Help me read these resistor colours please?
  • reessi
    • Jan 2016
    • 324
    I would like to clarify if I'm reading these correctly, I always thought there was a gap before the tolerance band. Should these be read starting with black as there is no black tolerance band.
    So the top one could be black, yellow or brown?, grey, red, red. So 0, 1 0r 4, 8, 2x0 so either 1.8k or 4.8k?
    The second:
    black, red, purple, grey, gold - 0,2,7,8x0 = 2700,000,000 so 2700Mohm.
    They both measure dead short.
    Also the red bands could be orange?
    The yellow/brown actually looks gold!
    Cheers.
  • mariushm
    • May 2011
    • 3799
    Re: Help me read these resistor colours please?
    The first could be
    black - red|orange - violet|blue - silver - gold = 0 - 2|3 - 6|7 - x 0.01 - 5% .. probably 0.27 ohm 5% 1w-ish?
    The other is weird... no idea.
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      These resistors are good...nothing is wrong with them......Resistors DON'T go by shorting.....They DO go bad by open circuit or INCREASED resistance.
      • reessi
        • Jan 2016
        • 324
        Ah thanks, that looks right for that one. Anyone solve the other one and a third one I am mythed by. I took another photo of these 2.
        Top looks like - brown, gold, silver, green, red.
        Bottom one looks like - black, gold, silver, orange, orange!
        Both test short but I was already wrong about one, maybe really small again?!
        Cheers.
        • reessi
          • Jan 2016
          • 324
          Thanks Andrew but can you explain the colours on the other 2? Would be handy if I actually understood what they should be, they are probably really small then like the first one but the colour scheme doesn't make sense to me?
          Cheers,
          • petehall347
            • Jan 2015
            • 4425
            • United Kingdom
            those resistors are most likely inductors ..now see how many mh they are .
            plus see what id they have on board and in schematic
            • reessi
              • Jan 2016
              • 324
              I'm not sure thats right as on the board they are labeled R with a no. not L. Also I just had a look at inductor colour charts and none have more than 4 bands? I'm not an expert though!
              Cheers.
              • reessi
                • Jan 2016
                • 324
                I couldn't find the schematic! Its a plasma tv, the service manual has all the other boards but not the psu board. I was looking for a short as it gets very hot! And doesn't turn on.
                • petehall347
                  • Jan 2015
                  • 4425
                  • United Kingdom
                  i have never seen a resistor go short and never expect one to .
                  • petehall347
                    • Jan 2015
                    • 4425
                    • United Kingdom
                    most odd .. not military obviously . no silver band on end .. resistor codes dont make sense to me .
                      • Jul 2011
                      • 6027
                      I googled ( 5 color band restistor ) and found this
                      http://hirophysics.com/Labsheet/resi...sis-codes.html
                      From this cart the it looks like one of resistor is 0.62 ohm
                      I hope this helps
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        whats the psu number maybe we/have can locate a shematic
                          Cheers.
                          Top one is 0.15 Ohms (It looks like Brown not red to me) 5%
                          Bottom is 0.33 Ohms 5%
                          The black band should be for Temp Coefficient.
                          These MOX Flame proof resistors are not marked the same as regular resistors.
                            Disregard to reply.
                            • reessi
                              • Jan 2016
                              • 324
                              Ok, that makes more sense budm. They read like 4 band and the 5th could be like you say co efficient.
                              Why did you say to dis-regard?
                              To vinceroger69 the psu is EAX65359511 from Plasma LG 50PB560B. I have created another thread on the repair if any of you can help.
                              I think the resistors are solved or at least we know why they tested short because they were such low values!
                              The PSU I have now tested on the bench and forced on with a resistor and appears to be fully working outside of the set!
                              Cheers.
                                "Why did you say to dis-regard?" I double posted the answer.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  Cheers.
                                  Well if the psu is testing ok when forced on etc (do you get all the voltages?) that should be ok so time to do more fault finding on the other boards
                                  • reessi
                                    • Jan 2016
                                    • 324
                                    Yes all voltages! I was originally looking for a short on the psu as gets hot when on in the tv. Then got confused by the resistors but that was a red herring.
                                    I am looking at the other boards now. Check my other thread on this tv if you can help.
                                    Cheers.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      ok will have a look
                                      https://www.badcaps.net/forum/showthread.php?t=61852
                                      Have you tried running the test patterns if you can on this set?
                                      • Andrew F. Ali
                                        • Jan 2014
                                        • 2450
                                        • Trinidad & Tobago
                                        Originally posted by budm
                                        top one is 0.15 ohms (it looks like brown not red to me) 5%
                                        bottom is 0.33 ohms 5%
                                        the black band should be for temp coefficient.
                                        These mox flame proof resistors are not marked the same as regular resistors.
                                        +100
                                        • magneh
                                          Is this some kind of fuse resistor ?
                                          by magneh
                                          Hello guys
                                          Taking a look at some KNX domotic modules that were toasted due to some kind of electrical failure, I found out 2 weird looking resistors.
                                          Seem to me like some kind of fuse resistor?
                                          After diggin a bit seems like a fuse wirewound resistor wafer or whatever that is
                                          They are very toasted but I think the 5 band colours are RED GOLD BLACK ORANGE ORANGE or the opposite, not sure which is the first band.
                                          The red band is larger than the 4 others, but I dont have much experience with these components.
                                          Also one of the orange...
                                          02-10-2025, 07:54 AM
                                        • jinu_j
                                          by jinu_j
                                          Hi
                                          05-03-2025, 10:51 PM
                                        • mikey5791
                                          Need help to replace burned resistor in 350w atx psu
                                          by mikey5791
                                          Hi to all forum members,
                                          Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                          The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                          Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                          Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                          12-26-2024, 04:55 AM
                                        • MidnightRoller
                                          Can a resistor lose resistance after hot air?
                                          by MidnightRoller
                                          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                          02-02-2022, 11:46 PM
                                          Acer Swift SF114-34-P25P + Pack Gold Acer 14'' Notebook 1 Specification for Upgrade or Repair
                                          This specification for the Acer Swift SF114-34-P25P + Pack Gold Acer 14'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SF114-34-P25P + Pack Gold Acer 14'' boardview and SF114-34-P25P + Pack Gold Acer 14'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                                          09-07-2024, 03:10 AM
