Inverting op amp follow up
  • DAVEMAC02
    • Jun 2018
    • 17
    Follow up to my op amp diagram of Q208 FET and IC204 for NJM 2068M op amp. I took took the following DCV readings on the Q208 (2SK246) and IC204 pins:
    pin 1 0v, pin 2, 0v, pin 3 0v, pin 4 -15.6v, pin 5 0v, pin 6 .08, pin 7 0v, pin 8 +15.9v
    Q208 source -.006, gate -15.5v, drain -.102. These readings are from the op amp Q208 that has no output on pin 1. I don't know what state ie (On or Off ) Q208 should be when op amp is working correctly. This circuit is on the filter/limiter stage of the PA system. Any help is appreciated. Thanks
  • DAVEMAC02
    Inverting op amp circuit
    by DAVEMAC02
    Yamaha Stagepas 300 pa system. I have a problem with the attached inverting op amp circuit. I have no output at pin 1 of the B amp. I have audio across cap 221. I've checked resistancr values and grounds and are all ok. I've checked for diode function on IC204 pins 2 & 3 and check ok. I don't know what other components are in IC204 and how to check. There is FET Q208 & Transistor Q205 and I don't their purpose in the circuit. I don't think IC204 is bad , but I don't know how to prove it is good or bad. Don't want to replace it if it is good as I will still have the problem. Need...
    09-30-2024, 12:13 PM
    Samsung NP-Q208 Q208 Laptop Schematic
    Samsung NP-Q208 Q208 Laptop Schematic...
    10-08-2024, 02:10 AM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • Flasman90
    Macbook Pro A2289 MXK62LL/A (661-14770) - No Startup
    by Flasman90
    Hi everyone - first time poster on here looking to embark on my first repair! Thank you in advance for any help!
    My Macbook only turns on when the charger is plugged in and only the trackpad and fans show signs of life. The display, caps lock light and touchbar do not turn on. There was previous liquid damage to the touchbar but after cleaning and drying the laptop was operational for a year without any issues. There doesn't seem to be any sign of liquid damage to the board, at present.
    What I have done so far:
    - All of the routine diagnostic methods including...
    08-29-2025, 08:38 AM
  • reessi
    Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
    by reessi
    Hello:
    I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
    I started on the ACER:
    Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
    All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
    I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
    10-29-2024, 11:31 AM
