Any electricians here?
  • freelancenoob
    • Oct 2017
    • 77
    I'm getting ready to wire a shed feeding power from my second garage. My garage is on its own service and is 200 amp. My plan is to put a 100amp breaker in and run a feed line to my shed panel. Total distance is 62ft. That is giving 2 extra feet on each end just in case. My father was telling me I should run #4 copper or #2 aluminum. Thats what he told me when we estimated the distance to be 100'. I measured it all out and I only need 62' at max. What is your take on this?
    • 31003
    Re: Any electricians here?
    use copper "concentric" if you have it in the u.s.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      I'm seeing #4 copper as kind of optimistic for 100A at 50ft based on a bunch of random web site tables...
      I kind of wonder if at this kind of power level whether it's worth to go to a higher voltage and drop back down. 50-100ft is kind of annoying for doing this however...
        • 31003
        it's not just that, for safety you should use armored or concentric rather than 2 single-core cables.
        concentric is interesting, you have the insulated live, with the neutral strands spiraling around it like a shield.
        that way if anything penetrates the insulation they only hit neutral.
        • R_J
          • Jun 2012
          • 9535
          It also depends if the cable is under ground, they will recommend a heavier guage cable if its under ground due to lack of heat dissapition vs cable strung in the open air
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            Yeah, exactly, I'm not even worried about electrocution safety yet, it's just I*R losses that's a bit concerning. 120V@100A is quite a bit of power, and from what I've seen you'd need at least AWG2 or AWG1 copper, or two sizes larger for aluminum (meaning AWG 0 or 0/1).
            Do you really need 12KW of power over at the shed? If you do, I'd say the wire cost shouldn't be a concern... Also perhaps duty cycle is something else, if your duty cycle is low, then cheaping out in wire is possible in an engineering sense, but this is not to code.
            • freelancenoob
              • Oct 2017
              • 77
              It will be 4 wires. It only goes underground for maybe a foot between the garage and shed. the section of wire that will be under ground will be in conduit. 90% of this wire is going to be in the garage since the panel is across to the other side.
              • freelancenoob
                • Oct 2017
                • 77
                Shed will have this. 1-220 outlet for window ac/heater, 8 sockets (4 sockets per breaker), 3 over head fluorescent light fixtures.
                This is going to be my electronic workshop. Fixing tv's, computers, etc. Gaming room when nothing else is going on. So I need to be able to run several components at the same time but ill next get close to 100a. 100a for this shed is a little overkill but id rather it be that way.
                  • 31003
                  gaming room??
                  you just moved up a notch on my respect-guage !!
                  • freelancenoob
                    • Oct 2017
                    • 77
                    Someone has to thoroughly test these tv's I fix.
                      • Jul 2011
                      • 6037
                      I will tell you a story about a person I use to know he ran wire to his washer and dryer and did not use under ground rated wire did not put in conduit did not have a breaker at washer and dryer it only lasted 3 years keep tripping the breaker in the mai panel
                      I ended up redoing it the right way for him
                      I would run # 2 wire rated for under ground this is a must either 1 “ or 1.25 plastic electrical conduit
                      It will last a lot longer conduit
                      I ran this to my shed 13 years ago and mine run was about as long as yours
                      I run some time run a welder or a battery welder or a air compressor
                      Battery chargers soldering equipment and the like never had a problem with this setup
                      • petehall347
                        • Jan 2015
                        • 4426
                        are you allowed to run 220v then split to 2x 110v ? like same as from entry point .
                        i dont fully understand your wiring over there . all i know is the wire can be thinner for 220v .
                        i would think for your usage 40 amps would be over the top .never mind 100 amps
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          Well 100A is 100A no matter what the voltage. If you're talking about watts, at 220V and the same number of watts, you can have lower current and thus thinner wire.
                          However, it seems to be the case that freelancenoob is running two 50A 120V lines, then the #4 may work (marginally) as two 50A lines and two 50A neutrals.
                          Would require double the amount of wire of course, but this should be on the borderline of "okay".
                          • petehall347
                            • Jan 2015
                            • 4426
                            its easier here .240v .. 6mm will just about work . 8mm is ok . 10mm is much better .armoured of course as it can take more current because it cools itself with the armouring .
                            • freelancenoob
                              • Oct 2017
                              • 77
                              I fully plan to run conduit where the line comes out the side of the garage and then goes into the ground. Only talking about a 3 or 4' span. Just not sure if its 18" or 24" it needs to be buried.
                              • RJARRRPCGP
                                • Jul 2004
                                • 6304
                                Hitting the neutral alone is even worse, because 115-127 V devices can get surged! Can cause the regular appliances to be hit with 230-254 V!
                                ASRock B550 PG Velocita
                                Ryzen 9 "Vermeer" 5900X
                                Arc A770 16 GB
                                eVGA Supernova G3 750W
                                Alienware AW3423DWF OLED
                                  • 31003
                                  you wont sever it,it's too thick.
                                  it's just so the person responsible doesnt die in a ball of white plasma!!
                                  • brokentvguy
                                    • Oct 2017
                                    • 6
                                    • england
                                    If you live in the UK you will need a registered sparky to sign the work off to comply with building regs or you may void your home insurance, if you decide to sell in the future it is one of the questions asked have you had any electrical work done since part p was introduced.
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8701
                                      I think this is true in any locale actually...
                                      • goontron
                                        5000!
                                        • Dec 2011
                                        • 4108
                                        • US
                                        ^ freelancenoob is in southwest georgia USA according to his profile. Homeowners can do their own plumbing and electrical there...
                                        Follow the white rabbit.
                                          Lift Master garage door opener with WiFi capability application through your phone
                                          I had a lot of trouble with the WiFi connection from my router inside of the house into a ( new ) metal garage I had to run a 150 ft cat6 patch cord so the WIFI connection would be strong enough for the WiFi connection on the garage door opener would work correctly ( my son has a work out area in the garage as well and he was having to put his phone near the door to be able to stream music ) ( so I was going to eventually put WiFi out there anyway )
                                          This garage door opener WiFi is very touchy if you lose the power it does not remember the password for the router which is weird or...
                                          01-21-2023, 08:31 PM
                                          Linear Garage Door Opener Control board took a crap install a new control board back normal
                                          I have been having issues with this garage door opener for a while first the range of the remote was a lot less and sometimes it would start to go down and stop for no reason that I could find and would every once in awhile to start with then it started going more frequently until last Saturday when I opened the garage door it refused to close so I cranked up force all the way maximum limit this did not work also the sensor on one side that has a green and red lights that are supposed to be on when the door is open and there are no obstacles in the way on the original board the only light that...
                                          02-08-2025, 06:52 AM
                                          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                                          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                                          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                                          I am comparing them to a brand new one that I installed
                                          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                                          I going to let it run for several days before I remount back on the wall next to the...
                                          09-05-2024, 06:48 PM
                                        • rictechie
                                          copper pad in board peel off
                                          by rictechie
                                          Hi I'm newbie when it comes to electronics repair. My copper pad where my diode sticks has peeled off what is the most efficient way to make the copper pad stick to the board? epoxy? ink mask? I want to hear your suggestions
                                          07-20-2024, 11:49 PM
                                        • technicalspecialist
                                          Vintage fan repair, copper wire question
                                          by technicalspecialist
                                          I currently have a customer's vintage fan on the work bench to repair.
                                          It uses an induction motor with 4 poles. One of the poles is open.
                                          I couldn't find the break so i cut off the original wire.
                                          I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
                                          I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
                                          The enamelled copper...
                                          03-16-2023, 12:54 PM
