Why does an LCD need a reset line?
  • caphair
    • Nov 2011
    • 1249
    Is it to reset all the pixels to a known state when the MCU isn't generating information?
    I'm wondering because if the panel gets display information constantly why does it need to be reset at power up?
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Re: Why does an LCD need a reset line?
    Sometimes , many wrong options lead to a confused and abnormal view , without knowing how to re-calibrate colors , Frequency , Horizantal , East-West correction , etc , so , here it goes .. Reset .
    In Repairs , Reset is vital to define the health situation of an LCD .
      • 31264
      data is clocked in serially,
      if the counters start in a random state then the initial image could look like a mess.
      also, if the mainboard takes a few seconds to boot, the reset signal prevents a screen full of colourfull snow.
      • caphair
        • Nov 2011
        • 1249
        I see. I ask because I have an iPhone 6 with the lcm_reset line shorted. It's tied directly to the CPU so it's a CPU fault.
        Normally this line is high at 1.8v. So what I tried was injecting 1.8v into the LCD connector (after removing a filter to separate the short)
        I got the display to work but it required timing on my part of when the 1.8v needed to be injected with the phone being turned on.
        When the phone goes to sleep and powered back on the display doesn't return so this led me to wonder why that is if it was just on with a static image that didn't change when it went into sleep mode
        • goontron
          5000!
          • Dec 2011
          • 4108
          • US
          Garbage data being sent to an LCD is interesting. On building coreboot for my thinkpad i ran into the Vbios not loading correctly. This lead to a black screen on boot, slowly fading in a sorta washover pattern to basicly a gray screen with every other line being a single pixel colour (R,G or B). Then when Unix finally booted and went graphical, the screen would reset and would have a rolling flicker for about a minute afterwards.
          I don't think it will damage anything, but that rolling flicker afterwards does suggest it screws with the logic...
          Follow the white rabbit.
          • caphair
            • Nov 2011
            • 1249
            So basically less display errors occur when the display is turned back on from a known state and quickly instructed on what to display?
            For example if a known state is a white screen the CPU/GPU quickly tells the display what the last image was before it was turned off to display that
              • 31264
              it's possible that the display chip is not powered off, but simply sent a command to shut the glass drivers down.
              • goontron
                5000!
                • Dec 2011
                • 4108
                • US
                ^Yep.
                • caphair
                  • Nov 2011
                  • 1249
                  Is there anyway to replicate the reset command in my case so the display keeps coming back on
                  • gabiz_ro
                    • Mar 2011
                    • 171
                    • Romania
                    Hard to tell.
                    Since touchscreen and display activity are somehow tied together you may use some power line from touchscreen or maybe if exist reset from touchscreen.
                    Since touch must be active while display is on and stay active as long as display is on there may be some singnal low-high for touchscreen on-off and you may use it somehow for lcd reset.
                      • 31264
                      maybe you can get something from the backlight drive.
                      • gabiz_ro
                        • Mar 2011
                        • 171
                        • Romania
                        That one too.
                        Now depends on delay.
                        Timming seems to be required.
                        One logic analizer could help to see what gets low or high and when is need to reset LCD to be high.
                        But that mean you need to add some extra parts small enough to fit in available space.
                        • caphair
                          • Nov 2011
                          • 1249
                          I tried getting the 1.8v from lcd_enable rail which is also 1.8v.
                          That worked for initial power on but again when phone goes to sleep the display doesn't come back after waking it up. Only on initial power up if have it powered off.
                          Do it's all about timing? Even though it's just 1.8v the reset line needs to be activated at a certain time?
                          • gabiz_ro
                            • Mar 2011
                            • 171
                            • Romania
                            Timing is critical I think.
                            First time is enable signal then with a little delay reset must come then maybe all OK.Or may be reset then enable.
                            Best chance is like I said before to use some multichanel logic analyzer on working unit.
                            You may see when and after or before reset signal is generated.
                            Edit
                            On most CPU related problems,reset signal must be after all conditions are OK to make proper initialization.
                            So LCD enable power the LCD,then there must be a reset to start fresh communications,but that could be wrong,LCD must be reset then power enabled.
                            My bet is on first variant,power enabled after that reset occur after that LCD is feeded with data.
                            • caphair
                              • Nov 2011
                              • 1249
                              Edit
                              Thanks. So to help understand this better, I measured a working one and the reset 1.8v is present the entire time the display is on. So how exactly does that voltage reset the display to avoid display errors? I pictured it like a quick 1.8v that goes away to arrange the glass drivers before receiving display information
                                • 31264
                                the transition from 0v to 1v8 is the signal
                                you may need a fast scope to catch it.
                                • caphair
                                  • Nov 2011
                                  • 1249
                                  So at 1.8v the glass drivers would be "reset" the entire time the screen is on to properly display correct images?
                                    • 31264
                                    maybe.
                                    i dont know if the reset signal is active-high or active-low.
                                    but the magic takes place on the transition.
                                    • caphair
                                      • Nov 2011
                                      • 1249
                                      maybe.
                                      On a working one 1.8v is there during screen operation and 0v when the phone is sleeping/off
                                      • caphair
                                        • Nov 2011
                                        • 1249
                                        maybe.
                                        So if this line is shorted then it's the transistor within the CPU that's gone bad holding it at 0v correct? (If its normally active high that is)
                                        • sheffieldyorky
                                          ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
                                          by sheffieldyorky
                                          Hey there people
                                          While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
                                          This is what I tried, but not in any order.
                                          Google
                                          YouTube
                                          BIOS
                                          Command Prompt (administrator privileges)
                                          On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
                                          10-25-2025, 02:22 AM
                                        • TrueSword88
                                          Kogan - KALED65XU9220STB - Blue Vertical Line
                                          by TrueSword88
                                          Hi all.
                                          I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                                          The line just happens to coincide with the end of COF and start of the next COF (attached).
                                          The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                                          Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                                          Hoping to fix...
                                          05-05-2023, 04:28 PM
                                        • odie34
                                          Sony OLED XR-77A80J - 5 Flashes But Turn On After Hard Reset
                                          by odie34
                                          I am a hobbyist (not a professional) so please be gentle...
                                          I recently received an XR-77A80J that wouldn't turn on. (Repeating 5 flashes when plugged in.)
                                          I did a hard reset by holding the power button for about 30 seconds until the set powered down. I then tried to turn it on and it powered up, bringing me to the setup screen. There's not a lot of detail on the setup screen but the picture didn't have any distortions, so at least a cursory examination suggests no physical damage to the screen. The set appeared to be working normally, but it shut down after about 15 seconds,...
                                          02-18-2024, 09:11 AM
                                        • ictc
                                          Philips MDP 3380/12 Blu-ray Player – No Power, Reset Signal Always High
                                          by ictc
                                          I'm troubleshooting a Philips MDP 3380/12 Blu-ray player that shows no signs of life. The display remains off, and no buttons respond.
                                          Inside, the power supply is working correctly, and all expected voltages on the mainboard match the service manual specifications. The CPU warms up slightly (checked with a thermal camera), the crystal oscillator is functioning, but the reset signal remains high at all times.
                                          The reset circuit appears to consist of two NPN transistors, one driven by 5V VCC and the other by 3.3V STBY, as shown in the attached schematic. Should the reset...
                                          02-25-2025, 12:15 PM
                                        • FALKLAN
                                          Running Line Voltage and Integrating LED Pods - Automotive
                                          by FALKLAN
                                          Howdy everyone! I hope all is well where ever you are!
                                          I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
                                          I am uncertain how to convert this line into a switched 12v output line for the LED pods....
                                          02-05-2025, 12:30 AM
