Replacing cig-lighter connector to air matress inflator
  • Welchs101
    • Sep 2008
    • 979
    HI, I have an air-matress inflator that plugs into the car cig-lighter. Well this end of the connector broke. I dont want to throw the unit away but replace the connector.
    i have a few cig-connectors from my old cell phone chargers but not sure they will work as they may be rated differently.
    Any suggestions.
    See enclosed pics
    • 31277
    Re: Replacing cig-lighter connector to air matress inflator
    that connector looks like shit, you can get one with a fuse in it and an led for a couple of $ or less.
    i cant comment on your actual question - you didnt show the other connectors.
    but they are probably good to use.
    • mhc
      • Oct 2016
      • 3
      • usa
      Check the insulation of wires on the inside of the broken connector,one is probably ribbed and the other is not. On the new connector attache the wires as they were on the broken connector.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8706
        The cell phone plugs are likely not rated for a few amperes of current needed for the inflator which probably needs to deal with 4 amps or so, maybe more instantaneously. You could jury rig the plugs but need to make sure the heavy wire comes out of the plug which might require some hacking...
        I was tempted to do the same but worried about the current rating that may cause failure down the road (my device was a thermoelectric cooler.)
        https://www.radioshack.com/products/...nt=20331738501
        • R_J
          • 9621
          You can get ones with the wires attached also https://www.amazon.com/Roadpro-Fused.../dp/B0016LG0CY
          • rhomanski
            nowhere man
            • 5157
            • U S of A
            I used to try to use them things. The motors were so cheap the impeller would break after about 10 uses and I'd have to get another one.
            sigpicThe Sky Is Falling
            • televizora
              ghettomodmaster
              • Nov 2016
              • 957
              • Bulgaria
              The connectors itself are identical, only the gauge of the wires that are soldered on the pins is different. I bought some spare cig-connectors. Chinese it seems. They come with fuse. You have to solder the wires yourself.
              The price of one cig-plug here, in Bulgaria is less than 1lv(less than 0.6$) But you can't really expect high quality, so even if you replace your plug - handle with care. The plastic from which the plug is made is very very fragile.
              Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
              1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
              • 5mall5nail5
                Help identifying connector for ASUS 4090 Strix RGB LED connector
                by 5mall5nail5
                Hi All -
                I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
                Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
                05-04-2025, 07:47 AM
              • bussincaps
                MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
                by bussincaps
                Hello All,
                tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
                Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
                eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
                Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
                I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
                08-03-2023, 12:57 PM
              • michhak
                Toshiba Satellite M50-A keyboard connector on LA-A481P motherboard
                by michhak
                Hi guys,
                i have a damaged keyboard connector on my older Toshiba Satellite M50-A laptop. I know there is LA-A481P motherboard. In attachment pictures there is a real looking connector and i also found a schematic to the connector. But i need help with finding a real electronic part to replace the damaged connector. e.g. on aliexpress (or different page).
                It is 34pin connector and the length from pin n.1 to pin n.34 is 26mm. So it means a pitch length is 0.764 mm. I have seen connectors with 0.5mm , 0.7mm , 0.8mm and 1mm pitch length. But not with 0.75. Is it some special custom connector...
                11-17-2021, 05:45 AM
              • Tomylee
                No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
                by Tomylee
                Sorry for the person who’s going to read all this !
                I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
                While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
                During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
                07-11-2025, 11:52 AM
