ULN2003 max input voltage?
  • waqqas.qayyum1
    • Feb 2017
    • 21
    • Qatar
    Dear Sir,
    Can you please tell me that what could be the maximum voltage we can provide at the input of ULN2003.. Please provide the answer I shall be very thankful to you.
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Getting a display from Apricot computer
    That is a 7 Channel Hi-Volt Hi-Curr Darlington Array....I couldn't download the Data Sheet.
      Originally posted by waqqas.qayyum1
      Dear Sir,
      https://cdn.badcaps-static.com/pdfs/...83d958bacf.pdf
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        +1..Thanks budm.
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          Re: ULN2003 max input voltage?
          I've deleted your tripleposts in unrelated topics and made this one instead.
          Incidentally I saw this video a few weeks ago that takes up this topic:
          https://www.youtube.com/watch?v=hkbP...s&spfreload=10
          • waqqas.qayyum1
            • Feb 2017
            • 21
            • Qatar
            Dear Sir,
            What is the max voltage we can supply at inputs and supply voltage??
            Mean 7 Channel so 7 inputs = What can be the max input volt?
            and comm that is supply voltage = what could be max supply volt to this ic?
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8711
              Datasheet says max input voltage is 30V.
              • waqqas.qayyum1
                • Feb 2017
                • 21
                • Qatar
                Thank you so much sir. Thanks alot.
                • waqqas.qayyum1
                  • Feb 2017
                  • 21
                  • Qatar
                  I am using ULN2803A for my project. I want to connect 2 relays at each pin. Its mean 8 channel would have 16 relays. So it will work or it will burn the ic? Can any one please give me the answer. I shall be very thankful to you. I am working on this project but I am stucked here.
                  • waqqas.qayyum1
                    • Feb 2017
                    • 21
                    • Qatar
                    I am so confused that 500mA is the max current of all the outputs or its a max current per output pin?
                      Did you download and look at the spec sheet.
                      Page 4: 500mA is the max current each Darlington pair can handle BUT the Total current (sink current) is 2.5A (total Emitter-terminal current), so you can have all 7 loads connected to the IC with 350mA per output so you will not exceed the spec of the total current.
                      Page 5: Vce (sat) is 1.2V @350mA so the power dissipation for each output is 1.2V x 0.350A = 0.42W, times 7 = 2.94W so you must take care of that power dissipation.
                      You need to use the correct relays that will not draw total excessive current.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8711
                        The ULN2803 is 8 channel but also has a 2.5A limit so it can handle even less, worst case, for each pin if each needs to be maxed. At 25°C the max power dissipation of the SMT chip appears to be a bit under 2 watts so depending on your load, the ULN2803 will hit its limit before the ULN2003 because it has one more driver and the somewhat less heat-dissipative SMT18 package versus DIP16.
                        • waqqas.qayyum1
                          • Feb 2017
                          • 21
                          • Qatar
                          Dear sir so can i use 16 relays? 2 relay per channel for ULN2803A. Actually data sheet made me confused. each relay coil resistance is 165 ohm and coil volt is 12V. so can i make operational all of the 16 relays at the same time? is it possible. it will not effect the ic life?
                          • waqqas.qayyum1
                            • Feb 2017
                            • 21
                            • Qatar
                            Actually sir i want to modify this circuit. The modification is i need to connect 8 parallel relays with the relays on the board. Now total relays will become 16. Actually the relays on board burn mostly and very difficult to change again and again so i need to connect external relays in parallel along with the relays on the board. when the board will turn on the board relays at the same time the external 8 relays will also be turned on so any time if the external relays with base will be burned out i can change easily. so is it possible or ic will be not be effected by dealing with 16 relays at the same time? I am so confused so give me some solution to make this project successful please. I shall be very thankful to you.
                            • waqqas.qayyum1
                              • Feb 2017
                              • 21
                              • Qatar
                              actually i will solder 8 more relays from down side in parallel with the relays on the board. so the relays on board will be dummy or will not take any load. the same new relays will be operation and can be changed at any time in case of any fault. so this modification will work or not?
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8711
                                Well if you did the math, each relay will draw around 70mA, and 16 of them is well within the 2.5 amperes the ground pin can handle. Calculating it out, you'll dissipate 1.4W worst case, which will make the chip quite warm, and it's probably not a good idea to run that much power through it.
                                What's the expected duty cycle of the relays, will they most/all be "on" most of the time, or will they be cycled frequently?
                                I would suggest removing/disconnecting the old relays from the board if you can... that would get around the power dissipation concern during the worst case scenario.
                                If only one (or in your case, two) relay(s) will be on at any one time, then you don't have to worry about it.
                                • waqqas.qayyum1
                                  • Feb 2017
                                  • 21
                                  • Qatar
                                  actually all will not be turned on at the same time. According to this cct 6 relays (for heating elements R N, Y N, B N) will work at the same time. 1 Relay ( inlet solenoid relay for water intake) will work when all the other relays will be off. and the last relay ( drain relay ) will work when the rest all will be off. so external relays if i will add in parallel will work in together with the board relays like 12 relays at a time and 2 relays at a time and 2 relays at a time so it makes total sum of working of 16 relays.
                                  • waqqas.qayyum1
                                    • Feb 2017
                                    • 21
                                    • Qatar
                                    very difficult to remove the old relays from the board. It damages the board actually
                                    • eccerr0r
                                      Solder Sloth
                                      • Nov 2012
                                      • 8711
                                      Also consider how much time the whole device is turned off, but if it's industrial and needs to be operating 24/7 then you can't take this into consideration.
                                      Up to you, take your chances on it, it could go either way. You're best off adding more margin of error to make sure it won't fail (doubling up on the drivers or removing the redundant relays), but at least on day 1 it seems like it should work fine.
                                      And yes the IC will feel quite warm to hot when the 6x2=12 relays are on... which is why I don't know about the long term reliability.
                                      • waqqas.qayyum1
                                        • Feb 2017
                                        • 21
                                        • Qatar
                                        Dear sir thank you so much. I try to remove relays from the board. Any how if you know the best idea of removing the relays or how to add other relays by making board relays as redundent so please let me know.
                                          LM358 LM358S-13 Datasheet
                                          The LM358 LM358S-13 consists of two independent, high gain, internally frequency compensated operational amplifiers which were designed specifically to operate from a single power supply over a wide range of voltages. Operation from split power supplies is also possible and the low power supply current drain is independent of the magnitude of the power supply voltage.
                                          Application areas include transducer amplifiers, dc gain blocks and all the conventional op amp circuits which now can be more easily implemented in single power supply systems. For example, the LM358 series can be directly...
                                          10-07-2024, 04:12 AM
                                        • Dannyx
                                          Modifying SMPS input voltage range
                                          by Dannyx
                                          Good day folks. Long time no see. It's been a while since I've tinkered with any new projects, despite one thinking this would be the perfect time, with the pandemic and the quarantine, people tend to stay indoors....it's not my case anyway: I go to work like normal, but it's here where I'm bored out of my mind with nothing to do, so here's something.
                                          A while back, I got myself this adjustable load kit form off Ali. I put it together and it works. It's powered by an AC or DC input and I've been running it off a 12v wall adapter on the bench. What good is such a device if it doesn't...
                                          03-30-2020, 06:45 AM
                                        • ugamazing
                                          820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
                                          by ugamazing
                                          So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
                                          1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
                                          2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
                                          04-10-2024, 08:06 AM
                                          Texas Instruments bq24745 bq24745RHDR bq24745RHDT Battery Charger IC for Laptop Computers Datasheet
                                          The bq24745 bq24745RHDR bq24745RHDT is a high-efficiency, synchronous battery charger with an integrated input-current comparator, offering low component count for space-constrained, multi-chemistry battery-charging applications. The input-current, charge-current, and charge-voltage DACs allow very high regulation accuracies that can be easily programmed by the system power-management microcontroller using the SMBus interface. The bq24745 charges two, three, or four series Li+ cells, and is available in a 28-pin, 5-mm x 5 mm QFN package.
                                          The bq24745 features dynamic power management...
                                          10-23-2024, 02:50 AM
                                        • Fernon@Repair
                                          Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                                          by Fernon@Repair
                                          i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                                          VCCIO voltage ok
                                          VCCSA Voltage OK
                                          VCCPLL Voltage OK
                                          Ram Voltage ok
                                          RamVTT OK
                                          VPP 2.5 OK
                                          But No Core Voltage
                                          and i want to this vrm ic datasheet or pinout (ISL69269)
                                          anyone have this ic pinout voltages?...
                                          06-25-2025, 07:19 AM
