How to test/check ic chip?
  • buchman
    • Aug 2015
    • 294
    • greece
    Is there any way to test/check an ic chips?
    I have only AVO meter, no scope or anything like that.
    Thanks in advance.
    • 31277
    Re: How to test/check ic chip?
    no.
    simple answer.
    • buchman
      • Aug 2015
      • 294
      • greece
      So the only way is to replace them and see if the circuit board is working?
      • petehall347
        • Jan 2015
        • 4448
        • United Kingdom
        you could check voltages against schematic
          My simple answer is also no.
          Sometime you may be able to test for internal shorted circuit of the IC if you know what are inside the IC.
          For example: the SMPS IC with integrated power MOSFET, you can check to see if the MOSFET is shorted or not with meter.
          Voltage testing also help in verification of the IC.
            • 31277
            it's actually a very complex question because there are so many types of i.c.
            i have equipment that can test logic, static memory, i/o controllers and most op-amps.
            but it's expensive kit, and that's still just a drop in the silicon ocean.
            • Grouickman
              Hofmann geodyna 6300 Wheel balancer
              by Grouickman
              Hi there,
              First, I'm not sure it's the right section to post for this type of device, but could not think of something better.
              Ok, so my son (a mechanic) bought a faulty Hofmann Geodyna 6300 wheel balancer (which appears to be mostly a re-branded Snap-on wheel balancer).
              I'm looking for any resources (doc, manuals, schematics) that would be available for this device or anyone that would have any knowledge on this particular device (or its Snap-On equivalent).
              I'm trying to diagnose the fault(s ?), but I can't find any schematic (appart from the...
              03-31-2025, 05:29 AM
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • Sparklingx
              CH341 disconnects, test clamp not working, soldered bios chip but not erasing/writing how I fixed
              by Sparklingx
              So i've bough a ch341 programmer, and the chip was CH341B . the test clamp was not working( when connecting bios using test clamp, ch341 device was disconnecting) I tried soldering the bios on the provided board, soldering the bios I could read the chip but could not write or erase. ASprogrammer , neo, ch341a programmer... all programmer software was hanging and device was disconnecting after few second of erase/write operating.
              So then I have soldered a capacitor(whatever I had..[10v ~470uf ] ) from VCC to GND on my provided pcb where you solder the bios
              now all...
              08-29-2024, 01:53 PM
            • ktmmotocross
              laptop onboard memory test and identify bad chip
              by ktmmotocross
              Hello.
              Know somebody how to successfuly test bad onboard memory and maybe even bad chip localization?
              Have newer asus that show memory related BSOD. After reball still the same. how to test if it is some ram chip or maybe bad ball under cpu or even cpu
              07-16-2024, 05:33 AM
            • privato89
              Nintendo Switch Oled HEG-001: Second-Stage Boot Failure
              by privato89
              I'm facing an issue with a HEG-001 motherboard that is unable to complete the Second-Stage Boot. I'd like to start directly with my conclusion, which is the decision to replace the MAX77621AEWI chip, and understand if it could be a correct evaluation.
              Before I dive into the process that led me to this decision, I want to mention that I have a fully equipped lab where I can perform any kind of tests.
              Let's begin:
              Following some guides online, I tried to understand how the Boot phase of the Nintendo Switch works, and what are the...
              03-26-2024, 06:37 AM
