copper pad in board peel off
  • rictechie
    • Jul 2024
    • 17
    • Philippines
    Hi I'm newbie when it comes to electronics repair. My copper pad where my diode sticks has peeled off what is the most efficient way to make the copper pad stick to the board? epoxy? ink mask? I want to hear your suggestions
    • Jul 2011
    • 6070
    Please show some pictures of the board in question so we can give you the correct information
    • mon2
      • 14685
      How to Use Wylie Patch Dot Repair Soldering Lugs | Injured Gadgets (youtube.com)
        • Jul 2011
        • 6070
        Thanks for posting this I was not aware that there was a product available like this
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8342
          Scrape a bit on the trace and expose the copper. Solder wire to it and go to your broken pad. After all is soldered together put some UV curing paint or whatever else you got on there and be done with it. There are endless YouTube videos on how to fix ripped off solder pads, Google “Northridgefix” for example.
          Your problem was you used too much heat and that ripped the pad off. This is usually due to a low wattage soldering iron, old or corroded solder, too much heat on the soldering iron due to not adjusting the temperature correctly, etc.
          • mon2
            • 14685
            As a suggestion on the wire to use -> locate an old IDE (PC) style hard drive cable. Hit up a friendly computer repair place and they should give these to you for free or dirt cheap. Such cables (and floppy drive ones) are made from crimped flat ribbon cables. Dissect the cable and take out a single strand of this wire. It is very flexible and should be fine to support the diode wiring you are facing. There will be multiple strands of this naked wire inside each conductor of the cabling you can find at the computer store. Keep in mind that there is no insulation on this wire so be careful as to where this wire starts and ends - do not allow it to touch anything else.
            As another suggestion, use tweezers to solder in place AND then flex the extra piece of the wire till it breaks (back and forth). Do not rip off the ends with force because this can cause further damage to the solder pads. Test the process with any donor board.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
            • Hakuu
              by Hakuu
              Hi There,
              More Details
              TV Model - LG OLED77G1PUA
              07-12-2023, 02:37 PM
