XL7005A vs XL7005
  • capwizard
    • Jun 2016
    • 1991
    XL7005A vs XL7005
    XL7005A: 0.4A 150KHz 80V Buck DC to DC Converter, PWM buck (step-down) DC/DC converter, capable of driving a 0.4A load with high efficiency, the heart of DPS5015.
    https://cdn.badcaps-static.com/pdfs/...6da4f5ee4d.pdf
    XL7005: 0.5A 200KHz 65V Buck DC to DC Converter 200KHz fixed frequency
    PWM buck (step-down) DC/DC converter, capable of driving a 0.5A load with high efficiency
    Re: XL7005A vs XL7005
    https://www.badcaps.net/forum/showpo...81&postcount=4
    • capwizard
      • Jun 2016
      • 1991
      Nice, struggling to buy one more toy.
        • 31017
        interesting, 80v limit at the expense of a bit of efficiency / transformer size.
        • capwizard
          • Jun 2016
          • 1991
          Because is buck (step-down) converter, where you gonna find A 60v 15A switch power supply? Let me know, I want one,too....
          PS: 5 ATX power supply add together...I am waiting for boost one.......
            • 31017
            55-0-55 toroid from an old amplifier, or a 48v switching psu with it's output tweaked.
            yes, i already thought about this problem.
            • capwizard
              • Jun 2016
              • 1991
              Wow, you're smart...I never thought about that and throw away 2-3 of them, in fact voltage ripple is better than switch power, I might change my mind..
              • capwizard
                • Jun 2016
                • 1991
                Pic1-2 those are junks, now i test 12v car amp is use this pic3-5 ATX power supple, customer face looks strange, so I will use old stereo amp. build power supple right inside the DENON's case......
                • capwizard
                  • Jun 2016
                  • 1991
                  DPS 5015 Parts came, Smaller than what I thought.
                  Pioneer stereo vsx-519v has no sound, customer abandoned, I gonna use the power supply as sti said : "55-0-55 toroid from an old amplifier," . found AC 39.66v X 1.414 = DC 56v -0-56v, It could be used as a dual 15A power supply. Thanks sti.
                  If I fix the Amp, I can use the power supply and linsen to the music at same time...........Voltage I set up to 12.35v current at 10A( on top of the meter small letters, set: xxxx xxxxx )..........Don't bug me , will change thicker input wires................................
                  PS: My recommendation is: don't but it, It can't survive even at 5A for long period of time! (It is A toy.)
                    • Jul 2011
                    • 6039
                    What this power supply will not put 10 amps for very long what happens I also bought one
                    I want to run it at 10 amps for very long times
                    So what amperage can safely run it at for long periods of time
                    • capwizard
                      • Jun 2016
                      • 1991
                      "what happens I also bought one, " YOU are my body!..............................
                      The MOSFET legs (pins) under the fan need to be resolder, it already have ring on legs even it is brand new. If you are seriously, you can put bigger TO-220 MOSFETs on it (four MOSFETs bridge) will give more power.
                      "So what amperage can safely run it at for long periods of time"
                      extra large heat sink or oil cooler for cpu.
                      Measuring the Voltage Ripple of the DPS5015
                      https://www.youtube.com/watch?v=WpbkxL0p7u8
                      http://www.eevblog.com/forum/testgea...ps5015-50v15a/
                      http://lygte-info.dk/review/Power%20...arts%20UK.html
                      Compared to professional units it is missing a lot: Lower noise, both numeric keypad and encoded, 4 terminal connections, computer control, larger display. But for the price it is very good and works fine.
                      http://lygte-info.dk/review/Power%20DPS5015%20UK.html
                      • capwizard
                        • Jun 2016
                        • 1991
                        Need help to find the specification of this mosfet which is one of the (four MOSFETs Full Bridge)? at Pic8
                        Pic last one: The MOSFET legs (pins) under the fan needs to be resolder, it already has ring on leg even it is brand new (with never load)
                        PS: look! How small it is!
                        Hope! Can use Door Hinge Rework Station take out the microcontroller and read Firmware on it then ZIP for you guys. Anyone has idea of those pins ( V GCD) or the other one (Rx B TX) at (pic2) . Can I read it with my TL866A ? and HOW?
                        • capwizard
                          • Jun 2016
                          • 1991
                          microcontroller is 32f100 in LQFP48 packing
                          https://cdn.badcaps-static.com/pdfs/...a875e57a69.pdf
                          PS: Anyone has idea of those pins ( V GCD) or the other one (Rx B TX) at (pic2) . Can I read it with my TL866A ? and HOW?
                          PS: TX is at pin30, RX is at pin 31, (pin30 is PA9 pin31 is PA10?).
                          Embedded SRAM
                          Up to 8 Kbytes of embedded SRAM accessed (read/write) at CPU clock speed with 0 wait states.
                            It is not hooked up as full bridge, look at how Gate of T1 and T4 are tied together, also how the Drain of T2, T3 are tied together and connected to T1 Drain.
                            • capwizard
                              • Jun 2016
                              • 1991
                              You are good and Youre really pay attention to detail. YES it is A Half-Bridge.......you're right again..............
                              Pic1 is U02 show 5106 is LM5106 100-V Half-Bridge Gate Driver With Programmable Dead-Time
                              LM5106
                              https://cdn.badcaps-static.com/pdfs/...bb5162a5d8.pdf
                              NCP5106A
                              https://cdn.badcaps-static.com/pdfs/...c8362829bb.pdf
                              PS: last pic can see the U02 NO.
                                So that 10-pin IC where the 4 MOSFETs are, is it XL7005? 5106?
                                Never mind, I see it now.
                                • capwizard
                                  • Jun 2016
                                  • 1991
                                  One question? why uses A half-bridge driver not the full bridge driver?
                                    Full Bridge, both terminals of outputs are not ref to GND, V drops on the load is also about 2x the supply Voltage, they are both hot, same basic as amplifier set to bridge mode.
                                    You need to see how those 4 MOSFETs are actually connected.
                                    • capwizard
                                      • Jun 2016
                                      • 1991
                                      "V drops on the load is also about 2x the supply Voltage." very good!
                                      PS: Ive traced the circuits, it like twins, two MOSFETs put together to increase current, and it only has two driver signals (Lo and Hi) (full bridge needs 4 driver signals.).
                                      My home work.
                                      provides characterization data of its half−bridge driver to show the maximum negative voltage the driver can safely operate with. To prevent the negative injection, it is the designer duty to verify that the amount of negative voltage pertinent to his/her application does not exceed the
                                      characterization curve we provide, including some safety margin.
                                      Confirm zero-voltage switching during all operating conditions
                                      http://www.powerguru.org/the-half-br...cuit-revealed/
                                      Half Bridge vs Full Bridge
                                      https://cdn.badcaps-static.com/pdfs/...aa877cf64a.pdf
                                      • capwizard
                                        • Jun 2016
                                        • 1991
                                        EEVblog #900 - STM32 ARM Development Board
                                        https://www.youtube.com/watch?v=mkx4qZCCHqI
                                        I don't understand what he's saying? the next one is better
                                        STM32 dev board first steps (linux)
                                        https://www.youtube.com/watch?v=xsYIh1sunso
                                        PS: Can we use Arduino to read it or ST-Link V2?
                                        How to Use ST-Link V2 Utility to program your STM8 and STM32 MCU
                                        https://www.youtube.com/watch?v=d9MftOa28Pw
                                        Discovery[/url] kit for STM32F100 Value line
                                        STM32F100xx value line Flash programming
                                        https://cdn.badcaps-static.com/pdfs/...10a9e60c7c.pdf
                                        STM32F10xxx/20xxx/21xxx/L1xxxx Cortex-M3 programming manual
                                        https://cdn.badcaps-static.com/pdfs/...27f87a1e61.pdf
                                        • Manuel S.
                                          Lenovo Yoga 720-15ikb (LA-E552P): DEAD - strange voltage on 5V buck converter
                                          by Manuel S.
                                          my Lenovo 720 is dead. :-(
                                          I guess i have found an issue on the 5V buck converter (**BAC7NH** from Silergy (also called SY8288C 5V)) but i am not completely sure so i want to ask here for some hints.
                                          Here is a Schematic of the IC: https://prom.ua/p1498216381-sy8288c-...ac-bacxxx.html
                                          When i attach the supply 19V, i only have 1.8V on the OUT (it should be 5V). The IC is getting hot.
                                          The EN1 is completely off 0V, EN2 show 1.5V.
                                          If i inject 5V on the EN1 the OUT goes up to 2.6V (but never reach 5V).
                                          BS seams SHORT to the OUT....
                                          03-14-2024, 05:17 PM
                                        • caspian
                                          Too much current from a Buck Converter
                                          by caspian
                                          Dear members,
                                          Let us consider the buck-converter circuit of +1.05VS_VCCPP in the PDF. +1.05VS_VCCPP is a 1.05v voltage rail. The schematic says the circuit can provide up to 20A of current. It belongs to a laptop: Lenovo G470. B+ is 19v.
                                          Now assume we connect +1.05VS_VCCPP to many ICs to provide power for them. The laptop works in a way that mostly less than 20A are drawn from +1.05VS_VCCPP but sometimes the required current exceeds 20A. For example, 25A or 30A.
                                          PU702 is the controller IC in the buck-converter circuit. It controls the output voltage according to the feedback...
                                          05-29-2020, 06:41 AM
                                        • adamski1952
                                          ps5 shorted after buck converter
                                          by adamski1952
                                          Hi.all.
                                          Working on a PS5 EDM-010 motherboard and i've located a short after the TLV62090RGTR 5v to 3.3v chip directly behind F7002.same chip i think. I've removed the chip thinking that was the problem but the short is still there.I injected 1v at 1 amp on output coil (arrowed in picture) but nothing shows up on my thermal camera. No boardview so I because I dont know which rail it feeds i'm reluctant to up the power injection.I could use some help with this if anone has any ideas. ...
                                          12-18-2024, 08:25 PM
                                        • caspian
                                          Causes of Failure After Buck Converter Repair in Laptop
                                          by caspian
                                          Dear members,
                                          Recently, I watched this nice video:
                                          www.youtube.com/watch?v=XBAn2Ck8GeE
                                          I have experienced such a failure many times in laptops.
                                          He replaced the Mosfets and the controller of a buck-converter in one go. But then after powering the laptop on, the new Mosfets burned again.
                                          What are the popular causes of the repair failure in this video?
                                          note: after removing the coil, he measured that the circuit is not shorted after the coil. only the circuit before the coil was shorted.
                                          03-28-2022, 12:57 PM
                                        • Geeker007
                                          Please review my ESP based WLED controller board for WS2815 12V LED Strips - New to electronics.
                                          by Geeker007
                                          I'm designing an ESP-based WLED controller board for WS2815 12V LED strips, with a primary focus on energy efficiency.
                                          To minimize power consumption, my goal is to completely shut down the system when the LED strip is turned off.
                                          However, the current buck converter powering the ESP module draws about 8 watts even when the LEDs are idle, making it unsuitable for low-power operation.
                                          I am using below components:
                                          • Buck Converter: TPS562201 (12V → 5V regulated)
                                          • Microcontroller: XIAO ESP32-C3 (with built-in USB-C)
                                          • LED Strip: WS2815 (12V digital LED strip)
                                          • Switching
                                          06-29-2025, 05:20 PM
