Non inverting Schmitt Trigger question
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    • Romania
    #61
    Re: Non inverting Schmitt Trigger question
    This might be something for you think about so hear out
    How easy would it be to put a optic sensor on the window or a switch on window mechanics when the window is up and when it down
    or encoder on the motor or a travel encoder on the window slide
    as for as the current amp sensing to that not as easy you think and here why
    is most DC amp probe that I have used you must zero it before you can use it
    This could be a problem if for some reason the amp probe showing let say 5 to 10 amp or even 2 or 3 might cause you some problems
    Keep mind that I am just thinking out loud
    I was thinking of that solution at one point in time, however taking apart the doors, drilling holes and running extra wires is not a feasible option sadly.
    Wattevah...
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      • Romania
      #62
      Back on this project, I wanted to go ahead and source some actual parts so we can at least prototype something, instead of just making assumptions since it could go on forever like this.
      As I previously wrote, after my previous searches trying to find the "best" transistors to use (which don't actually exist, since nothing is ideal), I realized I chose too high a drain current rating for my application, but even so, I managed to get myself 2 IRF3205 N-channels...YOLO They've got a 8 mOhms D-S resistance and they probably take 100A without complaining. I only got these because they were the only ones my local electronics shop had in stock with the lowest RdsON value. Just for curiosity's sake, I also attached the list I put together before realizing I greatly overestimated the drain current, so the list is rather narrow and there might be other better choices out there, they just weren't readily available or they were expensive.
      For my P-channels I found the IRF4905 in stock...the D-S resistance is a lot higher with these: 20mOhms, but again...YOLO They weren't terribly expensive and unless I REALLY screw up, I don't think I'll fry them...
      Wattevah...
        http://www.electronic-products-desig...neral-switches
        • Dannyx
          CertifiedAxhole
          • Aug 2016
          • 3912
          • Romania
          #64
          Back on my H-bridge project, I realised I may have some impedance issues: the P-channel FET has a 20mOhm on resistance, the N-channel has 8mOhms and the shunt resistor adds another 10, so that's almost 40mOhms of resistance which doesn't sound too good. I worry the motors might be a tad "slow"....does this usually happen with N-P channel H-bridges or is it something I don't need to worry about ? Cheers.
          Wattevah...
            .04 Ohms x 30A = 1.2V Vrops (more at startup). Is that a big deal?
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              • Romania
              #66
              Can I rewrite the formula as 0.04*7=0,28v ? Where 7 is an estimated current drawn after the motor has got up to speed and is moving the window freely up/down. I assume those 30a you put there were for the start inrush. There might be a small hick-up upon startup with a 1.2v loss, but should be good enough I guess...I could add a booster to allow me to use all-N channel FETs, though that would clutter up things.
              Wattevah...
                It is just Ohms law, so input the values you need to get the answer.
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  • Romania
                  #68
                  I found something which is interesting, but I don't think it's too much of an improvement over what I already have installed. I found this little doohickey at a flea market which claims to be a window roll-up device that supposedly does what I'm trying to build here. The price on this thing I gotta be honest was zero, because the chap gave it away as "non-functional". See, it didn't come with the wire harness (must've been pulled out of a car, who knows) and the guy said I wouldn't be able to find the exact connector to match, so he gave it away for nothing. Little did he know it's actually a standard 20p ATX connector, so I just said "sure whatever, hand it over"....he was also kind enough to include the instruction leaflet, which is mandatory for China stuff, since you'd have no way of figuring out what it is or how to use it. Anyway, enough chit-chat.
                  I took an ATX connector with stripped ends and wired the thing on the bench to see what it does: it behaves exactly like the one I currently have installed, except this one gives you the option of either "pulsed" operation or timed operation. If you cut the red wire, each of the relays engage for 10 seconds when it receives a lock signal and if you close that wire, each relay is pulsed very briefly, supposedly for cars which already have latching switches which only require a brief action for the window to go all the way up/down.
                  I was mostly interested in the control logic, I thought perhaps it has some sort of current sensing which I could hack into, but unfortunately no, it doesn't seem to do this: in "timed" mode, regardless of the load, it keeps running until the time elapses. I'm actually surprised they left the markings on the chips intact, since chinese products usually have them scratched out or use blank chips. The brains of the thing seems to be that MDT2010 chip which I couldn't find much about. The first few searches revealed a datasheet for an 8-bit microcontroller here. I thought for sure there's no way it would be the right thing, despite the model being an exact match, so I searched high and low, but all I got was this 8-bit micro....Is this thing that intelligent ? :| I mean the stuff that datasheet discusses is...intimidating to say the least :| Extremely complex stuff, so it's way over my head to try and hack this if it really IS micro-based and uses that chip indeed. The highest I'd dare to aim for at my level is Arduino There will hopefully be some engineering mavericks around here who will look at that stuff and go "oh, elementary...", so if so, please feel free to share you thoughts. Sometimes complex electronics stuff is instantly made easy when properly explained...
                  The other two ICs are an LM2904 op-amp and an ULN2003 relay driver, for both of which I managed to find the "correct" datasheets (I put that in quotes assuming the MDT one is indeed not right and these last ones are ). A very quick look at the circuit made me believe the op-amp is a current sense amplifier connected to that coil. I thought for sure that coil does some sort of current sensing, since it's in series with the battery input, but either I'm doing something wrong, or it's indeed not designed to do that. I also attached the instructions sheet in case you're curious or perhaps spot something that I don't. It's in "chinglish" of course, but you only really need the schematic - the other side is not that important.
                  What do you guys think ? Would this thing be of any use or is it going in the bin ? Cheers.
                  Wattevah...
                    You do not use coil for DC current sensing, that coil at the B+ is for filtering noise from alternator just like one you have in car stereo to get rid of the whining sound from alternator.
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      • Romania
                      #70
                      So it seems it does not do current sensing at all, since I don't see any other large shunt element in there...
                      Wattevah...
                        Any good clear hi-res straight shot of the bottom side of the board?
                        • Dannyx
                          CertifiedAxhole
                          • Aug 2016
                          • 3912
                          • Romania
                          #72
                          It shall be done. No parts there though - just traces.
                          Wattevah...
                            Just curious.
                            • Dannyx
                              CertifiedAxhole
                              • Aug 2016
                              • 3912
                              • Romania
                              #74
                              Here you go
                              Wattevah...
                              • martonmiklos
                                Dyson DC45 trigger board burnt brush motor driving SO8 IC
                                by martonmiklos
                                Hi fellows,
                                I am trying to repair a Dyson DC45 battery powered hoover.
                                There is a trigger board in it which hosts an Attiny48 and some power stage to drive the brush motor.
                                Unfortunately a SO8 component burned to hell in it together with a 0603 resistor and the IC could not be identified.
                                The Attiny output looks to be survived the problem because when pulling the trigger it outputs high for a while and then turns off.
                                It is likely that it measured the current on the R10 shunt and this is why it is shut down.
                                I have attached...
                                06-29-2024, 12:21 PM
                              • kamel
                                Lenovo Ideapad 3 15IML05 MB : GS452/GS552/GS752 NM-C781 not trigger
                                by kamel
                                Hi Ideapad when Plugged in 3.3vALW and 5vALW are on, but 1.05vALW and 1.8vALW absent. Power led lights and remains always on and laptop not trigger..
                                Found a burned spot on LV5075B IC, replaced with a new imported IC, but 1.05vALW and 1.8vALW still failing. .
                                EC IT8586E working voltages and signals are all ok except PBTN_OUT# 2.44V not changing when power button is pushed and EC_RSMRST# always 0.1V ??
                                Reflashed EC IT8586E and Main bios with newly download dump from Lenovo site to no avail.
                                Should I fix again a new L5075B and replace IT8586E to solve the issues....
                                04-20-2025, 08:19 AM
                              • DAVEMAC02
                                Inverting op amp circuit
                                by DAVEMAC02
                                Yamaha Stagepas 300 pa system. I have a problem with the attached inverting op amp circuit. I have no output at pin 1 of the B amp. I have audio across cap 221. I've checked resistancr values and grounds and are all ok. I've checked for diode function on IC204 pins 2 & 3 and check ok. I don't know what other components are in IC204 and how to check. There is FET Q208 & Transistor Q205 and I don't their purpose in the circuit. I don't think IC204 is bad , but I don't know how to prove it is good or bad. Don't want to replace it if it is good as I will still have the problem. Need...
                                09-30-2024, 12:13 PM
                              • DAVEMAC02
                                Inverting op amp follow up
                                by DAVEMAC02
                                Follow up to my op amp diagram of Q208 FET and IC204 for NJM 2068M op amp. I took took the following DCV readings on the Q208 (2SK246) and IC204 pins:
                                pin 1 0v, pin 2, 0v, pin 3 0v, pin 4 -15.6v, pin 5 0v, pin 6 .08, pin 7 0v, pin 8 +15.9v
                                Q208 source -.006, gate -15.5v, drain -.102. These readings are from the op amp Q208 that has no output on pin 1. I don't know what state ie (On or Off ) Q208 should be when op amp is working correctly. This circuit is on the filter/limiter stage of the PA system. Any help is appreciated. Thanks
                                10-03-2024, 01:08 PM
                              • simabilisim
                                HP LA-C701P REV 1.0 does not trigger
                                by simabilisim
                                HP LA-C701P REV 1.0 does not trigger after shutdown. However, when we remove the adapter and plug it in, it gets triggered.
                                10-01-2022, 12:36 PM
