LG 50pb690V Doesn't Turn on!
  • reessi
    • Jan 2016
    • 334
    • uk
    When plugged in, red power led comes on. After pressing power button led goes out and after a few minutes PSU heatsinks get very hot.
    Voltages tested on PSU when turned on with button, outputs to main board are present but none to Y Sus! PSU can be heard turning on and off and voltages to main board do exactly that but not to Y SUS.
    Tested PSU on bench and forced on with resistor, now all voltages including YSUS ones are all present.
    Can it be bad YSUS or no turn on signal from main board?
    Any ideas what to check on YSUS. I have the LG service manual.
    Cheers.
  • Hamie
    • Apr 2014
    • 1383
    Re: LG 50pb690V Doesn't Turn on!
    So you get -vy voltage?
    • amirabueno
      • Jan 2014
      • 10
      • Philippines
      You check the power voltage 12V /5v/3.3V
      • reessi
        • Jan 2016
        • 334
        • uk
        Made one mistake in first post, the output from PSU is one cable to ZSUS then thats connected to YSUS.
        Another to Main board.
        All the labeled voltages turn on when the PSU is out of the set and forced on with a resistor.
        The voltages to the Z SUS connector do not come on when in the set, even with that cable un hooked or cable from that to Z SUS is un hooked, makes no difference.
        On ZSUS connector is VS -> 205, VA - 55, M5 > 5v.
        Voltages to main board turn on and off every few seconds, regardless of YSUS cable connected or not or Z SUS Cable connected.
        Mainboard cable has 5.2v and 17V all other pins are:
        Auto GND - Whats this?
        M_On - Whats this?
        17V_Det,
        AC_ON - (this turns all outputs on when connected to GND with Resistor),
        RL_ON - Whats this?
        VS_On - I presumed this was to turn on VS and maybe VA but I havn't tried as AC_ON does this anyway so why is this there?
        VS_DET.
        Cheers.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          Have you tried running the test patterns if you can on this set
          can you upload the service manual if too large may have to zip the file etc
          • reessi
            • Jan 2016
            • 334
            • uk
            Ok, tested again today, I made a mistake in my post, with the ZSUS dis-connected VS and VA come back so I think we can be sure its the ZSUS. The YSUS is connected to the ZSUS and makes no difference if connected or not so I'm sure the fault is on the ZSUS as this when connected alone makes the VS and VA dis-appear.
            Any ideas what I can check on the board. Theres another thread on this forum but I already checked what he found faulty and mine seam to be good.
            Cheers.
            • reessi
              • Jan 2016
              • 334
              • uk
              Hi, what is the purpose of the test patterns? If there is no screen output, sorry for my ignorance and how do you do that. I think it was mentioned in another thread on this forum as well.
              Cheers.
              • vinceroger69
                • Mar 2012
                • 6714
                • uk
                whats the zsus board number used in this set? please remember we dont have the board in front of us so we are going from what information you provide us so some good clear pictures maybe be helpfull
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  Cheers.
                  well if the mainboard was bad sometimes the test patterns will run ok so rules a lot of boards out too but as you say you think its a zsus fault now so we can check that first i guess (i havnt worked on many plasmas as still learning) but more experienced members will advise im sure
                  • reessi
                    • Jan 2016
                    • 334
                    • uk
                    Well testing the ZSUS now, every single cap tests short! They're all on the same line so need to figure out if its a cap or something else on the line!
                    Any good ideas on how to find it without unsoldering everything? No visable damage, what about connecting a low voltage to see what heats up, I've seem alot of people do this on phones!
                    Cheers.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      pictures will certainly help us one good one from top and one good one of the bottom of the zsus so we can see where the traces go to etc.
                      A lot of other members maynot/wont help/advise when theres no pictures etc
                        "Well testing the ZSUS now, every single cap tests short!" What are the resistance readings, Ohms, K Ohms, M Ohms?
                        • reessi
                          • Jan 2016
                          • 334
                          • uk
                          I've found the shorts on 4 transistors!
                          2 x GT30F132
                          2 x GT30F133
                          They are on ebay but it would be good if I could get equivalents off RS Electronics. I couldn't find the datasheets.
                          If anyone knows equivalents of where to find the datasheets, I tried google!
                          Cheers.
                          • reessi
                            • Jan 2016
                            • 334
                            • uk
                            Its actually a pound cheaper for me to buy the whole board of ebay:
                            http://www.ebay.co.uk/itm/LG-50PB660...sAAOSwE0JY~x1U
                            Its listed for a different model tv but this no. matches -> EAX65335001
                            but this one does not:
                            EBR77258501 the 8 is a 6 on my board, do think they are the same?
                            Seams better to replace whole board as I do not know if any further faults on mine!
                            Cheers.
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              • uk
                              im think the eax number is just the blank pcb its the ebr number i think you have to match due to different parts fitted etc
                              the other trouble is with ebay IGBT Transistors there are fakes around so if you can get some from rs etc use them if needed they have live chat which is helpfull as saves ringing them
                              • reessi
                                • Jan 2016
                                • 334
                                • uk
                                So it may not be compatible?
                                Unless anyone else knows then I'll probably buy the transistors off ebay then. Or RS if anyone knows equivalents.
                                Cheers.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  Cheers.
                                  May not be wait for other members input as they may know better also live chat rs and ask about equivalent for the igbts
                                  • reessi
                                    • Jan 2016
                                    • 334
                                    • uk
                                    Actually after looking through ebay listings they seam to be interchangable the EBR no. or at least for the tv (50PB660V) that I saw the ZSUS for at £12! My EBR no. was listed on several for that TV.
                                    Anyone else shed light on this no.s meaning?
                                    Cheers.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      its a good price so nothing to loose i guess as may even have the parts you need on it also once boards are side by side you can check for any diffrences if big diffrences can always re sell on
                                      • reessi
                                        • Jan 2016
                                        • 334
                                        • uk
                                        Well I've ordered it and like you say probably has the same transistors on it. The photo of the top looks identical.
                                        I'll report back on sat if it all works or not.
                                        Cheers for helping.
                                        • objecttothis
                                          EVGA 430W PSU Correct voltages but computer won't turn on
                                          by objecttothis
                                          I had a desktop form factor mini-server die on me a few weeks ago. Through my initial diagnostics, I was convinced it was the motherboard because when I shorted the Green wire on the ATX connecter, the multimeter gave me all the correct voltages on the various pins of the ATX connector and 5VSTB was also correct. To my surprise the replacement motherboard wouldn't turn on with the case power button either. I threw in another PSU and it turned on right away. This is an 80 Plus EVGA 430W PSU with PN:100-W1-0430. I pulled the cover off and don't see any immediately obvious blown caps or scorch...
                                          02-08-2025, 11:19 AM
                                        • redbomb65
                                          msi mpg z390m gaming edge ac missing voltages and wont turn on when pressing the power button
                                          by redbomb65
                                          hi i have a msi mpg z390m gaming edge ac mb. that wont turn on when i short the 2 pins on the front connectror.
                                          im new in electrionic repair. and i hope that someone will share a bit knowledge, thoughts or ideas with me and others, to repair that damm thing ;D
                                          1. thought psu problem. nope psu is good. i even bought a psu tester to be save.
                                          2. thought a short somewhere that the psu goes in short save mode. nope... no short to measure with my multimeter to ground. psu and mainboard starts with all cabels plugget in, when i bridge green and black on the 24 pin.
                                          cpu isnt...
                                          01-24-2024, 08:36 PM
                                        • pajdek
                                          Lenovo Y700-17ISK turn on and off
                                          by pajdek
                                          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                          09-20-2023, 02:49 AM
                                        • Capacitorial
                                          Powersupply has all the voltages - Monitor still no power
                                          by Capacitorial
                                          Hello guys,
                                          I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                          I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                          On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                          The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                          The weird thing is, that the Power LED is powered over the TCON board.
                                          On The TCON...
                                          12-28-2024, 02:12 PM
                                        • debidoobs
                                          RX580 GPU have all the right voltages but won't turn on
                                          by debidoobs
                                          Hi Guys,
                                          I just replaced 2 blown fuses on the 12V rail of a RX580 sapphire 8go even though i didn't find any sign of shorts on the 5V, 3.3V or 12V with my multimeter. I don't know the history of the card..
                                          i followed step by step the video from TECH Cemetery (https://www.youtube.com/watch?v=supu7YeNTfw) but when on his RX580 sapphire 8go he doesn't have VCORE mine does but won't turn on .. I watched many video but i don't find same situation i m facing. So im clearly lost because all measurements steps i did on the GPU are fine. I have a B550m, a 550W psu, 16go...
                                          02-25-2023, 10:35 AM
