and dangerous.
                                  they also inflate when they are worn-out with enough pressure to damage the thing they are in - including forcing the aluminium battery casing apart on crapple laptops!
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8700
                                    Re: battery id
                                    I have a lithium thionyl chloride cell in my Tek 'scope that I retrofitted in. It's 3.6V however - just a hair under a Li-ion, and has fairly high capacity and shelf life hence great for the low power SRAMs used as NVRAM for the calibration memory. The cell is rated for some 2Ah (14500 sized, so 7.2Wh in an AA-sized package is pretty dense) but its internal impedance is so high that it's only good for using as memory backup... Plus can't recharge it...
                                      • 30994
                                      Re: battery id
                                      i have one of those in the GPIB interface of a big bench psu.
                                      • Bowline
                                        by Bowline
                                        06-11-2025, 10:13 AM
                                      • mkdj
                                        ASUS X571 no power : battery issue?
                                        by mkdj
                                        Mark and model: ASUS X571
                                        Symptoms: not turning on. There is only the LED battery indicator working. The owner of the laptop told me this problem arrived one week after having changed the battery. He then managed to power on the laptop only once, and then it never powered on again.
                                        Tests already made:
                                        - Battery is charging when laptop is plugged in. The LED battery indicator turns white after a couple of hours of charge, indicating that battery is fully charged. However, laptop won't turn on anyway, with or without AC plug.
                                        - I have removed...
                                        07-14-2025, 09:16 AM
                                      • techfreak9356
                                        Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                        by techfreak9356
                                        I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                                        09-14-2023, 11:10 PM
                                        NVDC charger configuration...
                                        11-05-2024, 03:28 PM
                                      • ferah831208
                                        Strange battery present behaviour in Lenovo Legion 5-15ARH05 mb model nm-d041
                                        by ferah831208
                                        Hello guys, i need help with this problem, I have a NM-D041 mobo, it came with low impedance in 3v linear regulator rail, the cause was a damaged EC controller ITE8227e-192. I ordered a new one and replaced it. This laptop have a different chip for keyboard management and it8227e pins for programming ITE chips are not accesible through keyboard interface, I flashed it using i2c interface pins with vertyanov programmer because laptop was dead and SPI flash didn't have power (only 3v EC) so it couldn't access firmware stored in SPI memory. I read SPI and extracted it8227 firmware from original BIOS...
                                        03-18-2025, 01:18 AM
