What do you think of TV LED tester eBay
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: What do you think of TV LED tester eBay
    Just use a dmm lol and for 5v leds a old pc psu with come bodged wires cheap but it works.
      • 31280
      that's not what this is,
      it will power a whole series-string without stripping the panel.
        • Jul 2011
        • 6070
        It came in the mail today--------->>>>>>>
        I have tried this unit and a couple of comments about how it works------->
        One thing I have seen with unit it works real good if it only has one row another words
        Series string
        But it dose not work as well if there are in parallel then LEDs do not get very bright you can see if all LEDs are working or not which is good thing
        Are there any LED testers that would do parallel LED strings ---->>>> just asking
          • Jul 2011
          • 6070
          Originally posted by Andrew F. Ali
          Great!!...BTW mine did come with the ac chord....I replaced it wit a longer one....that's why I forgot. Good Luck!!
          Yea it came with a cord and yes it is short I am going to find a longer cord and I will also put a ON / OFF switch on the cord as well
          I also going to buy a second one and put alligator clips on this one so do have keep pulling out leads and break them
          • snot522
            • Jun 2013
            • 7
            • micronesia
            same as mine great tools....
            http://i251.photobucket.com/albums/g...psxhmzkis8.jpg
            http://i251.photobucket.com/albums/g...pshluvqycb.jpg
              Can you show me the parallel connected LED strings? If they use more than one strings and they are not connected in series to form one big long string each string will have its own MOSFET and current sensor for each string so it this the case to you to locate the Cathode return side of the each string of LED so you can just light up just one string only, it will be very bad design to have the LED strings connected directly in parallel, if one goes open circuit the current on the working string will go up and it is also hard to get the match the total Vf of each string to get each string to have equal current flow.
                • Jul 2011
                • 6070
                Here is the board in question as you can see there only drop down resistor
                So is there any kind of tester that would work this kind of board
                The way this board is set this see a lot of LED board set up
                  Those LEDS are not connected directly in parallel, each set has its own limiter resistors so this kind of the set the total current draw will be higher than that LED tester can deliver.
                  You will have to put the Red probe of the tester on the Anode of the second LED of the string you want to test, the black probe on the Cathode of the last LED in that string, then you can test the first LED of that string by itself.
                    • Jul 2011
                    • 6070
                    Thanks for the feedback
                      BTW, if you check the current draw of that LED panel then you will see why that tester cannot drive that LED panel.
                      • DXseekerMO
                        Backlight strip quality, Amazon vs Ebay vs ShopJimmy. Is there really a difference?
                        by DXseekerMO
                        Hello everyone!
                        Recently I've noticed that some ShopJimmy backlight strips don't have double-sided tape installed upon them when an application calls for it, and I must purchase the tape separately. In a recent chat conversation with a customer service agent I told them if this tape wasn't applied when it was called for I would begin to consider ordering my backlight strips elsewhere. It looks like this time may have come.
                        I recently got a TCL 65S4 with bad backlights. After looking at the SJ listing here: https://www.shopjimmy.com/tcl-jl-d65...365as-m-led-ba...
                        Yes
                        0%
                        1
                        All backlight strips are the same quality
                        0%
                        1
                        No
                        0%
                        0
                        12-16-2021, 03:58 PM
                      • howardc64
                        Don't probe Samsung LED conector with LED tester, connect may not make contact afterwards
                        by howardc64
                        Samsung have been using this style LED connector for few years now
                        Usually good idea to test the LEDs before opening the panel to change them. I do this without the PSU stil connected. With this connector (white one) have to jam the LED tester probes in the very narrow thin slot where the PSU blade style male prong inserts into. I've done this on many Samsungs without problem until today...
                        The female terminal inside the white connector has fragile fingers that grabs onto the male blades on the PSU's black connector. If the LED tester probe spreads open...
                        10-12-2025, 08:13 PM
                      • Lifeisfun
                        Trying to troubleshoot DDR4 SODIMM slot with slot tester
                        by Lifeisfun
                        Hi folks!
                        I have some kind of memory problem on Lenovo laptop. I was initially able to install windows after several tries since the laptop did freeze in middle of those attempts.
                        Eventually I discovered that it was related to moving the laptop.
                        Later on it even stopped booting unless I pressed around the memory slot. (no keyboard LEDs only power button responds)
                        If I remove the RAM I get the beeps that RAM is missing. Inserting the RAM there is silence and it will not boot most of the time. No picture.
                        I removed the board got one of those memory slot testers...
                        06-04-2025, 02:26 PM
                      • spleenharvester
                        Reverse engineering of 18650 4-channel tester
                        by spleenharvester
                        Hi friends
                        I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
                        05-04-2025, 02:43 AM
                      • myth77
                        how do you resolve problems with ebay (and other shop) scammers!?
                        by myth77
                        When i need to replace cpu or gpu or pch ...i mostly order reballed chip from china, but lately there are more broken ones then working.
                        So lately i tried with ebay "not working motherboards". I ordered a few broken motherboards from ebay but i have found out that there are many scammers on ebay. The most of them are selling already destroyed motherboards with pictures in low resolution, some of them are being scammed and just scam forwarding...
                        First board i ordered last month was ok. Cpu was dead but i could use gpu and pch. The second arrived 2 weeks ago...and it was...
                        09-02-2022, 04:53 AM
